Like Tree9Likes
Old 03-20-2011, 09:44 PM
  #4276
AnonymousUser's Avatar
Trader Rating: 25 (100%+)
Some sweet carnage caused by worn diff pins
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-diff1.jpg
AnonymousUser is offline
Old 03-20-2011, 09:49 PM
  #4277
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Man I don't even want to look at mine.
Is Losi sending diff rebuild kits or just pins? I'm afraid mine are going to be trashed.
heavyjeffd is offline
Old 03-20-2011, 09:50 PM
  #4278
SaladFork's Avatar
Just the pins, no gears...
SaladFork is offline
Old 03-20-2011, 09:55 PM
  #4279
heavyjeffd's Avatar
Urgh. Guess I'll order some gears too. May just buy complete diff cases offa evilBay, it's cheaper.
Old 03-20-2011, 09:56 PM
  #4280
SCTRacerX's Avatar
Trader Rating: 32 (100%+)
Originally Posted by BDRMBULLY View Post
so my novak and mmp have to many issues , sensor wire , over heating, heating up my battery's. etc i was running a castle 1512 1.5 y in my slash but the can was a lil to big to fit in the ten properly. so i shimmed the four bolts of the center diff apprx 1/8 and my motor slid right in. very close to the outdrive but not touching. do you guys think shimming the center diff up 1/8 will affect it much or not? i didnt wanna dremel off the lil motor kick stand as i also ordered the castle 1410 new 4 pole motor yesterday. but my slash never over heated with the mmp 1512 1.5 combo so i wanted to install it and try it out.
I run the 1512 1y and it runs amazing. For being a larger motor and running it on the lower end of it's capabilites it sure does run great. Not too much torque doesn't pull the front end up very easy. It has great top end was about to run a speed test to get exact numbers but my truck stopped going forward( diff pins?) I would guess it will go about 37 mph on a good 2s and around 43 mph on a good 3s. Which IMO is FAST. When I get my truck fixed will put down some exact numbers. Heat is no issue at all. The motor is a little warm to the touch defiantly not hot to the touch after a good 5000mah pack or two. I am pretty happy with this setup. I did grind the little motor stand thing a little and took a bolt out and it slid right it. Using a novak 20t pinion installed upside down to fit. Easy install. I ran it at a smaller indoor track( not my fave) and it ran great, a little fast but the truck can handle it. I hope to get more track time in asap.
SCTRacerX is offline
Old 03-20-2011, 09:57 PM
  #4281
I called Horizon about the gears Thurs or Fri and was told June. This was before I even looked at the gears, I had a hunch....
Old 03-20-2011, 09:59 PM
  #4282
Cult Racing's Avatar
Trader Rating: 42 (100%+)
since all the ten-t aluminum rear hubs are sold out, would these work??
http://www.amainhobbies.com/product_...ub-Carriers-20
also would it be a good idea to do the front spindles and carriers aluminum with these if they fit?
http://www.amainhobbies.com/product_...Carrier-Set-12
Cult Racing is offline
  #4283
SCTRacerX's Avatar
Sorry I a new losi driver. Are the diff pins inside the diff itself? I got my rear diff out and one of my screws to open it up was stripped is the under warranty?
Also what happens when the diffs pins go out? My truck stopped going forward is that what everyone's trucks are doing when they go bad?
Old 03-20-2011, 10:01 PM
  #4284
BmainStar's Avatar
Why does horizon keep throwing this June date out?? Very disturbing!!They are not some small mom and pop operation ,WTF?
BmainStar is offline
  #4285
Pins are inside the diff, with the spider(small) gears on them. Mine just turns into front-wheel-drive when the rear diff goes poo poo.
Old 03-20-2011, 10:03 PM
  #4286
Hmmmm, front wheel drive class!
iThinman is offline
  #4287
BmainStar's Avatar
Originally Posted by SaladFork View Post
Wow just rolled into my LHS the other day and got em off the shelf,they had the wheels as well
  #4288
culture6's Avatar
well first time ever driving a 4x4SC, and I love it... I know about the diff pins, and it's unfortunate that I didn't get the good ones. Ran stock grease in the diffs, ran 3 heats and an 8 min main no problem but they are wore down a tad. got second in the main(:
losi xcel 1700kv on 3s (had the esc and motor just laying in my truggy doing nothing so...)
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-tenscte.jpg   Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-tenscte3.jpg
culture6 is offline
Old 03-20-2011, 10:06 PM
  #4289
It's not as fun as it sounds
Old 03-20-2011, 10:08 PM
  #4290
SaladFork's Avatar
Good call, and you get the diff case and out drives.
