Like Tree9Likes
Old 07-25-2014, 08:57 PM
  #46261
Integra's Avatar
Originally Posted by bds81175 View Post
If the truck is too worn you might consider just saving a bit more and getting the 2.0. Once you start looking at all the things that can wear out and eventually fail your costs will shoot by the cost of a new truck in a hurry.
+1
Integra is offline
Old 07-25-2014, 10:25 PM
  #46262
melski415's Avatar
Trader Rating: 18 (100%+)
True that. I'm fairly new to racing these. I'm just looking for a good truck for the track. Something with lots of adjustability.
melski415 is offline
Old 07-25-2014, 11:11 PM
  #46263
Fegbri46's Avatar
When you rebuild the hd diffs, do you put anything on the blue gaskets (green slime, etc)? Doing the change to diff fluid. Thanks!
Fegbri46 is offline
Old 07-26-2014, 06:30 AM
  #46264
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Nothing is needed with the HD diff cases. Only the blue gasket.
Feint Motion is offline
Old 07-26-2014, 09:11 AM
  #46265
Fegbri46's Avatar
Thanks!
Fegbri46 is offline
Old 07-26-2014, 12:51 PM
  #46266
melski415's Avatar
2.0 rtr for $400 a good deal?
Old 07-26-2014, 03:06 PM
  #46267
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
That's totally dependent on what makes it "rtr".
bds81175 is offline
Old 07-26-2014, 04:06 PM
  #46268
melski415's Avatar
the scte 2.0 has, alum f/r hubs, rpm a arms, 5mm 3800kv 4pole, mmp esc, savox servo, alum top brace, alum chassie brace. I'm not too sure with the radio system and battery yet.
Old 07-26-2014, 04:21 PM
  #46269
Moderator
bds81175's Avatar
Bashing or racing? The RPM A arms are really not necessary on this thing. If you can break one of the stock A arms you are doing something special. The 3800 kV Castle motor isn't terrible. It can be raced but it isn't very smooth. The MMP ESC is capable of either racing or bashing. It's not the greatest ESC ever made but it is definitely versatile and can run either sensored or unsensored motors. I started with an MMP and it worked fine but I eventually replaced it with an awesome Viper VTX8. The Savox 1258 is a pretty popular servo in these things. My $0.02...
bds81175 is offline
Old 07-26-2014, 04:58 PM
  #46270
melski415's Avatar
Thanx. I'm looking for an artr. Something race worthy. I found some with gen1 tekin rx8 but the prices are still sky high for just scte 1.0 and a few upgrades. I will continue with to hunt. Thx
Old 07-27-2014, 10:00 AM
  #46271
Default Losi SCTE RTR loses power after 7/8 minutes
My son races a Losi SCTE 1.0 RTR at our local track. Yesterday, he lost power (the truck quit responding to throttle input) after seven or eight minutes. The problem recurred using three different known-good LiPo batteries.
Thinking the truck might be overheating, I checked the ESC fan. It's working.
Any idea what else I should check?
KyMudhen is offline
Old 07-28-2014, 09:16 AM
  #46272
dtr
dtr's Avatar
How hot was the heatsink on the esc after the run?
What batteries did you use, what were the voltages before&after?
dtr is offline
Old 07-29-2014, 06:59 AM
  #46273
Is the ESC sensored? I had the sensor wire come out on my once. Maybe it's loose?
sp0097 is offline
Old 07-29-2014, 09:07 AM
  #46274
nitro_mt_racer's Avatar
Trader Rating: 230 (100%+)
Probably hit low volt cutoff. That's where "dtr" was going with his line of questioning.
nitro_mt_racer is offline
Old 07-30-2014, 09:03 AM
  #46275
I bought TLR5276 diff oil (2k, 5k, 7k) instead of TLR5277. Does it make a difference if I use TLR5276? I didn't think so, but I figured I would ask folks in the know.
I planned to use 7k in the front, 7k in the center, and 2k in the rear for an indoor high bite track.
sp0097 is offline
