Like Tree9Likes
Old 12-16-2014, 05:29 PM
  #46336
Suspended
Trader Rating: 440 (99%+)
Hey guys I recently bought a ten scte with a Bump chassis installed. Just curious what is a good starting setup on diffs and shocks? I have a small outdoor track in my back yard that I'm going to start running it on and then going to try some indoor racing over the winter.
MattP is offline
Old 12-17-2014, 02:57 PM
  #46337
Casper's Avatar
Trader Rating: 34 (100%+)
www.Casper-RC.com has great setups for the SCTE.
Casper is offline
Old 12-18-2014, 10:30 PM
  #46338
Suspended
K thanks!
MattP is offline
Old 12-19-2014, 07:19 PM
  #46339
mojo 309's Avatar
is any one still racing their scte 1.0 against the scte 2.0 and how is the scte 1.0 with all the hop ups doing side by side with all the newer brands scte2.0 rc10 2.0 tekno and others.
mojo 309 is offline
Old 12-19-2014, 07:34 PM
  #46340
Registered User
can you fit the radio tray out the scte 1.0 in a scte 2.0 at all
TheMuffinman is offline
Old 12-19-2014, 07:39 PM
  #46341
mojo 309's Avatar
I have the ape battery tray in my scte1.0 and it works really well, it moves the battery up to 3/4 back and the esc 1/8 lower to the chassis for a lcg and helps with the balance on the scte1.0
mojo 309 is offline
Old 01-22-2015, 03:12 AM
  #46342
Can the Losi 22 shock caps fit the scte? According to there website they are both 12mm shocks
Rcbitz is offline
Old 01-26-2015, 09:12 AM
  #46343
JourneyMan's Avatar
Trader Rating: 91 (100%+)
Haven't trouble finding dunford's final setup for the 1.0 truck. Does anyone have a link to it?
JourneyMan is offline
Old 01-26-2015, 09:20 AM
  #46344
http://www.petitrc.com/setup/losi/Se...siTENSCTE.html
sp0097 is offline
Old 01-26-2015, 09:22 AM
  #46345
JourneyMan's Avatar
Yeah thanks bud, but his final 1.0 setup is not on petitrc. Most of those setups have also been replaced with 2.0 setups. MAH.....
Old 01-26-2015, 09:28 AM
  #46346
http://www.casper-rc.com/images/TEN_..._13_reduce.pdf
CasperRc has his setup for 2.0, which I understand is very similar to the 1.0 setup.
sp0097 is offline
Old 01-26-2015, 09:38 AM
  #46347
JourneyMan's Avatar
close but no cigar.
Old 01-26-2015, 10:01 AM
  #46348
JourneyMan's Avatar
Originally Posted by hacker07
I have attached the most recent and final SCTE 1.0 setup.
Took me an hour to find, but it was in this post.
For the record, the 2.0 truck has different front and rear towers, so different rear camber positions. Also a different chassis/motor position, so weight transfer is different.
Old 01-27-2015, 10:05 AM
  #46349
Casper's Avatar
The original 2.0 setup is basically where we left off with the 1.0 and started the 2.0 setup wise.
Casper is offline
Old 01-28-2015, 01:05 PM
  #46350
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
New Losi® 1/10 Troy Lee Designs TEN-SCTE RTR
Features
AVC Equipped 2.4GHz Receiver with 2.4GHz DSMR™ technology
Completely ready-to-run with everything needed in one box
Shaft Driven 4WD Drivetrain with sealed gear differentials
Pre-installed Dynamite® 3900Kv 4-pole 540-size brushless motor
130A LiPo Compatible Waterproof Dynamite ESC
Spektrum™ DX2E 2.4 GHz transmitter and waterproof receiver
Updated chassis layout based on TLR SCTE 2.0
Exclusive Trim-Scheme by Troy Lee Designs
ESC and battery come pre-wired with high-current EC3™ connectors
Waterproof Spektrum servo and electronics
Product Specifications
Type:Short Course Truck
Scale:1/10
Length:21.34 in (524mm)
Width:11.65 in (295.8mm)
Height:7.3 in (185mm)
Wheelbase:13.15 in (334mm)
Weight:6.3 lb (2.9 kg)
Chassis:3mm plate aluminum
Suspension:Independent
Drivetrain:4WD
Tire Type:Eclipse SCT
Motor or Engine:540 4-Pole Non-Sensored Brushless
Speed Control:Included
RadioX2E
Servos:Included
Gear Pitch:MOD1
Kit/RTR:Ready-to-Run
Shock Type:Aluminum Coil Over
Ball Bearings:Yes
Experience Level:Beginner
Recommended Environment:Outdoor
Is Assembly Required:No
Needed to Complete
• Rechargeable Battery 2-3S LiPo with EC3™ Connector
• Li-Po Compatible Charger
Youtube - Losi® 1/10 Troy Lee Designs TEN-SCTE RTR with AVC
Drift_Buggy is offline
