I've spent allot of money on upgrades,not because I thought it was going to make be a better racer or even make my truck faster I just enjoy tinkering with my truck
I don't know. I upgraded every piece after it failed or if I thought it would help performance. And it did get better or more durable with almost every upgrade. Over time it had more aftermarket parts than stock parts.
Then it got really old hunting down aftermarket parts when they wore out or broke, so now I'm running a different truck bone-stock and I'm going to keep it like that as much as possible.
at this point I think the only upgrades that will help me are better throttle control,picking the right tire for the track,and getting more track time which I don't think will be any time soon since I just moved from Florida to NY so keep the upgrades coming so at least if I can't race it I can work on it
Has anyone heard of KK Pit? Any thoughts or comments from people who have used their parts?
Here's one part they make. Talk about bling...
http://www.ebay.com/itm/KKPIT-LOSI-S...adio_Control_T
I am planning to get the new diff cases. Can I use the old internal gears (sans the 4 tiny shims)? I read some posts about new gears so wanted to confirm first. Thanks!
Hi guys. I am newbie in SCTE. Can i use tekin pro4 4600kv with 3s Lipo?
any suggestion ?
Thanks.
any suggestion ?
Thanks.
not suggested
http://www.roarracing.com/downloads/..._Rule_Book.pdf
Start at page 70.
There is a minimum overall hieight as well as some rules on the size of some key body dimensions.
There is the issue that the wheel wells need to cover the wheels so so you need clareance for the wheel travel. It is kind of one of those things that it is what it is. If you like lower body cars there are buggies and ST trucks.
Start at page 70.
Also read about wing and reminded me a few dingos using them.
Anyways, on parts update: just got in the mail the new diff and intalled one already...now thats what a diff is supposed to feel ! Thanks Ryan
I realized that my truck most have almost all the goodies and the battery tray was shipped today from chris (a.p.e) but what I'm really surprised is that I still have a spare set of a arms on the bag and the stock ones still looks strong (mugen sucks on that department) and also I'm still using the stock bumpers and I have crashed and hit a lot of things like truggies in more than a year racing.
Really want a few teknos on my track and kick their...!
No, the 4600 is not meant for 3s. The 3300 is.
Yes, all gears work but the newest gear set is the set you will most likely get if you order and yes, do not use the 4 tiny shims
Losi noob
I am getting ready to pick up a used SCTE. I am getting a good deal on a buddies entire setup. he just had a kid and no longer has time for RC. Couple of quick questions. Is the scte sae or metric? How often do you have to service the diffs? And is it a chore to get to them? I am planning to tear down the entire truck, clean and refurb from the ground up so I start with a clean slate and go from there. I have always run ae till this. I ran a sc10 4x4 for a couple of weeks then sold it. Only been running blinky SC since. This will be my first Losi product ever. I came to the understanding in the last few weeks that brand loyalty doesnt really mean anything unless they are paying you. Checked the mailbox. Nope no check for running what i have been running. Time to make a change. I hope to learn alot in the coming months about how to setup this beast. Thanks all for all the posts I have been trying to catch up on.
Mixed - mainly SAE
Your mileage may vary. Some (many?) have problems with leaking diffs and there are many methods for trying to seal them (search "seal diff RTV"). Just released has been a new TLR diff housing that does no leak. I am not experienced with many kits, but find it is quite easy to get to them. Here are a couple of links I have saved:
http://www.rctech.net/forum/10810042-post34902.html
Here are some other notes I sent to a new SCTE owner:
Preventative Maintenance
+ YouTube Video | |
- Blue Threadlock 4 Centre Diff Mount screws
- Blue Threadlock Servo Saver in tightened position
- Cut Nerf bars?
- Trim rear bumper?
- Engine Mount Screw - swap to cap head (or countersunk with washer)
- Wheel nuts tight
- All screws on base plate are present & flush tight
- Serrated nylock flange nuts for wheels
- Pinion gears
- Ride height to 27mm/27mm
- Diffs changed over to Diff Oil (plus sealing method), start with 5000 Front / 5000 Centre / 3000 Rear
- Gold/Black Springs Front, Silver/Orange Springs Rear
- Centre diff Mounting Screws loosening - blue locktite
- Diff fluid leaking - sealing metal insert
- Centre driveshaft coupler pin (LOSB3556) wearing into plastic holder - newer part with grub screw, or aftermarket solutions
- Motor mount button head screw stripping head or thread - cap head screw
- Loss of "tight" steering over time - loose servo saver needs tightening + locktite
- Wheel nuts coming loose/off and wearing wheel hex away - serrated flanged nylock wheel nuts
- Bending shock towers (never happened to me) - carbon fibre shock towers
- Too much slop? Design feature, or hardened steering ball ends
- Too loud? SCTE is generally loud, but adjusting pinion gear mesh can help a little
- Glitching? Glitch buster capacitor or external BEC. (or change ESC / Servo / receiver)
