Like Tree9Likes
Old 03-08-2015, 01:49 PM
  #46366
Trader Rating: 66 (100%+)
I agree. The stock shock seals work great and last if you keep the shock boots in good shape. Boots are needed if you run on dusty tracks or outdoors.
Thunder Trail is offline
Old 03-09-2015, 11:11 AM
  #46367
Default hmm
Anyone know where I can buy a chassis skin for the tlr 4000 chassis? All the ones I see say 2.0 and I don't think their the same. Thanks guys
Grunt11b is offline
Old 03-09-2015, 11:41 AM
  #46368
BmainStar's Avatar
Do not run the boots,notice they were not carried over to the 2.0 ? The boots cause binding in the travel of the shock!!!!!! Cheers!
BmainStar is offline
Old 03-09-2015, 04:50 PM
  #46369
The boots do require some thought so they can flow a little air. They are so flimsy there is no way they can hinder the suspension. Just take a small screw driver and gently pull boot to the side in the spring cup slot so there is a very small gap. Rarely have to fix them. On dirty tracks you can still get a year or two out of shock seals and shafts show no wear. I know it is a pain at first, but pays for itself over time and gets easier as well. If your track is clean you may not need them.
Old 03-09-2015, 09:37 PM
  #46370
BmainStar's Avatar
Ya there is no way they hinder the suspension (KNOWN FACT, NOT JUST MADE UP)) ditch the boots kids, better yet get the new kit!!!(LOOK MA ,NO BOOTS!!!): lol:: lol:
Old 03-10-2015, 06:55 AM
  #46371
Yes Sir, just facts. I do understand and respect your point. A few times over the past 30 years of my RC life I felt boots were not needed. However, for harsh conditions I was wrong.
I still have a couple of my RCs from the 80s that were ran 4 days a week for 3 years on out door tracks and the shafts show no signs of wear with boots. Wall hangers now, but track ready. I have a few scared up SCTE shafts that only lasted 4 months and leaked like a $20 RTR.
As I said, its not for everyone. I apologize if I offended you in some way. Just sharing my experience that might be helpful to others
Old 03-10-2015, 07:04 AM
  #46372
Integra's Avatar
+1 no boots required.
Integra is offline
Old 03-11-2015, 12:59 AM
  #46373
MRANTITRAXXAS's Avatar
Shock boots suck! Unless a sponser is making ya run some for advertising
MRANTITRAXXAS is offline
Old 03-12-2015, 01:20 AM
  #46374
Razorbelly's Avatar
Team Associated 13mm shock boots (ASC91070) fit perfect on the Scte and are great for loamy/wet tracks to keep your shock oil clear. Won't hinder performance at all.
Razorbelly is offline
Old 03-12-2015, 08:41 AM
  #46375
Those boots look beefy, last longer. I will try a set. Thanks for sharing the info.
Old 03-13-2015, 12:29 AM
  #46376
vivi_gao's Avatar
Originally Posted by SaladFork View Post
Everything you need to know about your Losi Ten SCTe 4x4....
Truck Manual
http://go.redirectingat.com/?id=42X1...%26p%3D8516085
Type:4WD Short Course Rolling Chassis
Scale: 1/10
Length: 21.34 in (524mm)
Width: 11.65 in (295.8mm)
Wheelbase: 13.15 in (334mm)
Weight: 6.75 lb (3.06 kg) Fully loaded ready to race
Tire Type : Eclipse SCT
Kit/RTR: Rolling Chassis
Shock Type: Aluminum, Coil-over, oil-filled
Body Clear Polycarbonate SCT
Functional mud flaps with Losi logo
Oversized 12mm anodized, threaded shocks
12mm wheel hexes
Secure battery straps
Battery tray accepts multiple types and sizes of packs
Heavy-duty, 4mm tie rods with captured ends
Beadlock-style SCT wheels with rings
Front and rear sway bars included
Eclipse™ Short Course truck tires
Secure radio box to protect the receiver
Simple adjust, aluminum motor mount
Lightweight black anodized aluminum chassis
Needed to Complete
550-sized Brushless System (Motor and ESC)
1/10-scale Steering Servo
2S LiPo Battery Pack and Charger
2-channel Radio System
Polycarbonate Paint
550 Motors
Tekin Redline SC4X 4.5-5.5
Novak Ballistic 550 4.5-6.5T
Novak HV 4.5-5.5T
Fantom Fusion 1 & 2 550’s
Speed Passion V10 3.5R-5.5R
Speed Passion V2 5.5R
Team EPIC Monster Horsepower 550
Team Epic 4x4 Short Course Monster Horsepower 4.5t
LRP X12L Short Course Sensored Brushless 550 Motor
Orion Vortex 10 2800kv (best on 3S)
Castle Creations 1415 2400kv
1/8th Scale Motors
Tekin T8 2650 - Requires slight modification to plastic spacer under the motor mount.
540 Motors
Castle Creations 1410 1Y 3800kv 4 Pole
Gearing recommendations with 40T spur (2 Pole motors)
4.5 550's - 13-16T pinion
5.5 550's - 14-18T pinion
6.5 550's ??
Castle/Neu 4 Pole motors
Castle 3800kv - 13-17T pinion
Castle 2400kv - 17-20T pinion
3MM Mod 1 Bore Pinions for CC 1415 & 1410 motors
http://www.amainhobbies.com/advanced...ds=3mm&x=0&y=0
Recommended ESC’s
Viper VTX10R (3S capable)
Tekin RX8 (Using current limiting (90-80%) can help on motor temps)
Mamba Max Pro
Mamba Monster
Novak Kinetics
LRP SPX8
LRP Sphere Comp TC Spec w/fan
Speed Passion Silver Arrow V2
Stock shock oil f/r - 30w from the factory. Stock Diff's come filled with grease. When disassembling the diff housings, be careful when removing the screws. They have been known to be in tight and require a 1/16th sized hex.
