Like Tree9Likes
Old 03-19-2013, 09:18 AM
  #44356
weavty1's Avatar
Originally Posted by Casper View Post
That is over 100 runs. But even with that that wear does seem to be a little more then I would expect based on my personal experience, but... Looks like you run in a place were it is muddy and the dirt in the outdrives will accelerate wear. The dirt will act like sand paper. I am guessing these are the rears. How do the fronts look? The rears will wear faster then the fronts typcially. As others have pointed out the drive shaft pins are worn as well. A worn pin will slap the outdrives and accelerate wear as well. Did you replace the drive shafts when you upgraded to HD outdrives or were the pins already worn when you put the HD outdrives in.
With 100-130 runs on them I am not sure there is much customer service would do for you as that is quite a lot of runtime. Lets put this in perspective. Lets say you averaged 15mph and 10 min a battery at 100 runs you would have put around 250 miles on this truck! I would put new HD outdrives in as well as repalce the bones.
http://www.losi.com/Products/Feature...rodId=LOSB3564
Check the axles though as well. There are two sets of holes in the axle for the cross pin so if one is worn switch to the other to make your axles last longer.
It's not just the pins, Casper.. LOL, look at his bone!! It's bent... Well there's your problem!
weavty1 is offline
Old 03-19-2013, 09:31 AM
  #44357
huzzler's Avatar
Originally Posted by losi007 View Post
What is the Total bearing count for the scte losi i get 22 but kits have 22 and 24?
Avids come with 22 bearings.
http://www.avidrc.com/flexkit/?kit=327&kitname=TEN-SCTE
huzzler is offline
Old 03-19-2013, 03:04 PM
  #44358
Brazman's Avatar
If I had a dollar for every time I have heard that
Brazman is offline
Old 03-19-2013, 03:32 PM
  #44359
mojo 309's Avatar
By any chance is there some sort of tire reference guide that shows what tire is best for different track condissions when racing a 4x4 sc truck?.With all the different types of tires that are made for a sc truck and the testing that is done when a new tire comes on the market it would seem like there would be stats that show what tire works best for differents types of tracks. Chances are it most likly comes down to personal preferance.
mojo 309 is offline
Old 03-19-2013, 04:08 PM
  #44360
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Originally Posted by BashemSmashem View Post
Actually , I bet he is still running the old diff housings and the wobble from the outdrives caused the outdrive to wear like that . With the new diff housings I bet the rate of wear on the diff outdrives goes down a lot ....
That drive pin doesn't look that bad IMO , but weavty1 is correct you don't wanna use really worn pins as they will gouge out the outdrive pretty quick .
When I built this truck, I junked the diffs, and rebuilt them all with the HD Cases, and HD outdrives so thats not the issue. The dogbones were brand new. I bought the kit, w/ a HD driveline.
My dog bone isn't bent, its the angle of the picture.
Feint Motion is offline
Old 03-19-2013, 04:14 PM
  #44361
I run on a rather large outdoor track, with a bit of mud from time to time. I figured that had to play a role. These are indeed the rears. My front and centers aren't bad at all. No wear. I guess I needed to factor in, that I run on a more rough track.
I brought the truck new, Meaning it had new dog bones when I installed the HD Cases, HD Outdrives. My axles/Dogbones are fine.
I already ordered some Tekno stuff, going to give those a try.
Thanks for the help.
Old 03-19-2013, 04:18 PM
  #44362
Casper's Avatar
Trader Rating: 34 (100%+)
What track you running at?
Casper is offline
Old 03-19-2013, 04:25 PM
  #44363
Pellogt's Avatar
Trader Rating: 47 (100%+)
Hi guys... can somebody help me with this:
http://www.rctech.net/forum/electric...ount-help.html
Pellogt is offline
Old 03-19-2013, 04:49 PM
  #44364
Glen Helen RC raceway, Rev, and Thunder Alley.
Old 03-19-2013, 04:54 PM
  #44365
Casper's Avatar
Those are three big tracks for sure.
Casper is offline
Old 03-19-2013, 05:04 PM
  #44366
mojo 309's Avatar
The spacer goes in between the two bearings reason being is that both bearing turn at different rpm's in different dirctions its not good to have the two bearings touching each other..If you have noticed the with stock motormount and front up right with the single bearing there was about a 1/16 of a inch play in the stock mounts with the dual bearing the play is gone which means your drive shafts will turn much more truer. Hope this helps and ask questions if there is something your not sure about most people on here are willing to help.
mojo 309 is offline
Old 03-19-2013, 06:35 PM
  #44367
Pellogt's Avatar
thanks for the help my friend.
on the right side if you look i put something it came on the kit , some sort of a washer or insert... is that ok? and on the left the bearing is sticking out is that ok? if i try to move the left tower is very weak (maybe because i have to put the top brace) I forgot to buy the top brace , i just order the part.
Pellogt is offline
Old 03-19-2013, 07:31 PM
  #44368
mojo 309's Avatar
Your talking about the thin shim part#losb 3570 i dont even bother using those on my scte. Never had a problem with it not being there.As far as that goes its not even listed on the replacement parts list page in the ten scte manual.
mojo 309 is offline
Old 03-19-2013, 07:43 PM
  #44369
Pellogt's Avatar
ok, i was little confused... so throw away the whaser (thin one)
thanks a lot!!
pd. other guy said on the left is not sitting flat (bearing) maybe i have to pushed a little bit more.
thanks
Pellogt is offline
Old 03-20-2013, 08:04 AM
  #44370
Trader Rating: 160 (100%+)
What batteries does everyone have good luck with? I have been running a couple NanoTechs 6600 with my Novak Havoc Pro SC and 4.5 550. At the end of a 10 minute run they are always puffed a bit. I just ordered a Hobbywing 4000kv combo and wanted to get a couple new batteries. Not sure if the puffing is because of the batteries or the Novac system.
Chris Gierse is offline
