Like Tree9Likes
Old 01-06-2013, 01:52 AM
  #42736
Trying to figure out what pinion to run on another vehicle to match the FDR on the SCTE, but I can't find how many teeth the ring & pinion gears are, or the transmission ratio.
Anyone know?
Edit, nevermind, 3.888888888888889
rallyredevo is offline
Old 01-06-2013, 06:04 AM
  #42737
Hi. How many teeth have Associated ds1015 servo? Want to buy aluminium servo arm, and don't know how many teeth..
Kilbatrosas is offline
Old 01-06-2013, 06:18 AM
  #42738
what is the latest info on the diff leaking?
i have a friend that is a machinest and i mailed him a few losi diffs and told him to make an aluminum one but he thinks its the bushing and started to make a hardened one or maybe one that screws in and locks.
opinions?
auto2 is offline
Old 01-06-2013, 06:30 AM
  #42739
rcgod's Avatar
Trader Rating: 32 (100%+)
opinions?
TLR332001
rcgod is offline
Old 01-06-2013, 06:34 AM
  #42740
Suspended
Trader Rating: 440 (99%+)
Same as futaba. 25t
MattP is offline
Old 01-06-2013, 08:09 AM
  #42741
Warrior273's Avatar
Default Newbie
New to the site. Wanted to share my scte with u guys.
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-image.jpg
Warrior273 is offline
Old 01-06-2013, 08:11 AM
  #42742
Warrior273's Avatar
Another pic
  #42743
Trader Rating: 53 (100%+)
25 same as savox and futaba
underway is offline
Old 01-06-2013, 08:16 AM
  #42744
huzzler's Avatar
opinions?
if you build the diffs right they never leak in the first place. Hot Racing allready makes an aluminum diff. http://www.hot-racing.com/index.cgi?...CTE11C01;c=629
huzzler is offline
Old 01-06-2013, 08:18 AM
  #42745
huzzler's Avatar
Welcome and enjoy the "knowledge".
huzzler is offline
Old 01-06-2013, 08:28 AM
  #42746
Trader Rating: 90 (100%+)
opinions?
Read the last 3 pages and you'll read there's NEW TLR branded diff cases that are bulletproof. Ignore the LOSB#### ones and get the TLR ones.
Kuya_Kimo is offline
Old 01-06-2013, 08:48 AM
  #42747
Im running a dx3s radio system and a savox steering servo; Ive heard that this combo for whatever reason can cause glitching. I installed it when I built the truck and have been running it for several months now but only began to experience glitching problems last week. At first i attributed it to what I thought must have been a bad receiver or transmitter but as soon as some people began to clear off the track the problem stopped. The glitching is relatively minor and ONLY occurs when there are tons of other racers on the track. My question is if this is something a glitch buster will take care of or if I should look into getting another radio system.
M1kect is offline
Old 01-06-2013, 09:19 AM
  #42748
nanoverse's Avatar
Hahaha, sorry.
Losi brings out the HDs just for fun.
nanoverse is offline
Old 01-06-2013, 09:49 AM
  #42749
Originally Posted by ChrisAttebery View Post
Hey guys,
I just wanted to give you all a quick update. Diff pins are back in stock. I just finished cutting a batch. Diff bushings should be here tomorrow or Monday. Shims are in stock.
I will start working on battery trays ASAP.
Thanks,
Chris
did u know the ape tray cant be turned around on the kh chassis? is there a fix for this?
cuppcake80 is offline
Old 01-06-2013, 10:01 AM
  #42750
bigjerry's Avatar
Trader Rating: 53 (98%+)
compleatly different try for King Headz he states the on his order form
bigjerry is offline
