Like Tree9Likes
Old 01-28-2015, 03:58 PM
  #46351
mojo 309's Avatar
is this a losi scte 1.0 reissue with a updated chassie with a 4pole system? and what are the chassis updates besides the battery box. looks like a scte 1.0 on 2,0 chassis to me,whats the point of this.
mojo 309 is offline
Old 01-28-2015, 04:30 PM
  #46352
Doug T's Avatar
Trader Rating: 114 (100%+)
So...... It looks like AVC is creeping into race vehicles. Is it legal to race with AVC? Just wondering. I always thought it was not legal to use any kind of vehicle control assist in racing. I wonder if tracks will start to look for this.......
Doug T is online now
Old 01-28-2015, 05:01 PM
  #46353
mojo 309's Avatar
you make a good point with the AVC thing I always heard it wasn't allowed in racing but maybe its the winds of change thing going on or the RC canpanys are trying to drum up more bussisnes by making things easyer to drive.wouldnt surprise me if someday there is autpiolet control opions built into the radio's
mojo 309 is offline
Old 01-28-2015, 05:20 PM
  #46354
Casper's Avatar
Trader Rating: 34 (100%+)
You can quite easily disarm the AVC for racing and the receiver has a "blinky" mode like a spec ESC for easy teching if rules require you not run it.
The market for this truck is the guy who is going to bash with it so they add AVC to help guys handle the power to keep it under control and fun. Obviously you can and it will be raced but considering the intended market it is a neat option they include.
Casper is offline
Old 01-28-2015, 07:02 PM
  #46355
mojo 309's Avatar
casper is this truck a reissue of the ten scte 1.0 chassis that has been drilled out to the scte 2.0 spec's? and can any of the parts like the battery tray wire holder for the top of the center diff steering servo set up work on original ten scte 1.0
mojo 309 is offline
Old 02-02-2015, 06:03 AM
  #46356
Hi all,
Just wondering which online stores do you people buy your losi spare parts from?
Im in australia.
Aprilia060 is offline
Old 02-02-2015, 12:48 PM
  #46357
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Aprilia060
Hi all,
Im in australia.
International
1) AMain Hobbies
2) Losi Parts House
Australia
1) Model Flight - They are the Losi Distributor for Australia.
2) RC Hobbies
Drift_Buggy is offline
Old 02-23-2015, 01:47 PM
  #46358
After 2 years of light to moderate racing, I figured time to overhaul the shocks... Can someone post a link or list the part number for the best shock bottom seal o-ring replacement? I have the stock blue shocks that came with the ARTR kit (not hard-anodized option).
I have read that the Kyosho 1/8 x-rings are a great replacement, but not sure what part number these are.
Also, I heard the 22 low friction O-rings are good (these I think: http://www.amain.com/team-losi-racin...ings-8/p207255) but maybe these are better: http://www.amain.com/team-losi-racin...al-set/p265892 ??)
I could get the Ten-T rebuild kit and keep in emulsion mode, but I really just want the darn seals: http://www.amain.com/losi-shock-rebu...-ten-t/p157920
Thanks guys
stelio279 is offline
Old 02-23-2015, 02:31 PM
  #46359
Casper's Avatar
It is basically a 2.0 spec truck as far as chassis layout and towers however you get normal anodize shocks, not coatings on the shafts, plastic chassis braces, non flex tuned chassis, battery holders do not look adjustable. Small things like that to keep costs down for an RTR but it is a 2.0 spec truck as far as cambers links and chassis layout.
Thanks guys
Stock ones lasted 2 years and you are looking for something better?
Casper is offline
Old 02-24-2015, 05:40 AM
  #46360
Casper, when has adequate performance stopped ANYONE in this hobby from trying to find the next best needless pseudo performance upgrade?
Seriously though, the stock ones don't seem to come separately, only the whole rebuild kit for 2 chocks, so more expensive for all 4, and it looks like it would be cheaper to buy a set of just the seals... If the seals come separately, it would be really helpful if you could provide a part number or the best alternative.
Old 02-24-2015, 07:21 AM
  #46361
Casper's Avatar
Anything on my cars that lasts 2 years without needing to be replaced would go back on my car. I honestly have not tried anything else in these shocks as the stock ones just plain work. I know others have tried other stuff. As for your argument that the o-rings only come with the rebuild kit. If you shocks have not been touched in 2 years might as well do a full rebuild vs just o-rings.
Casper is offline
Old 03-08-2015, 01:49 PM
  #46362
Trader Rating: 66 (100%+)
I agree. The stock shock seals work great and last if you keep the shock boots in good shape. Boots are needed if you run on dusty tracks or outdoors.
Thunder Trail is offline
Old 03-09-2015, 11:11 AM
  #46363
Default hmm
Anyone know where I can buy a chassis skin for the tlr 4000 chassis? All the ones I see say 2.0 and I don't think their the same. Thanks guys
Grunt11b is offline
Old 03-09-2015, 11:41 AM
  #46364
BmainStar's Avatar
Do not run the boots,notice they were not carried over to the 2.0 ? The boots cause binding in the travel of the shock!!!!!! Cheers!
BmainStar is offline
Old 03-09-2015, 04:50 PM
  #46365
The boots do require some thought so they can flow a little air. They are so flimsy there is no way they can hinder the suspension. Just take a small screw driver and gently pull boot to the side in the spring cup slot so there is a very small gap. Rarely have to fix them. On dirty tracks you can still get a year or two out of shock seals and shafts show no wear. I know it is a pain at first, but pays for itself over time and gets easier as well. If your track is clean you may not need them.
