Like Tree9Likes
Old 12-31-2015, 08:45 AM
  #46411
Does anyone know where to find a receiver box for either losi ten scte 2.0, or losi 22 sct 2.0??
Amazonnaterc10 is offline
Old 01-01-2016, 08:46 AM
  #46412
Originally Posted by gernaat
Well why would I doubt you A quick bench test shows its in the center. With a some throttle... grabbed both rear tires and can see pinion and spur spinning but no rear drive shaft. Back to the drawing board.
So I thought that spool locker entirely locked the center diff... wrong. I hot glued the center diff and now I'm in business. If the glue doesn't hold up I'll try the jb weld... but I'm happy with it right now.
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-image.jpeg
gernaat is offline
Old 01-08-2016, 07:44 PM
  #46413
Ok guys, I will apologize up front. Newbie here. Just purchased a brand new in the box Ten SCTE from a guy at the local track. Its about 4 years old but never taken out of the box. This isn't my first rc but is the first that I have to add electronics to and can race. Technically this is my ten year old son's rc. Already purchased a lot of stuff but unsure of some detailed items. What I already bought.
Tools, shock oil, diff oil, grease, tire glue, batteries, 4 bank charger, tx, ride height gauge, camber gauge, transponder, hitec 7055tg, tekin pro4hd 4300, tekin rx8. My question is what spur and pinion do I need? I have tried to research but there is just so much info available that it's confusing. 39 or 40 spur? What pinion? Is this a Mod 1? Known parts that need replacing/upgrading before hitting the track? Thanks in advance and specifics on spur and pinion or even links would be greatly appreciated.
CJClyde is offline
Old 01-09-2016, 05:46 AM
  #46414
EJ2civic's Avatar
The truck comes stock with a 40T MOD1 Spur gear. Pinion gears will be your choice depending on what power system you plan on running. Pinion size is also determined by what size track you are running on, also what motor and ESC temps you are reading. The BEST tool for you to buy is an infrared temp gun. With this, you can monitor ESC, motor and even battery temps. My truck is equipped with the Novak Pulse V2 ESC with Tekin SC4X 4.5T 550 motor. I run on a medium sized indoor carpet track. Therefore, I only have use for a 13 and 14T pinion gear.
EJ2civic is offline
Old 01-09-2016, 06:41 AM
  #46415
dtr
dtr's Avatar
Definitely get an aluminum servo horn.
The stock shock towers are prone to bending; replace them with carbon towers when they are out of shape.
The kingheadz front upright for the center diff will reduce wear on the diif outdrive and drive pin.
dtr is offline
Old 01-24-2016, 09:45 AM
  #46416
Trader Rating: 66 (100%+)
One thing about the used and or new V1 trucks that make them a great starting point for racing is that just about all the parts interchange with the 2.0 truck. Fix your diff leaks at rebuilt time and slowly upgrade to the 2.0 as parts need to be replaced. The V-1 truck is still a front runner, the updates just make it more durable and handle even better.
http://www.rctech.net/forum/electric...f-diffs-3.html
Thunder Trail is offline
Old 02-03-2016, 07:55 PM
  #46417
Default Wtb and shims
What size shims will I need to rebuild diffs, also diff pinion and outer axle shims?
Anyone have the snr front and rear +9mm shock mounts they want to sell? And what aluminum shock standoffs work for this mod? Thank you...
Also looking for tekno front drive shaft and hub set.
Also looking for aluminum front and rear arm cariers....
Please pm me..
shumway is offline
Old 02-04-2016, 02:26 PM
  #46418
Please pm me..
Not sure if you are asking for the info or for used parts.
Most diff info is in the link I posted above. It includes part numbers for the shims and seal info.
Team Losi Racing Aluminum Rear Gearbox Bearing Insert Set (2) [TLR3100] includes the side shims. Same shims fit front and rear diff housing bearings. Use those to adjust clearance between ring and pinion gears.
Losi 5mm/6mm Metric Shim Set [LOSA6356] works for diff pinion depth, but not often needed. I have used them on the stub axles as well.
Tekno RC HD Center Driveshaft/short (SCTE - Front/SCTE 2.0 - Rear) [TKR2213]
Tekno RC HD Center Driveshaft/long (SCTE - Rear/SCTE 2.0 - Front) [TKR2217]
Front and rear aluminum hubs are not necessary, but the 15 degree carriers have proven to be a worthy upgrade. Team Losi Racing Aluminum 15 Degree Front Spindle Carrier (+2mm) [TLR334017]
Not needed but Losi Aluminum Rear Hub Set [LOSB2130]
To get the most from the 15 degree carriers use Tekno RC M6 Driveshaft & Lightened Outdrive Set [TKR2210X] on the front.
Hope that helps. I don't know about the shock towers....
Old 02-04-2016, 08:25 PM
  #46419
Default Yes looking for used or spares aswell
Thank you..
-Yes looking for used or spare parts also,
-snr +9mm ft and rear shock tower
-Ft and rear aluminum adjustable hinge pin mounts
-tekno ft drive set and a spare dbone for front
-15 degree caster blocks
-Losi ft/rr light out drives if I can't get the tekno
-plastic rod ends, rear hubs
-center diff brace
-mip super diffs x3
I'm looking for someone who has extra parts and moved on from the scte, I don't mind buying used on some items also.
Thank you...Please pm me for parts
shumway is offline
Old 05-19-2016, 05:46 PM
  #46420
ops, double post
Old 05-19-2016, 05:50 PM
  #46421
I just got the V3 ball bearing plate from Vision Racing. Took out a lot of slop on my V1 and 2.0 truck.
www.visionracing.net
Old 06-02-2016, 11:34 AM
  #46422
Good thread will read more got the girl friend a nitro that was converted so will need help with the upgrades needed . should be here Monday . after teardown I'll know more
barryjcm is offline
Old 06-04-2016, 02:11 PM
  #46423
Don't forget that all the 2.0 parts will fit. even more info about the truck here
http://www.rctech.net/forum/electric...it-thread.html
Old 06-05-2016, 08:13 AM
  #46424
Thanks for info
barryjcm is offline
Old 06-05-2016, 08:23 AM
  #46425
Trader Rating: 17 (100%+)
Good idea to do a -search- in the "for sale" ads before u spend a ton of money on hop ups. You might find a killer deal on a quality finished one and have yours for spare parts or sell it as is and get the newer one less than 1/2 price. Just a thought.
CaptCarnage is offline
