Like Tree9Likes
Old 05-28-2014, 08:54 AM
  #46186
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by AtomicPunk
Thanks Thunder! I agree, the factory could change the front and rear gearbox cases to incorporate the added bearings, but I'm sure there are other trade-offs that they would have to make and the new injection molds would be spendy as well as the Non-Recoverable Engineering costs. That would be a business decision that only Team Losi could make.
I've been through 3 diff housings already before I made these mods so it may be that the additional parts sales are a good revenue stream for them.
The extra weight doesn't seem to bother the SCTE much, but I'm not an accomplished enough driver to really be aware of the difference. Besides, the SCTE 1.0 is no lightweight to begin with!
Thanks again,
Simon
3 diff cases? Did you know they made HD diff cases with the 2.0?
What is wearing out on them? Just leaking?
http://www.tlracing.com/Products/Def...odID=TLR332001
Casper is offline
Old 05-28-2014, 12:04 PM
  #46187
AtomicPunk's Avatar
Thanks Casper,
The last diff cases I ordered were the HD versions for the 2.0. What wears out is the steel insert that serves as the bearing/bushing for the outdrive cup shaft. (See Pic).
One wore out on the external bearing land due to a seized outer diff bearing, the other two wore out due to the bearing/bushing wearing to the point where the poor little silicone o-ring didn't stand a chance at keeping the diff fluid in the case. They developed about 2-3 degrees of angular slop.
The effective bushing length is around .275", not enough to keep the outdrive cup from starting to wallow around in there after 8-10 packs. With the exterior cup bearing modifications, I almost tripled the effective supported length for the cups. I'm hoping this will keep them running square and allow the little seal to keep doing it's job.
Thanks for asking,
Simon
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-scte_07.jpg
AtomicPunk is offline
Old 05-28-2014, 12:23 PM
  #46188
Casper's Avatar
Thanks Casper,
Thanks for asking,
Simon
I have yet to wear out a HD diff case. Do you add a little black grease to the oudrives before you build the diffs? The outdrives should not go in the diff inserts dry.
A bearing failure is a whole different problem. Looks like you run in a some pretty dirty environments though.
Casper is offline
Old 05-28-2014, 12:43 PM
  #46189
AtomicPunk's Avatar
Hi Casper,
The dirt is the problem and yes, I do lube the cup-to-bushing interface with some high temp Dow-Corning Molykote NLGI #2 bearing grease when assembling a new diff.
Thanks,
Simon
Old 05-28-2014, 06:51 PM
  #46190
AtomicPunk's Avatar
Default Four More Packs Today
Another four packs and no reliability problems. The rear cup from the center diff is loose (it's the only one that I can't fit an external bearing onto due to motor clearance) but the rest are rock solid.
Mark and I (Mark has a Traxxas Platinum) had many great competitive laps.
I can't believe how much fun this is!
Simon
Old 05-28-2014, 07:00 PM
  #46191
AtomicPunk's Avatar
Default Question
Hey Casper,
What is the composition of the tracks that you regularly run on? Carpet, blue groove, clay, loamy? I'm impressed that you have never replaced a 2.0 HD diff case.
I think the sand gets the blame for my diff bushing problem. I can live with it.
Thanks,
Simon
Old 05-28-2014, 08:51 PM
  #46192
Trader Rating: 66 (100%+)
Default SCTE Diff Wear
My experience with SCTE diffs started out bad on my first SCTE truck that was used and somewhat tired. I ran the truck until the diff drive cups were wore slap out and needed to be replaced. Over 100 lipos of torture and it all needed to be replaced. The HD diff cases or even the 1.0 cases last and last if you change the oil and grease often. I have some diffs with over 300 runs, but they are taken apart every 50 to 60 lipos for oil and diff washers. The silicone seals seem to last about 150 lipos with this frequent maintenance. However, these diffs eat diff washers/shims fast. The washers fill the diff oil with metal and increase wear. After about 80 to 90 lipos with no maintenance my diffs are all but done.
