Like Tree9Likes
Old 07-16-2013, 01:39 PM
  #45436
Amrcr's Avatar
Originally Posted by Casper
Only other reason I would see them breaking is the setscrew backing out and have to assume you are cleaning the threads and thread locking the set screw in place in the coupler.
Absolutely. Once I get it fixed you want to buy it
Amrcr is offline
Old 07-16-2013, 02:00 PM
  #45437
mxgregg's Avatar
Trader Rating: 32 (100%+)
Are you over tightening them and maybe cracking it by the hole?
mxgregg is offline
Old 07-16-2013, 08:02 PM
  #45438
Amrcr's Avatar
I had not thought of that and it makes sense because where the set screw goes into the pin is the thinest part and could put to much pressure on it there. Do I really need the set screw to hold them in since there is a retainer sleeve that covers the ends of the pin?
Amrcr is offline
Old 07-16-2013, 08:23 PM
  #45439
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Hmm , they did update that pin to add set screw long ago, i always preffered the original pin .yes the retainer holds it in for i while but its been known to fly out through the plastic retainer, others make an aluminum retainer. Then you can add pin if your choice with same measurments
BDRMBULLY is offline
Old 07-17-2013, 06:04 AM
  #45440
R/C Tech Elite Member
Darkgenerals's Avatar
Trader Rating: 72 (100%+)
I have some quick questions about a order I'm about to place. I'm getting the Losi scte rtr as a roller and I want to order stuff for reliability. Ive done alot of reading and see that the out drives are weak, and that the drive shafts especially the front are prone to wearing out really fast.
My plan is to order these things:
Tekno HD front driveshaft
Tekno HD rear driveshaft
HD lightened out drive set front and back
HD lightened Center out drive set.
TLR kit
Aluminum rear gearbox bearing insert set (not sure on this)
and a xtreme racing carbon fiber center diff top brace.
also any advice on the king heads center diff brace that uses 2 bearings instead of 1. Does this actually help the front front wearing out as fast?
Future upgrade plans are:
Losi tuned chasis
King heads extended rear brace
Losi front brace.
My plan for electronics are:
Tekin pro4 hd 3500kv
MMP with castle BEC
savox 1258TG servo
My main question do you guys that race these trucks think this is a good starting point for a durable and dependable race truck, or if you could order anything else or remove anything from my list what would you recommend?
I'm also asking where to start gearing wise, I plan to start with a 16 tooth pinion and check temps along the way.
Thank you in advance for any advice you may give.
Darkgenerals is offline
Old 07-17-2013, 09:11 AM
  #45441
blade329's Avatar
Trader Rating: 114 (100%+)
TLR kit
Losi tuned chasis
Losi front brace.
MMP with castle BEC
savox 1258TG servo
Sounds like you got it covered pretty well. I had most of the upgrades you have and it was pretty much bullet proof.
blade329 is offline
Old 07-17-2013, 09:15 AM
  #45442
mxgregg's Avatar
TLR kit
Sounds good. Go with the new BCE chassis with the 2.0 layout and you will be stylin!
Losi tuned chasis
Losi front brace.
MMP with castle BEC
savox 1258TG servo
Sounds good. Go with the new BCE chassis with the 2.0 layout and your truck will rip!
mxgregg is offline
Old 07-17-2013, 09:26 AM
  #45443
thanks for the input guys, I also plan to rebuild the diffs, would the HD diffs be a worth wile upgrade since Ill be in there? 8 bucks for better diffs sounds like a good deal, but if the stock ones are just as good I wont worry about it.
Old 07-17-2013, 10:30 AM
  #45444
Amrcr's Avatar
Are the tekno center shafts more durable? I have no problem fixing the stock ones but if the other hold up I would be willing to give it a try
Amrcr is offline
Old 07-17-2013, 10:33 AM
  #45445
tc5 man's Avatar
Yes they are for sure !
tc5 man is offline
Old 07-17-2013, 11:23 AM
  #45446
RiceP's Avatar
Trader Rating: 71 (100%+)
OMFreckingG so aggravated I only have a few days a month to race or practice with my work schedule. And for the past 2 months every time I can make the 1 hr drive to the closest track it rains like today rain out. Seriously thinking of selling all my Rc stuff.
RiceP is offline
Old 07-17-2013, 01:23 PM
  #45447
Casper's Avatar
Trader Rating: 34 (100%+)
TLR kit
Losi tuned chasis
Losi front brace.
MMP with castle BEC
savox 1258TG servo
Get a 2.0! With all the stuff you are getting to "hop up" an RTR why not just get the SCTE 2.0 that already has the majority of that stuff already on it! A lot of the stuff on that list is not needed IMO but others will disagree and that is fine.
Casper is offline
Old 07-17-2013, 01:26 PM
  #45448
tc5 man's Avatar
All you need really for this truck is the HD diff cups , Lighten outdrives all around especially the center diff , Carbon towers Front and Rear. And a diffrent chassis after you bend the stock chassis which you will evently.
The other things like a better center Front axle you only need one when the stock part is shot. The King Headz center diff mount is to stop the wobble in the center diff and yea it will help with wear is it a must. Not really with the HD diff cups it takes a good amount out of it.
tc5 man is offline
Old 07-17-2013, 01:36 PM
  #45449
I would, but I traded another truck for a RTR, So I'm happily stuck with a RTR.
TC5 man -
I was thinking of dropping off bearing inserts, the carbon top brace and getting the HD diff cups. Dropping off the bearing inserts and cabon top brace free's some up to buy new tires. Extra tires are always welcome.
is the HD diff cup the same front middle and back?
Old 07-17-2013, 02:19 PM
  #45450
tc5 man's Avatar
TC5 man -
Yea the Alum bearing inserts to me never seemed a must ive used the plastic ones on the Rear for a long time never a stripped diff or anything. I dont know anybody who i race with that uses them on the 1.0 at least.
Its up to you really . The Carbon brace for the stock chassis hum yea i would get that actually if you want to stop it from bending.
Yup the HD cups Front, Center, Rear are all the same.
tc5 man is offline
