Like Tree9Likes
Old 04-04-2013, 06:35 PM
  #44476
RiceP's Avatar
Trader Rating: 71 (100%+)
Hey does anyone know the cheapest place to order the proline flow tek body on Internet need new one for my scte thanks
RiceP is offline
Old 04-04-2013, 06:58 PM
  #44477
chucko's Avatar
Pro line
a main
but I here the new ford is doing really well with balance and looks
chucko is offline
Old 04-04-2013, 07:23 PM
  #44478
Brazman's Avatar
You should try the TLR body..it's quite nice.
Brazman is offline
Old 04-04-2013, 07:34 PM
  #44479
Feint Motion's Avatar
Trader Rating: 24 (96%+)
I was thinking about upgrading to the 2.0 but my 1.0 is so dialed.
Feint Motion is offline
Old 04-04-2013, 11:40 PM
  #44480
Brazman's Avatar
I thought my 1.0 was dialed too until I built the 2.0
Brazman is offline
Old 04-05-2013, 10:40 AM
  #44481
JourneyMan's Avatar
Trader Rating: 91 (100%+)
Thank guys, did not know I could run the ape with my guards. I will pick one up then. So has anyone else had issues running without sideguards... I see so many with the "shaved" guards on rctech but NEVER at the track.
Here is a perfect example:
Still drolling over this truck! Look at those RPM goodies mhmm.
JourneyMan is offline
Old 04-05-2013, 05:36 PM
  #44482
mojo 309's Avatar
I know at different tracks and condussion not all tires will work at any given time lot depends on weather if its cool warm or hot outside if the track is dry slick dusty rought or smooth or if its watered alot durning the race day or watered only alittle.Certain tires might work really well starting out but wont as well as the day gets hotter,so my question is from the list of tires below
aka cityblocks soft
aka enduros soft
jconcepts goose bumps soft
jconcepts subcultures soft
proline calibers med
proline bow tie soft
proline bow frighter soft
What tires work well on a hard packed dry slick dusty track that is large in size and gets watered durning the race day but drys out fairly quick between rounds.If there are better type tires for what i am asking about please post what they are and how they work for you i know its all a matter of opinion but i would like to know Thank you
mojo 309 is offline
Old 04-06-2013, 06:41 AM
  #44483
Jake C6R's Avatar
aka cityblocks soft
aka enduros soft
I would try the cityblocks or calibers (soft) for those conditions, out of your list I have had the best luck with those. The enduros will last longer but will not grip as well IMO.
Jake C6R is offline
Old 04-06-2013, 02:51 PM
  #44484
platgof's Avatar
Spent most of the day rebuilding all the diffs. What a messy job!! I also installed the Tekno driveshafts and a full set of bearings, while I was in there. I guess the first time it takes longer than the next time. I also found out how to keep the diffs from binding. When they started binding, I would back off till I could freely turn it again, then tighten it from there. It worked for the most part. Really pleased with the way things turned out. I also installed a full rear bumper. I bought a roller, that is why all the work involved.
platgof is offline
Old 04-06-2013, 04:43 PM
  #44485
mojo 309's Avatar
Does any one use a combo heatsink/ cooling fan on their scte if so how is it working out for you and does it really help keep the temps down on the motor? As for the fan it self who makes a fan with a long enough wire to get from the motor to where it will plug in at and does it plug into the receiver or the esc and i suppose you would have to use some sort of a spliter to make it work.
mojo 309 is offline
Old 04-06-2013, 07:12 PM
  #44486
Integra's Avatar
A quality heatsink is all you need imo, Fans Fail quite frequently in Offroad.
this is what i run on my Pro4
http://www.amainhobbies.com/product_...Heatsink-Black
Integra is offline
Old 04-06-2013, 07:23 PM
  #44487
Do you use any thermal paste? Or just clip it on?
65BAJA is offline
Old 04-06-2013, 07:43 PM
  #44488
P6
Last year I liked blockades on out dusty outdoor at leisure hours this year I'm gonna try a softer panther boa I feel with the thickness of dust and once the line forms I would like them a lot better but I heard their changing dirt, it was rocky dry clay hardpack so if you Jove dive I broke up like pavment in nice big chunchs and ill probably have new calibers in soft compound as backup untill everyone figures out what's working best they seem like they would dig through the dust but have trouble once the line got formed
P6 is offline
Old 04-07-2013, 07:14 AM
  #44489
Integra's Avatar
No paste over here, I got a couple tube's but cant find any reason I HAVE to run it. My motor temps Never get above 160-170 after a Hard run.
Integra is offline
Old 04-07-2013, 08:18 AM
  #44490
chucko's Avatar
Default cooling fan
I have been using this for a yr with the same fan.
http://www.ebay.com/itm/RC-Car-Alumi...item2a228a0401
Keeps the temps down to 110 from 150 to 190 now I dont worry about heat
chucko is offline
