Like Tree9Likes
Old 03-17-2014, 02:40 AM
  #46021
Oztiger's Avatar
Default Help
Hi all, i drive an SCTE, 50-100 c 6000 mha lipos, 5.5 t sensored Turnigy 550 motor and a Tekin RX8. You can see pix of my local track at FB Page Murgon RC. (Australia). Temps around 30-36 celcius. Thats air temp not motor temp Punch is down to 70 percent. No timing on the motor and a 16 tp. It is wicked fast. Not too many cars can catch it.
I am melting soldered wires, gluing deans connector together? I am at my wits end to work out a way to lower temps, Esc never temps out, motor dosent lose power but everything is real hot. It is even making a few of my older lipos start to swell.
All comments considered, children please abstain i would like opinion from people who know what they are talking about.
Cheers
Oztiger is offline
Old 03-17-2014, 04:44 AM
  #46022
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I don't know a ton about the Turnigy motor but it seems like you are geared way too high. I don't run on any track that allows more than a 14 tooth pinion.
bds81175 is offline
Old 03-17-2014, 05:05 AM
  #46023
Errokk's Avatar
Cheers
The problem your experiencing is due to the deans not being able to handle the current demand of the motor and esc. Upgrade to ec5 or larger connectors which will have more contact surface and a tighter connection that won't cause them to heat up.
Errokk is offline
Old 03-17-2014, 05:23 AM
  #46024
I too beleive thats your issue. Ive got Deans in mine and they have come unsoldered numerous times. I thought that maybe I sucked at soldering but everything else I soldeer has no issues and looks good too. I sent other post elsewhere that folks have had with the deans and high current loads. I am going to go straight from the esc to battery this season so no more connectors for me.
freebird is offline
Old 03-17-2014, 06:47 AM
  #46025
Integra's Avatar
lol there's nothing wrong with deans. there's something else a miss here.
Integra is offline
Old 03-17-2014, 07:47 AM
  #46026
Casper's Avatar
Trader Rating: 34 (100%+)
Cheers
You running deals 2 pin ultra connectors? Those should be able to take the load. I ran those for years with no problem and really they should be as good or better then most birdcage connectors we run. Multiple test show these are about as close to a zero loss connector as you can get.
Is it always the connector joint melting or at the motor solder tabs as well?
Have you ever found out what temp the motor is at?
Deans can be a little hard to solder to. Make sure you pretin the deans posts and get a good solder joint.
4wd SC on 2S is the hardest thing you can do to a battery. The amp draw is near double that of a 2wd 10th scale car so everything is working VERY hard to push these cars around on what is actually low voltage for the size of car. I recommend not taking batteries down to LVC in 4wd SC (actually ever in any car) as this can damage cells if they fall out of balance or one cell is weaker then the other. IMO high quality cells are a must for this class but even then you risk damaging them as the sustained discharge rates are so high for this class.
Casper is offline
Old 03-17-2014, 11:17 AM
  #46027
Kaw1000's Avatar
Deans are rated for 60 amps but some say they are safe to 100 amp. I am unsure what these power systems pull amp wise, but seeing 150 amp esc for a truck I'm thinking amps over 100 in some trucks and cars.
Kaw1000 is offline
Old 03-17-2014, 12:03 PM
  #46028
Casper's Avatar
Continuous vs burst are very different ratings.
Deans claims (and again I have seen many articles confirm) they have the same restistance to 12 ga wires. all this assumes a good solder joint as well though.
http://www.wsdeans.com/products/plugs/ultra_plug.html
Casper is offline
Old 03-17-2014, 12:07 PM
  #46029
Kaw1000's Avatar
Good point thank you. BTW....what amps do these 4 cell setups pull for example a 1900 kv tekin on 4s?
Kaw1000 is offline
Old 03-17-2014, 12:21 PM
  #46030
Oztiger's Avatar
thanks for all the comments I do appreciate them.
However surely the Deans Ultra plugs are not the cause of the esc and motor getting extremely hot? Plus the soldered joints are not coming apart its the actual connector fusing together to the point they have to be pried apart with a flat blade.
The esc does not thermal shutdown in a 7 minute race and from memory the esc fan does not come on a lot.
Thanks for the comment re the batteries taking a pounding in these things. It makes sense that we are pushing equivalent to 1/8 Buggies around on 2s2p batteries.
I will also try a 13 tp with the Turnigy 5.5 and also with a Castle 4 Pole. (4600Kv I think).
Gotta say, used to race 1/8 gas then elec but 4x4 Sc Class is awesome. Maybe this car makes it awesome, love it.
Oztiger is offline
Old 03-17-2014, 12:26 PM
  #46031
Casper's Avatar
I use less mah on my 8th scale for the same length race then with my SCTE. The reason is you get you power from the voltage increase.
I know this will sound weird but if your batteries are not up to the task it can cause all sorts of issues with your electronics. Now causing your connectors to fuse have not heard of that one yet. I do know batteries with low amp output can hurt your electronics. I don't know the scientific reason as I am not an electrical engineer (I am a mechanical however) but I have been told by many people I trust know what they are talking about that this can cause all sorts of issues.
Casper is offline
Old 03-17-2014, 07:31 PM
  #46032
Kaw1000's Avatar
I want to replace my shocks as cosmetically they are nasty looking and one is stripped out. Is there any other options besides stock? I will use the metal shock caps that are on mine and metal shock collars. Going to rebuild with mip kit.
Kaw1000 is offline
Old 03-17-2014, 07:33 PM
  #46033
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
Tlr 2.0 shocks are what's on my scte
84 GT 5.0 is offline
Old 03-17-2014, 08:21 PM
  #46034
Kaw1000's Avatar
These?
http://www.ebay.com/itm/like/191096393994?lpid=82
Kaw1000 is offline
Old 03-17-2014, 09:39 PM
  #46035
84 GT 5.0's Avatar
No the shocks off the tlr scte 2.0
