Like Tree9Likes
Old 02-23-2013, 01:19 AM
  #44011
MRANTITRAXXAS's Avatar
Originally Posted by BlackStarRacing View Post
off track a bit.... but anyone using a good power drill? if so what brand.... thanks
Makita with Lithium Ion battery
MRANTITRAXXAS is offline
Old 02-23-2013, 02:27 AM
  #44012
eddomak's Avatar
Originally Posted by Losi Junkie View Post
I heard 4 WD are MUCH tougher to maintenance, is this true?
I would say that the difficulty level is around the same, but there's just more to maintain. So 2 more diffs (since this the SCTE forum), and 3-4 more driveshafts (centre, 2x front). In the end, it's really only the diffs that take time to get to and change fluids...
Having said that, there is also the fact that one change in the drivetrain can now affect other parts of the drivetrain, so you could potentially need to think of more things when doing changes to achieve the desired effect.
If I think about it another way, then I wonder if 4WD is built tougher than 2WD, and so less likely to break and need maintenance that way? Certainly the SCTE is mega tough...
Anyway, hope the maintenance doesn't put you off the SCTE - it's an awesome truck and you don't need to do all that much to keep it running.
eddomak is offline
Old 02-23-2013, 05:08 AM
  #44013
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Don't worry about the maintenance too much on this truck. I've had mine a month and have torn it down to the chassis a couple times with no issues. The Team Associated SC10 4x4 is a nightmare to maintain compared to this truck.
Guys, I'm getting beat in the corners by the stinkin' Tekno's. I need more steering. For our main last night, I sauced the front tires only (I know, it was stupid) and I had the steering that I wanted but all the other things I did to the truck to loosen up the rear end came back to bite me (wild oversteer). Any one have suggestions for how to get more steering on a track with a lot of 180's? I've already got the thinnest sway bar in front, a light spring, a low roll center, battery forward, and a partridge in a pear tree. Do I really need to sauce the fronts and not the backs and just try to get the rear end back to planted again?
bds81175 is offline
Old 02-23-2013, 05:31 AM
  #44014
caguilar4's Avatar
I actually removed any front swaybar to get me more steering. I also had to lower my ride height 1mm all around to prevent the truck from traction rolling (you could also change droop and/or downstops to achieve the same effect)
caguilar4 is offline
Old 02-23-2013, 06:06 AM
  #44015
drepus's Avatar
if the rear end is too stuck it can overpower the front end and cause push. i will ofter try a little less rear toe in to free the back up.
Taking the front sway bar off will belp in low speed off power situations but you will lose some on power steering in long sweepers etc.
Are you running the lower holes on the front upper link? If not that belps a bit too.
Some more negative camber in the front tires only, -1.5-2 degrees should help.
drepus is offline
Old 02-23-2013, 08:44 AM
  #44016
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Thanks for the info i was looking at one from them online!
BlackStarRacing is offline
Old 02-23-2013, 11:45 AM
  #44017
BmainStar's Avatar
Ditch the front sway bar,go to the short Ackerman plate,also run more toe out.Put the battery back it will cause more weight up front which =push.Lower ride ht.Always sauce front and rear with 4x4 the same.Run shocks middle on tower out on arms.Do not run too heavy of a shock fluid.Cheers!
BmainStar is offline
Old 02-23-2013, 12:19 PM
  #44018
TCCustoms's Avatar
Here ya go...I have one just like it and love it, even if the screw is too tight(like a bolt or not on a real fullsize car) if you pull the trigger and the bolt is stuck, if you turn it, it locks and wont twist backwards, very bad @ss drill
http://www.ebay.com/itm/SNAP-ON-CTS5...786160&vxp=mtr
TCCustoms is offline
Old 02-23-2013, 03:38 PM
  #44019
JPKinsella's Avatar
Trader Rating: 30 (100%+)
Hey just out of curiosity what are your trucks weighing in at???? I am at 5 pounds 7.5oz no body with tires...........
JPKinsella is offline
Old 02-23-2013, 04:10 PM
  #44020
Haha101's Avatar
Hey Guys, Complete noob here so be aware! Anyways, Im still learning too drive and i have losi Ten scte still learning how too setup the truck and thats why im here... i have no idea what anything does too the driving characteristics of the truck so if anyone has a good resource for that it would be awesome. my current setup is 5/5/3 with 32.5 wt in the shocks with a pro4 4600 and rx8. If anyone has some speed controller settings that are good too start with it would be helpful.. If anyone has any advice on what i should do too tweak my setup that would be great. Here is the track i race at for reference also my first race.. mine was the Blue and silver truck. Thanks and sorry for the word wall
edit it seems i can not post the youtube link.... so if you want too view the video add this too your youtube link watch?v=fbGyhCT5zpM
Haha101 is offline
Old 02-23-2013, 09:13 PM
  #44021
Get the Chris atteberry battery tray.Slide it back as far as possible.Run the short ackerman and move your shocks in to the middle hole on the front arms.
Losi57 is offline
Old 02-23-2013, 09:56 PM
  #44022
Casper's Avatar
Trader Rating: 34 (100%+)
http://www.teamtekin.com/hotwire/ESC...up-sheets.html
Casper is offline
Old 02-23-2013, 10:02 PM
  #44023
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
http://jq-products.com/the-news/43-t.../160-the-guide
RC*PHREAK is offline
Old 02-23-2013, 10:44 PM
  #44024
Haha101's Avatar
Looks like ive got some reading too do thanks guys!
Haha101 is offline
Old 02-23-2013, 11:03 PM
  #44025
tc5 man's Avatar
Well i raced the truck today on the indoor carpet . I ran the lower hole on the shock tower while i calmed down the response of the steering/ front end it felt like i needed it more responsive into some tighter corners. so im going to try a pair of tires with knobs on them first before i change it back to the upper hole.
The Droop on the Front was 88.98 and the Rear at 104.58 something around that no traction roll only if i went to hot into the corner lol. I did use 30w shock oil in the rear shocks that did help for sure . And the Front ride height with the arms a little above level and the Rear arms leveled.
But the stock truck could use a diet a little lol.
tc5 man is offline
