Like Tree9Likes
Old 01-01-2013, 08:37 AM
  #42541
Nothing about it???
robertino59 is offline
Old 01-01-2013, 08:45 AM
  #42542
buchanan88's Avatar
Anyone ever tried the tenshock 4600kv sct401 motor? Just wondering what gearing would work for a med traction large outdoor track? Also how did the motor compare to the more expensive ones. Thanks in advance. Also Im using the Mip tuning kit so my truck is 8oz lighter then normal.
buchanan88 is offline
Old 01-01-2013, 09:17 AM
  #42543
rcgod's Avatar
Trader Rating: 32 (100%+)
Originally Posted by robertino59 View Post
I was thinking to buy the xtreme racing chassis.
It's the one that mix carbon and aluminium.
According to your opinion is carbon durable or can break very fastly???
And carbon chassis change the car??? Change the way to drive it???
I had the extreme chassis and didn't like it. Felt inconsistent. My opinion is too stiff front to rear and too flexible laterally. I also have the bump, bce and snr chassis and they all work great and are durable.
rcgod is offline
Old 01-01-2013, 10:49 AM
  #42544
8ight-e's Avatar
Trader Rating: 58 (100%+)
Order of my preference..
1 - Bump (best one out there imo long bump brace is a must though)
2 - Kingheadz
3 - TLR
4 - BCE
8ight-e is offline
Old 01-01-2013, 12:11 PM
  #42545
timamybrown's Avatar
Nothing about it???
I run the kingheadz and like it.
Ran my buddy's bump seemed to have to much rear traction for me.
All are better than stock but I think it's more a personal preference.
I ran the snr once and really liked it to.
timamybrown is offline
Old 01-01-2013, 01:07 PM
  #42546
Gene158's Avatar
That's the motor I run and it's fast as hell. My brother runs the 411, the sensored version, and it's also an awesome motor. I haven't run the more expensive motors in this truck so I can't really compare them to the tenshock. For a large track, 14-15t pinion and 40t spur should work just fine. When I ran outdoors over the summer, my scte had no problem clearing all the jumps on a 1/8th scale track. You will not be lacking power with this motor. My only complaint is that it's not the smoothest. The sensored version is a little smoother.
Gene158 is offline
Old 01-01-2013, 01:11 PM
  #42547
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Runtime leaves a lot to be desired. Never made it over 8 mins with my sc401 4600. I'm running the hobbywing 4000Kv next season.
Rockthecatbox21 is offline
Old 01-01-2013, 01:22 PM
  #42548
Gene158's Avatar
With my nanotech 6000mah batteries and kingheadz chassis, I easily get 10min of run time. That doesn't seem right that you can't even make 8 min. I would check for binding or something.
Gene158 is offline
Old 01-01-2013, 01:28 PM
  #42549
No binding,(all new avid bearings). Recommended gearing (13 tooth pinion). And all smooth diffs. I was using the 6600 nano's and i still had runtime issues. Other than that it's a fantastic motor.
Old 01-01-2013, 01:39 PM
  #42550
rcgod's Avatar
Imo runtimes can't be compared between different drivers and tracks. Too many variables. If you only get 5 minutes runtime then there's an issue. If you're getting 20 minutes runtime you need to pull the trigger harder. Lol.
rcgod is offline
Old 01-01-2013, 01:55 PM
  #42551
+1
Old 01-01-2013, 01:59 PM
  #42552
TCCustoms's Avatar
Originally Posted by dtr View Post
Can't you read, man? The diff cases are the same front, rear and center.
+3
They are all the same...never been any different diffs, just the out drives are different from front/rear to the center
TCCustoms is offline
Old 01-01-2013, 02:31 PM
  #42553
Panda-PR's Avatar
Anyone tried the pro-line toyota tundra body? How does it fits?
If not I'm going back to the stock body. The losi hi performance is not good because how thin it is (it broke exactly where I used the exacto blade for painting it)
Panda-PR is offline
Old 01-01-2013, 03:03 PM
  #42554
rcracenut's Avatar
Trader Rating: 52 (96%+)
Does anyone make 2-3mm offset wheel hexs for the Losi scte?
rcracenut is offline
Old 01-01-2013, 03:31 PM
  #42555
rcgod's Avatar
You can use the sc10 4x4 3mm offset wheels.
rcgod is offline
