Like Tree9Likes
Old 11-05-2013, 10:59 AM
  #45736
Casper's Avatar
Trader Rating: 34 (100%+)
I take the hole cover off and run the diff low so I used the short screws. If you like the Nitro hole cover then you would need the longer screws.
Casper is offline
Old 11-05-2013, 12:24 PM
  #45737
R/C Tech Elite Member
Darkgenerals's Avatar
Trader Rating: 73 (100%+)
Fair enough, even with my BCE chassis I still run the longer screws.
Darkgenerals is offline
Old 11-05-2013, 02:15 PM
  #45738
socal23's Avatar
Trader Rating: 112 (100%+)
I run the stock motor mount and stock diff standoff. I have the mip chassis so i orderd the shorter ones. They never gave me issues but the diff stand off broke and i am re building and freshening up the truck and just had a issue getting one out. Thanks all
socal23 is offline
Old 11-13-2013, 06:21 AM
  #45739
Default Clean Diffs?
I'm kind of new and i wanted to know the best way to clean the grease out of the diffs and when i do fill them with oil, how full should i fill them? I appreciate any help you can give me. Thank you!
mikeymac74 is offline
Old 11-13-2013, 06:42 AM
  #45740
rcgod's Avatar
Trader Rating: 33 (100%+)
Some guys use motor spray or mineral spirits. I just used a q tip. Make sure you take the oring out if you use a chemical as it can swell or damage it. Diff fluid to top of cross pins.
rcgod is offline
Old 11-13-2013, 07:42 AM
  #45741
really? top of the cross pins? I think I need to relook at how I do it. I've been filling it past cross pins, and putting the top diff gear in place and making sure the fluid is level with it.
Old 11-13-2013, 08:18 AM
  #45742
rcgod's Avatar
The problem is the fluid gets air in it and expands with heat so it can cause leaks. Usually forces out where the out drives are. I like to leave a little space and don't have any leakage issues. Especially with the updated diff cases.
rcgod is offline
Old 11-13-2013, 02:02 PM
  #45743
No this one on the losi site.
Yes. It will work great.
That link takes me to a blank setup sheet?
hendershot706 is offline
Old 11-13-2013, 05:24 PM
  #45744
There are some great videos on youtube about diff rebuilding. use a light weight shock oil to dilute the lube 10wt etc. rotate the assy to work it in, dump and repeat. work good, no contamination.
twolf is offline
Old 11-13-2013, 08:14 PM
  #45745
silveraider14's Avatar
anybody else having the problem with the king headz center pieces where if you tighten the bottom screws too much the driver terrain binds up?
silveraider14 is offline
Old 11-14-2013, 05:05 AM
  #45746
rcgod's Avatar
Are you sure your chassis isn't bent? What chassis do you have?
rcgod is offline
Old 11-15-2013, 09:28 PM
  #45747
its a king headz chassis. I have run it maybe twice with the chassis and it worked fine with the regular diff parts.
Old 11-16-2013, 02:46 AM
  #45748
rcgod's Avatar
Hard to say without looking at it. Can you take a pic and post it? Do the mounts sit flat on the chassis with no gaps and the holes line up before you put the screws in?
rcgod is offline
Old 11-16-2013, 09:05 AM
  #45749
It works fine when it is snug and not cranked down. All the holes line up correctly.
Old 11-16-2013, 09:33 AM
  #45750
rcgod's Avatar
Try taking out the outer bearings that support the outdrives and see if it still binds. If it does then it's probably the diff. Either the case is warped or outdrives are messed up. The stock mount allows some flex and misalignment so it won't show up there. There's a small chance that one of the kh parts are machined wrong but not likely. They are done on a CNC mill, so unless the part moved during the machining process it should be good. They don't do 100% inspection so it is possible.
rcgod is offline
