Like Tree9Likes
Old 09-15-2013, 05:06 PM
  #45646
eddomak's Avatar
Originally Posted by JMURACN
I just picked mine up... it was used and a good price. Looks like it has the TLR light weight chassis and some different battery tray. I know i dont have a ton of the bling parts yet, but its a project for me to learn the 4wd.
Looks like it has the TLR tuning kit as well (HA aluminium shock caps, HA aluminium threaded shock collars, one piece shock standoffs, aluminium hinge pin holders, carbon towers?, can't see if it has the aluminium rear hubs). You probably don't need much bling at all .
eddomak is offline
Old 09-15-2013, 05:17 PM
  #45647
It does have aluminum rear hubs.
The steering rack seems a little sloppy so im going to address that first. I want to get a complete screw kit and break down the chassis and clean it up
JMURACN is offline
Old 09-15-2013, 05:22 PM
  #45648
silveraider14's Avatar
anyone who has the kindheadz center diff package. mine was too tight and binging for some reason? I just loosened up the bottom screws and now its smooth but its a lot louder than the stock!
silveraider14 is offline
Old 09-15-2013, 06:31 PM
  #45649
tc5 man's Avatar
What do you guys do to stop the oversteering on the MIP conversion for the 1.0 it seems like the Rear end likes to come out of turns ? Im using the TLR towers on it . The Front end seems much lighter than the Rear end for sure also and it tends to catch me off guard and get twichy kind of.
Im coming from driving the typical 1.0 layout with the TLR flex chassis so this was the first time driving the MIP. One thing i notice is the MIP has a ton of corner speed and it does seemed to have more turn in.
So im thinking about trying 5,5,3 from 7k in the center diff and using 32w shock oil on the Front end some lead weights maybe on the Front end .
tc5 man is offline
Old 09-15-2013, 08:03 PM
  #45650
run 5,5,3 first before you add weight it should help with your problem
Old 09-15-2013, 08:13 PM
  #45651
tc5 man's Avatar
Ok what about doing 32w shock oil on the Front shocks insend of 30w ? Im running 3 hole pistons. Im thinking that doing 32w on the Front shocks will help to stop the twichyness and make the Front end more of a planted feel .
I run the truck outdoors with usually dry dirt. The 7k in the center diff worked good on the TLR flex chassis 1.0 . But that was a heavyer truck totally diffrent layout.
tc5 man is offline
Old 09-15-2013, 09:12 PM
  #45652
It couldnt hurt to try but I have never ran 3 hole pistions so im not much help there. Maybe make the roll center higher? Just to get some more weight transfer
Old 09-15-2013, 09:23 PM
  #45653
tc5 man's Avatar
Move the camber link on the front tower up ? I have it on the bottom hole on the tower with 1 degree camber .
tc5 man is offline
Old 09-15-2013, 09:25 PM
  #45654
I would do it to the rear and I think u get more role the lower you put the camber link someone correct me if im wrong. I always get confused with that
Old 09-15-2013, 09:32 PM
  #45655
tc5 man's Avatar
Wink
On the rear im not sure i know if i move that into the uppet hole il lose some rotation but it will be more stable on the rear end . But that many help a lot with the lose rear end .
Yea the roll center thing is confusing with all diffrent opinions .
tc5 man is offline
Old 09-15-2013, 09:39 PM
  #45656
Yeah I just kinda leave mine for the most part in the same spot right in the middle lol.
I rarly change setup anything on mine just a set of tires and maybe some more droop for outdoor
Old 09-15-2013, 09:42 PM
  #45657
tc5 man's Avatar
Yea im just likely doing 5k in the center diff and 32w in the front shocks.
tc5 man is offline
Old 09-15-2013, 09:51 PM
  #45658
That should help and I highly reccomend using the bypass1 pistions
Old 09-16-2013, 04:58 AM
  #45659
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Check out the tuning with camber links thread. That helps clarify the roll center adjustments. Going to a stiffer front oil will help keep the weight from transferring rapidly to the front end under braking coming into a corner. Decreasing droop in the rear will have a similar affect but I have never liked decreasing droop on my SCTE. It has just never felt right. If you are loosing the tail of the truck on corner exit (stepping out like a posi on snow), you could try even lighter rear oil too (2K).
bds81175 is offline
Old 09-16-2013, 05:00 AM
  #45660
Moderator
bds81175's Avatar
You could also try running a short camber link in the rear. Bringing the rear hubs up to the short wheel base position could help lock the rear end back in too.
bds81175 is offline
