Like Tree9Likes
Old 03-03-2013, 03:57 AM
  #44146
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
The Pro4 is a 540 motor....
BashemSmashem is offline
Old 03-03-2013, 04:51 AM
  #44147
drepus's Avatar
Originally Posted by mojo 309
This might sound like a stupid question but is there suppose to be spacers on the bottom of the front center diff mount and on the motor mount so that there is space between the spur gear and the stock chasse? reason i am asking i picked up a used scte and for some reason the center diff was mounted backwords so i turned it back to the way it suppose to be and now the spur gear hits the chasse and the spur gear is not over the cut out in the chasse the manual says nothing about any spacers between the two mounts
http://losi.com/Products/Features.aspx?ProdId=LOSB2412
Yes there is normally a spacer used under the center diff,losb2412. Some folks have modded their trucks (myself included) and eliminated this spacer to lower the diff and motor. The goal was a lower cg. You can search this thread to see how but the gains are small.
drepus is offline
Old 03-03-2013, 05:24 AM
  #44148
jayhawknavy02's Avatar
Originally Posted by rcus3r
Those Mugen o-rings did not work for me. Saw a reference to them here a while back.
I have rebuilt many diffs (not as many as you), and had them to a point where they would not leak. Then I tried the Mugen o-rings. Built the diffs with my proven method Put 4 full days through them. They leaked almost as bad as the unglued diffs. Rebuilt them with stock o-rings, and many packs later they are still dry.
I had the same experience. Stock o-rings are better. I rebuilt 2 of 3 with Mugen and 1 without. The stock diff retained the most diff fluid.
jayhawknavy02 is offline
Old 03-03-2013, 08:22 AM
  #44149
platgof's Avatar
Originally Posted by mxgregg
I only had to drill 4 holes. 3 for the diff mount and 1more for the battery. I used existing holes for the rest.
Any chance you have some drilling specs for the layout? I am very interested in this mod for my new truck!
platgof is offline
Old 03-03-2013, 08:36 AM
  #44150
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
One of the guys at our track used the rear holes for the front out drive support and then just marked off the rear holes from there. I saw the chassis and it looked like it should work but don't hold me responsible for swiss-cheesiness or lousy drive shaft alignment. I'm not even sure why this change in layout helps. What's the thought process here? More weight to the rear seems to make a truck that already doesn't steer that well steer even less doesn't it? Or am I the only one struggling to get steering (that could very well be the case). Just put in the short Ackerman bar last week and that helped a ton.
bds81175 is offline
Old 03-03-2013, 08:52 AM
  #44151
tc5 man's Avatar
What size cap head screw do you guys use in the motor mount on the top hole ? The top motor mount screw is tight but it moves from flex im guessing.
Im getting sick of the gear mesh moving after race.
tc5 man is offline
Old 03-03-2013, 09:06 AM
  #44152
Casper's Avatar
Trader Rating: 34 (100%+)
Remember you have to either have an aftermarket chassis like the TLR tuned flex chassis or dremel/machine the chassis under the spur for clearance if you take the chassis spacer out to lower the diff.
I use one of these!
http://losi.com/Products/Features.aspx?ProdId=LOSA6240
Casper is offline
Old 03-03-2013, 10:55 AM
  #44153
mxgregg's Avatar
Trader Rating: 32 (100%+)
I will post up how i made the mod. I did use one of the existing back holes for a front hole..
mxgregg is offline
Old 03-03-2013, 01:16 PM
  #44154
mojo 309's Avatar
I use one of these!
How good is the TRL 4000 flex tuned lightened chassis compaired to the other after market chassis on the market?
I have seen jammin, king headz, mip, tlr,on the web. whats the difference's between all the chassis? and which works the best and offers more bang for the buck.
mojo 309 is offline
Old 03-03-2013, 01:33 PM
  #44155
tc5 man's Avatar
Well best bang for the buck would be the Jammin chassis i heard it lowers the gravity on the center diff and its light. Im thinking about getting it.
I dont know about the Losi Flex chassis but the King headz chassis straightens the center diff out and makes the gear mesh not at a angle. But any of the chassis will make the truck lighter .
Casper: Oh thank you i been looking for a screw like that !
tc5 man is offline
Old 03-03-2013, 03:49 PM
  #44156
tc5 man's Avatar
Guys racing this truck on carpet have you ever tried a alum chassis brace Front and Rear or just the Rear end ? Or the RC8B rear chassis brace in plastic or Alum on carpet ? Im not hurting for grip so.
This is on the stock chassis.
tc5 man is offline
Old 03-03-2013, 04:05 PM
  #44157
mojo 309's Avatar
I use one of these!
So casper your saying with the TLR tuned flex chassis #TLR4000 you dont need to have the chassis spacer under the center diff mounts to have clearence between the spur gear and chassis? And is there other advantages to having the tuned flex chassie besides the lower LCG on the center diff and the lower wight over all for the Losi tenscte 1.0. Thanks
mojo 309 is offline
Old 03-03-2013, 05:05 PM
  #44158
Casper's Avatar
Yes it does all those things. Also allows you to run the TLR rear torque rod which gives better rear front to back stiffness but allow more side to side flex for more rear traction.
Casper is offline
Old 03-03-2013, 05:17 PM
  #44159
tc5 man's Avatar
Anybody ?
tc5 man is offline
Old 03-03-2013, 05:18 PM
  #44160
MRANTITRAXXAS's Avatar
I love my TLR chassis. I can't imagine another brand taking the abuse it does.
MRANTITRAXXAS is offline
