Like Tree9Likes
Old 12-30-2012, 03:20 PM
  #42496
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Kevin_M View Post
Need some help.
I was racing and noticed that my car will not make a tight right turn as it will left. I have adjusted the rods to see if I can get more throw but no go. Any suggestions?
Make sure your steering turnbuckles are equal length.
Rockthecatbox21 is offline
Old 12-30-2012, 03:23 PM
  #42497
Kevin_M's Avatar
Originally Posted by timannnn6 View Post
Servo saver may be sticking.
I just changed servo out from hitec to savox and still no change. My steering rods are same length as well. I think the throw from the servo to the saver is hitting when pushed forward..
Kevin_M is offline
Old 12-30-2012, 03:24 PM
  #42498
Suspended
Originally Posted by drepus View Post
Yup
Nope not the same..
LOSB3104 front/read diff housing
LOSB3522.center..also need mounting bracket
Carpet Racer69 is offline
Old 12-30-2012, 03:42 PM
  #42499
timannnn6's Avatar
Trader Rating: 140 (100%+)
I mentioned servo saver not servo. If its sticking your wheels will stay in one direction as you turn another. Had this happen on my sons truck. Took it apart, cleaned it, and all is well.
timannnn6 is offline
Old 12-30-2012, 03:49 PM
  #42500
drepus's Avatar
Originally Posted by Carpet Racer69 View Post
Nope not the same..
Pretty sure he was asking about these.
http://www.tlracing.com/Products/Def...odID=TLR332001
drepus is offline
Old 12-30-2012, 04:03 PM
  #42501
Kevin_M's Avatar
fair enough ill tear it all down and look at it tonight.
Kevin_M is offline
  #42502
Originally Posted by ironzgti35 View Post
Any online vendors have the new diff cases in stock yet? Beside horizon
NitroHouse has them for $6.79
http://www.nitrohouse.com/HD-Differe...E_p_15372.html
Throwindirt is offline
Old 12-30-2012, 05:02 PM
  #42503
timannnn6's Avatar
Before you tear into it turn the car on with your steering servo centered. Grab a front wheel and force turn left then let go. It should come back to center. Do the same thing but force turn right it should come back to center. If it sticks you'll know. Mine just had a small amount of grit in the servo saver. Once cleaned it worked great.
Old 12-30-2012, 05:04 PM
  #42504
Panda-PR's Avatar
Is this the HW mentioned 2 pages back?
XERUN SCT COMBO (SCT-PRO Series), the 4000kv?
http://www.falconsekido.com/products...sct-pro-series
Product number: 81040180 in blue, 81040201 in black
Panda-PR is offline
Old 12-30-2012, 05:12 PM
  #42505
Thats the one.Its a great combo for the price you cant beat it.Good customer service too.Any other questions pm me.
Losi57 is offline
Old 12-30-2012, 05:18 PM
  #42506
Panda-PR's Avatar
Thanks!!
I have a tekin 4600/rx8 installed. Do any of you know if this combo will give me more runtime?
Also, I usually run on a large outdoor track; will this combo run as fast? Or what can I expect vs. the 4600kv ??
Lots of questions! Thanks
Panda-PR is offline
Old 12-30-2012, 05:49 PM
  #42507
Kevin_M's Avatar
Ok can someone tell me what the steering tie rod lengths are supposed to be? They are not defined in the manual.
Kevin_M is offline
Old 12-30-2012, 07:04 PM
  #42508
huzzler's Avatar
Need some help.
Have you checked the EPA or travel in your settings on radio? I know sometimes switching servos I got to redo the EPA. As far as tie rod lengths what I usually do is with radio and esc on make sure servo horn is centered then adjust the tie rod going to steering rack so steering rack is centered. Then you can adjust tie rods for your toe. I usually go like -1. toe out. Then just kinda measure to see if they are same. Then I put it on ground and adjust trim to make it track straight. Then adjust epas.
huzzler is offline
Old 12-30-2012, 07:12 PM
  #42509
Suspended
Trader Rating: 440 (99%+)
Definitely check EPA.
Take servo horn off. Center your steering trim and subtrim to zero. Set both left and right EPA to 100 percent. Then install servo horn with radio on. Center the horn using subtrim. Then turn all the way to right and back your EPA down until the servo quits making a stressed sound. Do the same for the left steering throw.
MattP is offline
Old 12-30-2012, 07:17 PM
  #42510
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
also try checking your dual rate settings if your radio has them this sometimes cause the servo to turn short
BlackStarRacing is offline
