Like Tree9Likes
Old 07-27-2013, 09:34 AM
  #45481
MarqueeRc's Avatar
Never seen or had an issue in my personal experience with the posts on this truck. Seen quite a few beat to heck without issue.
MarqueeRc is offline
Old 07-27-2013, 10:34 AM
  #45482
dtr
dtr's Avatar
Originally Posted by bds81175
Breaking posts?? How are people breaking posts?
Tha body is eating away the posts at the mount point, no matter how long the holes are.
dtr is offline
Old 07-27-2013, 12:54 PM
  #45483
chucko's Avatar
I had that problem because of the body flex. I ob longed the holes used a plastic washer re-drilled the holes so the clip didnt hit the scoop and they fit better and with the flex in the long holes it quit tearing up the body as much. also using a long aluminum brace helps stop the long flex JMO Hope this helps
chucko is offline
Old 07-27-2013, 09:33 PM
  #45484
tc5 man's Avatar
Is it me or does it seem like 5,7,3 with 7k in the center diff just works better than 5,5,3 setup even on Dry dirt on this truck ?
I gave 5k in the center a try while yes it makes it easier to drive i just cant get that forward drive out of the corners like 7k. Its just more torque and on power steering with 7k in the center diff.
Whats weird is i ran faster lap times with 5,7,3 than 5,5,3 .
I guess it depends on how much torque and KV you have on your motor.
tc5 man is offline
Old 07-27-2013, 09:37 PM
  #45485
tc5 man's Avatar
I cant say i ever broke the body post on this truck even with tumbles.
Even with the Flex chassis.
tc5 man is offline
Old 07-27-2013, 11:01 PM
  #45486
Casper's Avatar
Trader Rating: 34 (100%+)
I have broken a few body posts over the years but the mounts were improved a long time ago so it is not very common to my knowledge anymore.
As for diffs. Current dunford setup is 5-7-5. 7 in the center is no weird at all. With the old truck we used to run 5 in the center a lot of get that easy to drive feel. With the current truck we run 7 in the center lot as the new truck's chassis balance allow for more stability so we can run thicker center for more forward drive as you have noticed.
Casper is offline
Old 07-28-2013, 06:10 AM
  #45487
Thumbs up
Originally Posted by nanoverse
Drill a hole a little bit lower on the rod, do the same to the rear. Or use Durango Desc bodyposts in with minimal drilling in the front. They are super simple designed so that they virtually never break just cut a little bit of the length away if you don't want it sticking out that much.
Best mod ever to stop breaking posts. This is one part that should have gotten some extra R&D into it.
Thanks for the hint !
diltech is offline
Old 07-28-2013, 12:25 PM
  #45488
tc5 man's Avatar
Yea that makes sense im going back to 7 in the center diff again . It just seems like im faster with it than 5 in the center diff . I mean the 4600kv doesnt have a lot of torque so its not that hard to drive.
How about 2k in the rear diff ? Im figuring it would help with the dry dirt that northeast outdoor tracks have with grip .
tc5 man is offline
Old 07-29-2013, 05:53 PM
  #45489
big kid 37's Avatar
Any one running a Tekin SC4X 4.5 with the stock speed control that comes in the RTR kit. If so what are you running for gearing on med to large dirt track.
Thank You Ron
big kid 37 is offline
Old 07-30-2013, 03:45 AM
  #45490
Hi. What could it be? Running on the race and feel that the rear diffs is not running, only the front. Re-elected end diffs and saw that all is normal. Where is the problem?
Kilbatrosas is offline
Old 07-30-2013, 05:31 AM
  #45491
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Set screw came loose/ out on ur rear center drive shaft ?
BDRMBULLY is offline
Old 07-30-2013, 06:22 AM
  #45492
eddomak's Avatar
Alternatively the pin may have broken or come out of the dogbone. Same effect.
Check by:
1) Remove shell
2) Switch everything on
3) Putting the rear wheels on the ground whilst the front is off the ground. Hold the truck still.
4) Gently apply throttle
Does the centre to rear shaft still spin? If so, it is likely to be somewhere on the rear to centre driveshaft.
eddomak is offline
Old 07-30-2013, 06:30 AM
  #45493
Set screw on rear center drive shaft i think this? :
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-losi-scte-016.jpg
Old 07-30-2013, 06:53 AM
  #45494
eddomak's Avatar
Yes - that's the one.
eddomak is offline
Old 07-30-2013, 10:16 AM
  #45495
Casper's Avatar
Thank You Ron
14-15 should be the range for that motor.
Casper is offline
