Like Tree9Likes
Old 04-13-2015, 10:42 AM
  #46381
Buhda21's Avatar
Originally Posted by stelio279
13 pinion should be fine for a 4300 kv motor, especially a longer can (HD version) of a 4-pole motor...
If you haven't done anything funky on the electronic side (played with boost, esc timing, motor timing, etc.) then I would look to a potential mechanical issue.
Gear mesh too tight is a likely culprit. But binding anywhere in the driveline will also do this. Remove the pinion and make sure that everything rolls freely throughout. Then doublecheck your gear mesh. If everything is ok, and its really only your motor temps (not esc or batt) it might be bad motor bearing(s) or just a plain bad motor.
Ive Checked Gear mesh. pulled motor and diff's move freely. I just talked with Tekin and they are telling me Im geared to low and should be using a 15 to 17 pinion.
Buhda21 is offline
Old 04-13-2015, 11:13 AM
  #46382
I've run two 3660 size 4,600 kv motors (not Tekin, but Tacon and Tenshock) and run 13 and 14 tooth and it was always fine. I would be surprised to learn that going UP in teeth count would rectify your problem.
Curious to know... Can you please report back if it works?
stelio279 is offline
Old 04-13-2015, 12:44 PM
  #46383
Integra's Avatar
+1 your too low.
Integra is offline
Old 04-13-2015, 03:06 PM
  #46384
ok guys im stumped and need some help. I have a losi scte With an rx8 gen 2 and tekin pro4hd 4300 running 40 spur and 13 pinion. current limiter is at 50% and no timing or boost no drag brake, brake at 50%and cant seem to come off the track with motor temps lower than 187. tried and 12 and 10 pinion and same thing. Any Ideas
I run 15 on my setup and come off our track at 140-145. Stock spur also.
go up young man in pinion!!!!!!!!
freebird is offline
Old 04-14-2015, 07:34 AM
  #46385
mvrk28's Avatar
I run the MIP 40 tooth with a 15 tooth pinion with pro 4 4600 and I've never gone above 150.
mvrk28 is offline
Old 04-16-2015, 06:16 PM
  #46386
does anybody know where i can buy the arr? everywhere I look it's like 400 dollars when on the website it is 300 and it says that yhe item is discontinued.
rcman21 is offline
Old 04-16-2015, 06:31 PM
  #46387
The roller version is discontinued. The options are now a version 1 RTR or a version 2 in kit form.
SpongeX is offline
Old 05-14-2015, 05:27 AM
  #46388
lilws6's Avatar
Hey guys I'm completly new to the 4x4sc and i just picked upa 1st gen roller to race with. I'm putting a hobby wing setup in it for a power plant and i found a used mip chassis on ebay that i ordered as well. I'll be running it indoor on a pretty smooth clay track any setup tips right away or things i should look at. The rear diff is leaking so ill have to rebuild that right away. I've heard to start with 5-5-3 as a base for diff oils. When i get around to racing ill have to get a good set of tires any recommendations on whats good? I run ions on my2wd stocker but not sure if the 4x4 would tear those to shreds. Thanks in advance
lilws6 is offline
Old 05-14-2015, 05:35 AM
  #46389
3093 pages, not planning to scroll them so I'll just ask. what would be the best/most common mods people are using for durability on this thing. Thanks!!
worm304 is offline
Old 05-14-2015, 09:32 AM
  #46390
rcus3r's Avatar
If by 'this thing' you are referring to the bone stock SCTE 1.0, you could check the first page.
If I had to hop it up today, I would, while drinking an IPA (get it? hop...), do the following,
- King Headz center diff mount
- lightened outdrives all the way around
- HD diff cups all around
- cabron fiber shock towers
- chassis
rcus3r is offline
Old 06-22-2015, 10:58 AM
  #46391
Long term project: Am thinking of eventually converting the truck to 2wd for a bullet-proof 2wd racer (for my young son to race a the local track).
I know I could just hot glue the center diff (and remove the front drive shaft and front diff)... Any thoughts on a possible way to introduce some limited-slip in the center diff to make the car more drivable?
Old 06-22-2015, 12:05 PM
  #46392
Casper's Avatar
Trader Rating: 34 (100%+)
What you plan to power it with? This will be one heck of a heavy 2wd car. Balance will be way off as well.
You could fill the center diff with million to 2.5 million diff oil/grease. and see if that works?
http://www.teamgravityrc.com/store1/...=0&sort=normal
or try the puddy stuff
http://www.reflexracing.net/RSD-Sili...ty_p_2204.html
Casper is offline
Old 06-22-2015, 12:07 PM
  #46393
rcgod's Avatar
Trader Rating: 33 (100%+)
Super heavy diff fluid should work. Will probably take some trial and error. They make 100k thru 1,000,000 wt. Amain sells up to 500k.
rcgod is offline
Old 06-22-2015, 12:25 PM
  #46394
Thanks guys, I figured I could use heavy diff fluid, but didn't realize that such heavy weights were available.
Indeed Casper, this would be a tank of a 2-wd SC truck. It would probably be powered by a 4-pole 540 motor, with EPA throttled down for a young child... I don't think balance will be an issue as much as driving in a straight line without crashing! I figured this will make a great car on which to learn RC driving skills.
Old 06-22-2015, 12:51 PM
  #46395
Casper's Avatar
It is quite the durable platform. How young are we talking? My son is 7 and has been driving on an off for about 2 years now. He learned mostly bashing around with a Vaterra Glamis. Thing is tough as nails and looks cool. Not quite a track ready car though.
Casper is offline