I'm experimenting with some different washers/shims and even Casper Extreme Grease all in an effort to reduce maintenance 50%. It would be great to go 100 runs between service intervals, but that might not be posible on these dirty tracks. I just started this test so it will be end of summer before I will have any info worthy to post. However I have a good feeling about the new washers that are about the same size as MIP diff washers but at a much lower price.
Indoor or clean tracks are easier on equipment. Outdoor tracks with sand and deep fluff on top are really hard on all moving parts. I spend a lot of time cleaning my rig after each run on sandy loose dirt that gets into everything. Might be borderline OCD but it eats up time between races.
Thunder Trail is offline
Old 05-28-2014, 09:02 PM
  #46193
jwill05's Avatar
I had my truck sitting for a year and over that period of time the diffs leaked pretty bad granted they were probably a little leaky before then. Also I use an air compressor to clean my truck after each run which seems to help on wear and tear.
jwill05 is offline
Old 05-29-2014, 05:23 AM
  #46194
Originally Posted by Thunder Trail
Well, in that last line you posted why they are breaking You also run the post higher than you would with a short course body which is what they were designed for. The losi parts are tough. I have used the same body mounts for the life of several Losi trucks and never had a failure. I do have a suggestion. I have a older Ten T converted to electric. It has the body mounts that are very short on the shock tower so they don't ever break. That Ten T body looks more like a shrunken 1/8 scale truggy but I like it and the Ten t wing. You could swap to that body and the mounts to stop breakage. You might even be able to cut down that cool Chevy or GMC body to fit. Not cheap to swap bodies, but mounts are cheap and the Ten T body seems to last forever. With the Ten T body mounted low it flies better and is sealed to the chassis better keeping dirt out. I'm impressed with handling as well. With a good 550 motor is runs hard and turns lap times close to my Pro8 buggy. drives like a dream. Tires make a mean sound tearing around the track. I"m a racer and for me this is the ultimate racer's bash truck. That might not be what you wanted to hear, but I hope it helps in some way.
Yeah it might be higher than usual but i brake my rear post as well and that is pretty low. There is only one hole visible above the mount itself.
In the rear i snapped the post right off but in the front the post cracked in the little hole where the screw holding the plate which holds the body is.
I think the ten-t mount would be to low but i read somewhere that the slash 2wd body mount might work with a little modification so im gonna try that i break it again.
MrSvahn is offline
Old 05-29-2014, 01:08 PM
  #46195
dtr
dtr's Avatar
Make the body holes twice as long, that will absorb most chassis flex.
dtr is offline
Old 05-30-2014, 08:20 AM
  #46196
AtomicPunk's Avatar
Wow Thunder, thanks for the tips! I'll add your maintenance intervals to my maintenance schedule.
Simon
Old 05-30-2014, 08:23 AM
  #46197
AtomicPunk's Avatar
Thanks Will,
I also use an air compressor at 50-75psi to blow out my car after a few runs. I don't know if it's helping but it sure slows down the amount of dirt I drag into my shop!
Simon
Old 05-30-2014, 10:05 PM
  #46198
Anyone tell me overall length of steering links losi ten scte 1.0
mindnotme is offline
Old 05-31-2014, 03:20 AM
  #46199
AtomicPunk, in regards to adding extra bearings and the mods you were making. Just an FYI since you were looking to add additional bearing support. King Headz makes the front and rear center diff mounts that have dual bearings and support the outdrives getting rid of what wobble there is. They also make a chassis that removes a lot of the angle originally in the front center drive shaft as well. I have used their chassis and center diff mounts with dual bearings, and a few other things they make for about a year and a half now and they have performed very well. All of their parts are available at A-Main and most other larger places.
mpkent is offline
Old 06-01-2014, 01:17 AM
  #46200
Trader Rating: 48 (100%+)
I still have mine I want to do a 2.0 style layout on it and I will bring it back out at some point just don't really have the money for it currently I have rebuilt the front and center diff now I just need the rear and reinstall all parts on the chassis
NitroLuver is offline
