Like Tree9Likes
Old 07-14-2013, 05:35 AM
  #45421
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Decrease the kick up in front, drop the front ball stud, and run the short Ackerman arm. You will be amazed....
bds81175 is offline
Old 07-14-2013, 08:39 AM
  #45422
chucko's Avatar
Originally Posted by tc5 man View Post
Ok thanks . I may try out the inside hole on the Losi servo arm since i got my servo centered straighter. They may help a lot with turn in into the corner i tried out with the battery Forward but it was to much steering and it nose drived more so i had the battery in the Center .
Heres the setup i have now . Front Camber 1 in a half , Rear 1 degree, stock Front and Rear sway bars, Front shock in the middle hole on the tower and the (bottom in the middle hole had it in the outside) But turned to wide. Camber link into the Upper hole on Front tower, 32 half weight in the Front shocks. 24mm ride height Front, Full droop.
Tires up Front Soft Holeshots which i think are ethier not giving or to slideing to much it seems.
Rear shocks in the middle hole on tower, bottom arm into the middle hole, camber link into the bottom hole. 24mm ride height , 32 half shock oil, Camber 1 degree Full droop.
SS Double Dees tires on Rear which actually helped for sure .
I run this Truck outdoors also so my setup changes.
try lighter oil in the front diff. everything else seams OK. Keep notes do one thing at a time.. you would be amassed at how oils in shocks affect turning.
chucko is offline
Old 07-14-2013, 09:39 AM
  #45423
tc5 man's Avatar
Oh ok well im using 5,7,3 diff oil. So i guess its better to use 5 in the center than 7 on carpet ?
Im using 32 w in the shocks because i run it outdoors and its hotter outside .
tc5 man is offline
Old 07-14-2013, 11:12 AM
  #45424
Default Steering Servo?
Was running a JR sport digital high torque, what servo is the best for my scte?
Rich68 is offline
Old 07-14-2013, 12:11 PM
  #45425
chucko's Avatar
the hotter it gets. go up in oil's' I think its 12 w per 25 deg.
go 3 5 3 in your diffs.
chucko is offline
Old 07-14-2013, 08:12 PM
  #45426
Moderator
bds81175's Avatar
Not sure there is a hard set rule but I can't stand anything much slower than 0.1 and I think you need somewhere north of 150 oz of torque. I'm currently using a Savox 1258 and it kicks butt. I've seen a Savox 1257 in one but the extra 0.01 seconds transit time doesn't seem worth the drop off in torque.
bds81175 is offline
Old 07-14-2013, 08:32 PM
  #45427
tc5 man's Avatar
Yea first im going to try out new tires up Front like the Pressure Point tires in ethier a clay or Soft compound i have some . Than if that does not work il try out the ball down on the Steering turnbuckles. I may try out the Short ackerman again i mean if it is to much il just set the shock positions diffrent.
But i may try the inside hole on the Losi servo arm first i did have issues with it hitting the side of the servo before but my servo is cented much better now.
I need to buy them adjustable suspension blocks to change the kick up on the Front but that makes sense.
One of the fast guys with a 2.0 uses 5,5,3 in his diffs on carpet so maybe il try out 5k again but im doing them first things first though.
All i know is im tried of the pushing out of them kind of turns and getting passed lol.
I tried out a guy i race with MIP 1.0 and it handled and turned really good on a tight Carpet indoor track. My truck handles and turns fine outdoors.
tc5 man is offline
Old 07-15-2013, 10:18 AM
  #45428
mxgregg's Avatar
Trader Rating: 32 (100%+)
BCE H-1 chassis has been testing great and should be in production soon. If you want the ultimate Losi 1.0 this is the chassis to get. Contact bcespeed.com for more info.
mxgregg is offline
Old 07-15-2013, 04:37 PM
  #45429
Rustynuts's Avatar
Trader Rating: 19 (100%+)
Does anybody know if the Reedy 1515sl 2000kv motor will fit the scte?
Rustynuts is offline
Old 07-15-2013, 11:23 PM
  #45430
Trader Rating: 46 (100%+)
when doing this does the front driveshaft become the rear and the rear become the front?
NitroLuver is offline
Old 07-16-2013, 05:35 AM
  #45431
mxgregg's Avatar
Yes just like the new 2.0 truck.
mxgregg is offline
Old 07-16-2013, 07:40 AM
  #45432
chucko's Avatar
what else besides battery hold downs. ? would the Chris Attaberry battery holder work ? Do you need spacers for the center diff. ? and what would come with the purchase. ? just the chassis ? Thanks
chucko is offline
Old 07-16-2013, 07:51 AM
  #45433
mxgregg's Avatar
All you need is the 2.0 battery hold down parts for about $10. All other parts work from the 1.0. No shims or other parts needed. I guess you could use the APE tray but you would have to drill holes and it will add weight and also raise the center of gravity.
mxgregg is offline
Old 07-16-2013, 12:12 PM
  #45434
Amrcr's Avatar
Due to not wanting to look through 3000+ pages I must ask. What can I do to improve/ keep from breaking the pins in the drive shafts on the front and rear center drives shafts. Is there an upgrade that holds up?
Amrcr is offline
Old 07-16-2013, 12:17 PM
  #45435
Casper's Avatar
Trader Rating: 34 (100%+)
How many have you broken? I have broke a few front pins over the years but not sure I have ever gone through a rear one.
Are you using the updated version with the set screw through the coupler?
Casper is offline
