Like Tree9Likes
Old 02-20-2013, 04:28 AM
  #43951
eddomak's Avatar
Originally Posted by witman69 View Post
Does anyone know the thread size/ part number for those 4 chassis screws(Circled in RED) holding in the center diff?
Thanks!
I remember asking the same question 1.5 years ago, so glad I can help someone else in the same position.
They are the same size as the ones that hold the front bumper in place, so 8-32 x3/8 flat head screws (LOSA6264).
eddomak is offline
Old 02-20-2013, 04:32 AM
  #43952
Djioul's Avatar
Originally Posted by eddomak View Post
Yes they will. My mate is running those during bash sessions. They are on a 12mm hex, and the offset is a little wider, so the stance of the truck will be slightly wider (and hence even better for bashing/stability). He loved the extra stability. Be aware that the wider stance will not be suitable for competition though as it will be beyond the maximum width permissable.
Hope this helps!
That is helping brilliantly, thanks a lot !
Djioul is offline
Old 02-20-2013, 04:37 AM
  #43953
witman69's Avatar
Originally Posted by Djioul View Post
", I was just wondering : will they fit my SCTE??
Im not sure about those particular tires, but the stock Slash Platinum ones fit just fine.
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-wp_000259.jpg   Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-wp_000258.jpg
witman69 is offline
Old 02-20-2013, 04:39 AM
  #43954
witman69's Avatar
FWIW, I thought my Slash was the shizz until I drove a friend's SCTE at the track. It IS still a fun basher though.
witman69 is offline
Old 02-20-2013, 04:40 AM
  #43955
witman69's Avatar
Awesome, Thanks Eddomak!
witman69 is offline
Old 02-20-2013, 09:26 AM
  #43956
tbills66's Avatar
I new to the scte and racing. I race on carpet and am having trouble with driving hard through the tight corners without rolling over. I am running the sway bars. I run 35 shock oil and black spring on front. I have 27.5/silver on rear. inner and bottom camber link. ride height it 27mm. 1 degree camber. I was going to try and use the carpet setup on Losi's site, but it is only 14mm ride height. There is no way I could run that without bottoming out.
tbills66 is offline
Old 02-20-2013, 09:31 AM
  #43957
taco0's Avatar
Trader Rating: 25 (100%+)
Good afternoon guys, I'm in the market for a Losi SCTE and I have some basic newbie questions:
1: How many teeth are on the stock spur?
2: What is the proper wheel (offset) to use on the SCTE?
3: Necessary/must have upgrades?
taco0 is offline
Old 02-20-2013, 09:45 AM
  #43958
rcguy76559's Avatar
Trader Rating: 22 (100%+)
bottoming out is ok just don't want to chassis slap or make you flip over/bounce off track on landing to much
rcguy76559 is offline
Old 02-20-2013, 10:24 AM
  #43959
Casper's Avatar
Trader Rating: 34 (100%+)
Bottoming out is not a bad thing. Run the Dustin Evans setup for carpet. His truck looked like it was on rails. Carpet is so high bite you have to get the car low so it will not roll over.
1: 40
2: Most call it zero offset but most companies make wheels for the SCTE and say so on the lable.
3: Only thing most agree is a "must" is carbon towers as the stocks may bend in a hard crash. Other stuff is for tuning options. Upgrade the outdrives to the HD lightened after the stock ones wear out. Obviously there are a lot of parts that you can upgrade but the argument for Necessary/must have is up to each driver.
Casper is offline
Old 02-20-2013, 10:37 AM
  #43960
tbills66's Avatar
[QUOTE=Casper;11839844]Bottoming out is not a bad thing. Run the Dustin Evans setup for carpet. His truck looked like it was on rails. Carpet is so high bite you have to get the car low so it will not roll over.
What is your thought on the sway bars? I have been told to take the sway bars off as this will free the truck up. Won't that make the rolling over worse?
Also, are the black silver and gold springs the same as the ones in the tlr spring kit?
tbills66 is offline
Old 02-20-2013, 11:46 AM
  #43961
Pygmy's Avatar
I was using gold springs, 50wt, heavy swaybars, really really low rideheight and schumacher minipins on carpet. Worked wonderful, it was really stiff and hardly ever traction-rolled.
Pygmy is offline
Old 02-20-2013, 12:40 PM
  #43962
drepus's Avatar
[QUOTE=tbills66;11839892]
The Evans carpet setup is definately the right direction to go. Lower ride height and stiffer sway bars will help with rolling over. You may want to try the upper hole on the tower for the front upper tie rod. This will reduce the aggresiveness of the steering.
No sway bars will definately cause more chassis roll=more likelt to roll over.
To help achieve a lower ride height you will need to cut a couple of coils off either the stock springs or the option rear springs. They are just too long for this low a setup. I remember cutting 2 coils off the stock black rear springs when I first raced the truck on carpet. I ran the cut portion of the spring "up" as i was worried the cut side would easily pop off the spring cup if mounted with the cut side down.
The schunmachers are notorious for traction rolling and it is normal to see folks trim off the outside two rows of pins on all four tires to slightly reduce it.
drepus is offline
Old 02-20-2013, 12:52 PM
  #43963
Pygmy's Avatar
No need to cut up springs, just use front springs in the rear.
Pygmy is offline
Old 02-20-2013, 01:00 PM
  #43964
Casper's Avatar
Swaybars would be a must for me on carpet. Stiff then what we normally run as well.
Casper is offline
Old 02-20-2013, 01:05 PM
  #43965
tc5 man's Avatar
Lightbulb
Yup i know where your coming from i race on a Carpet indoor track also. The main thing that will have the biggest effect of helping rollovers is the turning the drop screws in front and Rear. I have my where in the front the screw is just touching underneth and the Rear is almost touching.
Ride height i dint use a gauge so my is where the rear arms are level and the front are barely leveled yea theres no way i could run that low also not with the jumps at my track. The 1 degree camber is right on .
Shock oil im using 40w/4 hole and 32 1/2 /3 hole Rear . Springs i actually tried the Blue springs up front and that helped a lot all around steering etc.
Rear spring is a Meduim black spring im going to try a Silver color one .
Sway bar i actually loosen the set screws on my and the rear also but im going to try out some stiffer ones Front and Rear The Camber link i been running the upper hole but im going to try the bottom one.
And Tires play the biggest roll and not flying into turns.
tc5 man is offline
