Like Tree9Likes
Old 04-29-2013, 10:38 AM
  #44716
P6
i use mystik hi temp no2 its been working for me for everything from bearings to gears ive been using it for over 10 years when i was riding bmx and bought my first rc
P6 is offline
Old 04-29-2013, 02:05 PM
  #44717
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
A pro driver told me he puts a few drops of thick shock oil on the ring n pinion gears
BDRMBULLY is offline
Old 04-29-2013, 02:38 PM
  #44718
silveraider14's Avatar
I just got my ape battery tray in the mail. the instructions aren't very good so how do I install it? is there I can mount it where the esc is infront of the battery like the 2.0?
silveraider14 is offline
Old 04-29-2013, 02:53 PM
  #44719
I am rebuilding my diffs with the HD diffs and I ran into an issue where I reinstalled the center diff and it will spin smooth except for you get to a portion of about 2cm in the turn where it's harder to spin. I checked to see if the portion is touching the chassis or if the screw is rubbing but don't see anything like that.
gus6464 is offline
Old 04-29-2013, 03:13 PM
  #44720
BDRMBULLY's Avatar
Open it back up n make sure the square blocks are seated all the way down and throw out the small washers
Old 04-29-2013, 03:37 PM
  #44721
chucko's Avatar
glue the small little o spacers to the chassis. glue is dry, now put screws in battery holders each (2) of them at a angle so when the battery tray is bolted to chassis with the little o ring things it misses the center drive assembly depending on weather the speed control is front or back. it goes either way but the little angle pieces have to be turned to your installation.
chucko is offline
Old 04-29-2013, 03:52 PM
  #44722
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
*SIGH*
First off, if you have a question about how to install it email me. I don't frequent this forum that often anymore. I just happened to see your post.
Second, I get a question about once a week on flipping the tray. There is ZERO advantage to that. I've tested it both ways.
Third, there is a 2 page installation sheet included with the tray. There are also 5 pictures of it installed on the web site if you need a clearer picture.
Chris
ChrisAttebery is offline
Old 04-29-2013, 04:04 PM
  #44723
thanks guys ! and really there is no advantage?
Old 04-30-2013, 01:40 PM
  #44724
JourneyMan's Avatar
Trader Rating: 91 (100%+)
Just received some Avid sabertooth wheels from Amain and am extremely disappointed with the quality. I have looked for a review everywhere, so I started this post to know your experiences with them.
My first take... very thin plastic and lots of flex. Compare these to the DE wheels on my light 2WD SC, which are rock solid... These seem like they would flex/bend with my heavy Ten-SCTE just sitting on the bench. I could not imagine how they could possibly hold up on large tracks.
They have some cool features, such as the grooves for the serrated lock nuts... but the plastic feels cheaper than a New Bright.
Here is a link...
http://www.amainhobbies.com/product_...ack-2-TEN-SCTE
JourneyMan is offline
Old 04-30-2013, 01:53 PM
  #44725
R/C Tech Elite Member
blade329's Avatar
Trader Rating: 114 (100%+)
Originally Posted by JourneyMan
Just received some Avid sabertooth wheels from Amain and am extremely disappointed with the quality. I have looked for a review everywhere, so I started this thread to know your experiences with them.
Here is a link...
I like these wheels. While I have only used them on indoor tracks, they seem to hold up pretty well. Probably the best looking wheels I have seen for this truck.
blade329 is offline
Old 04-30-2013, 03:06 PM
  #44726
tc5 man's Avatar
I been running them Avid rims for a while they hold up pretty good on large outdoor tracks and Indoor on the SCTE in there very light. Yea i agree they do look kind of cheap looking though but i like the look of them though.
I had the hex on one of them eat up the hex not strip nessasary and my wheel fell off during a race it might of been my fault though but it can be fixed.
The Flex is not bad really not sure where your getting that from.
Might take a look at them DE dish wheels so my truck is cleaner thats the downside of the spokes is everything goes though them dirt/rocks.
tc5 man is offline
Old 04-30-2013, 04:05 PM
  #44727
Casper's Avatar
Trader Rating: 34 (100%+)
Shock oil is not a lubricant. I would not recommend this for the ring and pinion. Either the TLR black grease or maybe the marine grease or some other type of gear grease.
Casper is offline
Old 04-30-2013, 06:04 PM
  #44728
BDRMBULLY's Avatar
Perhaps ur right it may have been his advice for the 22 gear box, my bad as they are plastic gears, works great
Old 04-30-2013, 06:20 PM
  #44729
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
I like the AVID wheels also , I thought the DE wheels flexed more than the AVIDs .....
BashemSmashem is offline
Old 04-30-2013, 08:52 PM
  #44730
rcus3r's Avatar
Avid are my favorite wheels so far. Tried few of them - proline, aka, jconcept, de, de dish.
I too was sceptical when I got them. They are very flexible, which, suprisingly does not impact my driving style. Probably the lighest of the wheels, and they have been very durable for me. They have stayed true the longest out of all the wheels I tried. Also, I run my truck heavy.
The DE Borrego were my least favorite. Two of the four warped more and easier than the others, and are heavy.
Stock Losi, second favorite.
rcus3r is offline
