Like Tree9Likes
Old 01-14-2013, 07:19 PM
  #43081
Panda-PR's Avatar
At the rate my addiction is going....4000kv can be here on a near future LOL
I have a mamba 3800 for indoors but that track closed
Panda-PR is offline
Old 01-15-2013, 01:46 AM
  #43082
nanoverse's Avatar
Originally Posted by xXblitzXx View Post
Ive been following along but dont fully understand. When you guys say you are gluing the stock pistons so there is only two holes. Are you doing this to the number three pistons. What oil is used after you do that for both front and rear. finally are shock locations just left up to personal discresion or is there a standard. I am currently using the dunford and am looking to try something else.
You can do it to the stock ones too, but need a 1.3mm drill to open the holes. Oil starting point: losi f32,5, r30
nanoverse is offline
Old 01-15-2013, 03:30 AM
  #43083
Dos Andos's Avatar
Trader Rating: 32 (100%+)
Hi all,
Has anybody else had issues with team Orion batteries? I have 4 carbon pro 6500mah 90c packs. 2 have minor swelling but the other 2 have split open. These packs have always been looked after, always balanced, always charged at 6.5 amps with a good quality charger, never dropped and never over discharged. I don't bash only race. So they are only ever run for 7 minutes most times.
They have between 15 to 20 cycles on them and gotta say I'm pretty disappointed...
Any ideas or comments?
Dos Andos is offline
Old 01-15-2013, 03:41 AM
  #43084
nanoverse's Avatar
Originally Posted by Dos Andos View Post
Hi all,
Yeah, my saddles I used for my Desc and my friends stick did swell after few cycles. He got it replaced I just sold everything, including the rango.
Imho overpriced and tech outdated for the price.
Old 01-15-2013, 03:59 AM
  #43085
rcracenut's Avatar
Trader Rating: 52 (96%+)
A freind of mine had the same problem.
rcracenut is offline
Old 01-15-2013, 04:48 AM
  #43086
jayhawknavy02's Avatar
Originally Posted by Gene158 View Post
I got an xtreme racing transponder mount and the amb transponder holder. Does the mount go on top of the switch cover or do you remove the cover? Also, what's the best way to secure the transponder holder to the mount?
Here you go, here is a photo, you have to get hardware yourself. You can grab aluminum bolts and nuts to save weight. Re-Use the bolts in the radio box.
jayhawknavy02 is offline
Old 01-15-2013, 04:49 AM
  #43087
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Do you use bullet connectors, not the bird cage variety?
BDRMBULLY is offline
Old 01-15-2013, 04:52 AM
  #43088
Trader Rating: 46 (98%+)
Yes I like the duratrax 4mm bullets, cheap and work awesome
TurboTim is offline
Old 01-15-2013, 06:12 AM
  #43089
goehm's Avatar
Trader Rating: 45 (100%+)
Do you have it mounted that way so that you can swap transponders? If not, seems like it'd be cheaper, lighter and cleaner to put it in the radio box.
goehm is offline
Old 01-15-2013, 06:22 AM
  #43090
Pygmy's Avatar
I'm using the birdcages to directly connect the Esc to my battery, seems to work fine.
Pygmy is offline
Old 01-15-2013, 06:33 AM
  #43091
Won't be for to much longer I would deff change those out as soon as possible if you like your lipo. ESP with that monster of a motor u run
TurboTim is offline
Old 01-15-2013, 06:54 AM
  #43092
Hi all,
I've had 2 Orions (of 2) swell to unusable levels and 1 IP (of 2) also go round.
I'm not hating here, but I've also got 14 nano-techs without 1 single issue...
I also only race and look after my packs. I hope you get good warranty service out of Orion but I'd suggest selling them on while/if you can.
On the same note - A friend had 8, yes 8, protek batteries die in about 3 months. He's now converted to turnigy and not a single issue
whittie is offline
Old 01-15-2013, 07:18 AM
  #43093
BDRMBULLY's Avatar
Birdcages are for charging, after time they become a loose connector and will possibly melt you lipi by the connector,
Old 01-15-2013, 07:23 AM
  #43094
I was referring to the techno center driveshafts (front/rear), actually. So TLR HD lightened outdrives in the center diff will be compatible with the techno driveshafts? Why is it different for the front/rear driveshafts?
KoryRC is offline
Old 01-15-2013, 07:33 AM
  #43095
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Tekno makes the ball end (the side with the drive pin through it) bigger than the stock CVD's so it will not fit into the stock diff cups . You must get the Tekno diff cups to use their F/R CVD set ....
BashemSmashem is offline