Shock Piston sizes:
#1 0.95mm | #2 1.00mm |#3 1.05mm | #4 1.10mm | #5 1.15mm
Diff housing screw size (for people who have stripped the screws and want another option) Four screws - 2.5mm 45 pitch 10mm. HPI has some screws that work part# Z449 , they are M2.5x12mm 2mm longer than stock but the holes are deep enough in the diff housings.
Diff fluid starting points.
Indoor blue groove 5-7-3 (Front/Center/Rear)
Indoor blue groove 5-5-3 (Front/Center/Rear)
Outdoor med bite 3-3-2 (Front/Center/Rear)
Lunsford SCTE Titanium Turnbuckle kit
http://www.lunsfordracing.com/mm5/me...egory_Code=NEW
2 - 4mm x 65mm Titanium Turnbuckles (Front Camber)
2 - 4mm x 68mm Titanium Turnbuckles (Steering)
2 - 4mm x 70mm Titanium Turnbuckles-Long Thread (Rear Camber)
Bearing sizes for the entire truck
LOSA6907 5 x 8 x 2.5 Ball Bearing 4each Steering
LOSA6947 5mmID x 11mmOD x 4mmW Sealed Ball Bearings 4 each Front and Rear Diff Pinions
LOSA6954 5 x 10 x 4 Sealed Ball Bearings (clutch bearings for Ten-T)
LOSA6956 12 x 18 x 4 Sealed Ball Bearings 6each F/R/C Diff outdrives
LOSA6957 10 x 15 x 4 Sealed Ball Bearings Plastic Retainer 4ea Inner Hubs
LOSA6958 6 x 12 x 4 Sealed Ball Bearings with Plastic Retainer 4ea outer Hubs
Factory Parts Listing
http://www.horizonhobby.com/Products/RelatedParts.aspx?ProdID=LOSB0127&Category=Parts%2 0Listing#prodDetailTabs[/URL]
Parts Weight
Losi stock battery tray: 2.8oz/79g
Losi stock rear hubs: 7g
Losi aluminum rear hubs: 10g
Casey Pecks win at the Nitro Challenge- http://vimeo.com/20541530
SaladFork & SC Rage - http://www.youtube.com/watch?v=3lYe7T0S7To
Blitz sized bodies fit with the least trimming. SC10 bodies fit but require more trimming.
PM me with any TLR SCTe win and I will post you here.
Anyone who has been reading the thread knows the diff pins on the first shipment of trucks have diff pins that are to soft for brushless power. Losi has updated the pins in the second shipment. If you suspect you have the older pins, contact Horizon Hobby (877) 504-0233, they will send you new pins free of charge. We don't need you to post about how pissed you are, we get it... It happened to all of us.
Diff Pins
The diff pins in the truck have been fixed in the seconds shipment of trucks. If you would like aftermarket pins, I suggest using Chrispins ([email protected]) or visit his forsale thread located here - http://www.rcshortcourse.com/forum/s...ad.php?t=18851
Diff pin length
24 mm long 3mm thick and the grove in the middle is 3mm long and 1.5mm deep
Chassis droop screws
Keep an eye on your chassis where your droop screws hit the stops. The small screws will chew down the chassis over time and cause premature wear. You can prevent this by installing 4-40 x 4mm Droop Screws (part#LOSA6253) http://www.horizonhobby.com/Products...rodID=LOSA6253
Servo Saver
From the factory check your servo saver for tightness, we have seen this comes loose and causes steering issues. Red loctite seems to be the fix, blue loctite just doesn’t hold over time.
OEM Hop-up Parts
http://www.horizonhobby.com/Products...prodDetailTabs
Front/Rear Lightened Outdrives Part # LOSB3575
http://www.losi.com/Products/Feature...rodId=LOSB3575
Center Lightened Outdrives Part # LOSB3576
http://www.losi.com/Products/Feature...rodId=LOSB3576
Technical Questions: Questions about this product should be directed to Horizon Hobby's Product Support department.
Horizon Hobby, Inc.
ATTN: Product Support
4105 Fieldstone Road
Champaign, IL 61822
Email: [email protected]
Support Phone: (877) 504-0233
Fax: (217) 355-1552
Can i use this post?
vivi_gao is offline
Old 03-15-2015, 01:57 PM
  #46377
Anybody try the Teflon shock bushings from Vision Racing?
www.visionracing.net
Old 03-15-2015, 04:58 PM
  #46378
I am new to the SCTE and RC in general. I just got back from my track where I had a strange problem like my SCTE had a slipper clutch that was way too loose. I know the SCTE doesn't have any clutch. I was clearing jumps earlier in the day just fine and then later I didn't have nearly the acceleration. Batteries were fine. Any help is appreciated.
Himmelberger is offline
Old 03-16-2015, 07:11 AM
  #46379
Himmelberger, it sounds like you are running in "2wd mode".
One of your drive shafts may have come loose... Check the connection of the coupler of the center CV shafts, probably the front-center to the front diff. It might be as simple as tightening the set-screw on the coupler. However, if it was running loose for a long time, it may be that a pin flew out (Part No. B3556).
stelio279 is offline
Old 03-16-2015, 07:17 AM
  #46380
Integra's Avatar
Center Drive shaft set screw came loose ? Melted a diff ? Missing a CV bone ?
Time to get inspecting.
Integra is offline
