Like Tree9Likes
Old 02-15-2013, 12:54 PM
  #43891
tc5 man's Avatar
What oz weights do you guys use when you place them in the back of the chassis ? It looks like most guys use 4 of them but i dont know the oz of them though .
Because im noticeing since i cut off the mud flaps and some of the bumper and a Rear Carbon tower the rear end feels lighter than the front end for sure .
I dont have a weight gauge.
tc5 man is offline
Old 02-15-2013, 01:19 PM
  #43892
mysupratoy94's Avatar
Trader Rating: 24 (100%+)
Originally Posted by traxxasrockhead View Post
searched that part# and its a body mount kit is that right?
Yeah, unfortunately those parts are not sold separately. I had left over parts from my xxx-sct
mysupratoy94 is offline
Old 02-15-2013, 01:22 PM
  #43893
Originally Posted by hacker07 View Post
No, these are the spring colors from the tuning spring sets.
I guess I don't understand. I have the LOSB2959 and LOSB2963 spring sets. "Front (Rear) Racing Spring Set", each set has 4 springs. The rear set has green, silver, orange, and red. The front set has purple, blue, black, and green. Are these the correct springs that corrolate with the colors we are talking about?
Thanks Ryan.
riverdog is offline
Old 02-15-2013, 02:18 PM
  #43894
tc5 man's Avatar
Originally Posted by Feint Motion View Post
I see, cool man. Biggest thing you can do, if you all about saving weight, is getting a Aftermarket chassis. Would shave off a lot of weight.
Yea im looking at getting the Bump chassis or the Jammin Chassis whatever i can afford.
tc5 man is offline
Old 02-15-2013, 02:20 PM
  #43895
Adonis_mp's Avatar
Trader Rating: 8 (90%+)
I have a few nube question. I'm setting my truck per Dunford setup sheet but;
1. How do adjust/change the anti squat and how does it affect the truck?
2. What is the aluminum pivot support.
3. What is the part number for the 2 hole 55 pistons?
Adonis_mp is offline
Old 02-15-2013, 04:46 PM
  #43896
drepus's Avatar
Most of the stick on weights you will see folks using are 1/4oz each piece.
drepus is offline
Old 02-15-2013, 05:56 PM
  #43897
1. anti squat is adjusted using the adjustable toe blocks in the tlr tuning kit and it can affect the truck many different ways it pretty much does what the name implies it helps so the truck doesnt squat under power it just puts a slight angle on the a arm.
2. the aluminum pivot support is the toe blocks that come with the tuning kit
traxxasrockhead is offline
Old 02-15-2013, 10:08 PM
  #43898
Casper's Avatar
Trader Rating: 34 (100%+)
I think 1 and 2 were pretty much answered.
As for 3 you need to make them.
Here are instructions but we are not drilling them. Start with a 22 #55 piston and just glue two holes shut.
http://losiracing.blogspot.com/2012/...e-pistons.html
Casper is offline
Old 02-16-2013, 12:52 PM
  #43899
Thanks Ryan.
riverdog, I'm pretty sure he ment to say yes here. The part numbers you listed are correct for the SCTE.
65BAJA is offline
Old 02-16-2013, 12:53 PM
  #43900
ussprinceton's Avatar
Default which motor, esc, & LiPo combo + gearing for the new Ten-SCTE 2.0 kit?
I want to post my questions here as well, hoping to get answers from a different thread, knowing there will be lots of experience coming from this one.
I plan on getting the new Ten-SCTE 2.0 kit when it comes out this March 2013. What motor, esc, gearing, and LiPo batteries should I run?...
I was looking into the Castle MMP SCT 2400kv combo, as well as the Tenshock SC411 Hobbywing SCT Pro 120A combo.....Which of these two motor & esc combos should I get. If the Tenshock SC411 is better , then whick kv rating should I get for the Tenshock SC411? It comes in the 3500kv, 4000kv, 4600kv, and the 5200kv...
I was also looking to be running 3S LiPo, but, would 4S be better, or is 4S too much?
How should I gear the new Ten-SCTE 2.0 to keep the temperatures down? I will be running it in a short course RC track with tight turns, so I'm looking for fast acceleration instead of high top speeds because I don't need or want high top speeds....
All answers would be greatly appreciated.
ussprinceton is offline
Old 02-16-2013, 01:17 PM
  #43901
Cajvol94's Avatar
Trader Rating: 27 (100%+)
Default MMP and SCTE
I have a mamba max pro and a Tacon 4000kv 550 brushless motor with a 18t pinion. I had this set up in my sc10 4x4 and just bought a Losi scte and intalled the same set up in it. Oh yeah and a 6600 60-100c 2s lipo, savoy 1258 and CC ext BEC. I can only get about 4-5 minutes out of it before the Esc stops and blinks red with the fan continuing to run. I still have my steering and after a min or so it's back and running then it does it again. The motor is only 130-140 degrees. And i still have 3.9v in each cell so i know its not the lipo cutoff. Does the MMP overheat and quit? Should I drop to a 14t pinion and go from there. I'm puzzled because this is the exact same set up I had in a different truck. Anyone???
Cajvol94 is offline
Old 02-16-2013, 01:39 PM
  #43902
The gearing is to high try the 14 tooth pinion.
slasn_48 is offline
Old 02-16-2013, 01:49 PM
  #43903
Cajvol94's Avatar
So prob it's over heating the Esc which is causing it to quit and cool off. The truck deff had plenty of punch. Thanks.
Cajvol94 is offline
Old 02-16-2013, 01:58 PM
  #43904
Trader Rating: 21 (100%+)
Default SCTE MIP
Can I get some help...I have the MIP conversion for my SCTE. I bought it here. I just started racing it..I'm newer to racing and dot have the knowledge I would like. When I race and jump my truck bounces a lot when it lands. The guy I've bought it from said I have 50wt and 35 wt in the shocks. The MIP blue springs on front and black on back. How can I make the truck squat more when it lands? I don't know anything about shocks. Ride height? Spring color? Big bore shocks? Also my truck seems to roll a lot when turning fast..I have away bars but maybe it's my driving...and need to learn how to use the throttle better. Please help with the shocks....indoor clay track.
Anthony
YonkersRC is offline
Old 02-16-2013, 03:50 PM
  #43905
Haha101's Avatar
Hey Guys im looking for an aftermarket screw kit for this truck.... any suggestions?
Haha101 is offline
