Like Tree9Likes
Old 12-23-2012, 07:31 AM
  #42286
I believe that the 4600 is limited to 2s. I run 6800mah 70c batteries for racing with the same combo.
Tailspin is offline
Old 12-23-2012, 08:07 AM
  #42287
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by iroczcec View Post
what battery should i be running with a tekin rx8 and pro 4600 motor? 2s or 3s what c and mah also
No more than 2s lipo on that motor, 3s will destroy it in no time and you couldn't gear it low enough to stand a chance. If you want to run 3s lipo you need to be in the 2400-3200kv range, you could maybe sneek by with a 3800kv but that is very high rpm.
8ight-e is offline
Old 12-23-2012, 08:37 AM
  #42288
Gene158's Avatar
2s will be plenty. No need for 3s.
Gene158 is offline
Old 12-23-2012, 12:32 PM
  #42289
nanoverse's Avatar
Originally Posted by 8ight-e View Post
Your description of power, maybe different than mine. The 4000 can provide enough power and top end with out a boost if you want it to just gear up, the 4000 has more torque than the 4700 it'll be just fine from really 14-16t. The trick is how much of your lipo's you eat up and how long of a run time you need to have. The 4k geared a touch lower with a little boost will be more effecient with your lipo's, it will NOT stress out ever and you can still have the same top speed down the stright a higher KV motor has. You will have the benefit of the control a slightly lower kv motor has in technical areas of the track. The 4k w/ 14t on any normal indoor track is overkill as is, with 15t on some of the rare large indoor facilities (motorama etc where you run on the 1/8 scale track). Keep in mind the stock losi SCTE motor is a 2800kv and they run that sucker geared WAY up to generate the power and a RTR with just that won motorama last year vs all the 4600,4700 motors out there.. higher kv in the same exact motor doesn't always mean more power, in fact in these vehicles it just means you gear lower to get the same top speed because any more is just wasted and ends up with a DNF due to LVC or way more crashes because you are too hot in the technical parts of the track that just don't need it to be fast.
Just an opinion, buy both and play you choice Good luck either way.
With what esc do you run boost with the 4000kv?
nanoverse is offline
Old 12-23-2012, 12:51 PM
  #42290
Pygmy's Avatar
Originally Posted by dmorash View Post
anyone use any of hot racing products?
I do / did. I'm not impressed by their quality control - one of my 3 diff cases was unusable and they don't respond to email. Won't be using HR again.
Pygmy is offline
Old 12-23-2012, 12:52 PM
  #42291
Pygmy's Avatar
I'm quite fond of my Gens Ace 2S2P 7000mAh batteries.
Pygmy is offline
Old 12-23-2012, 02:00 PM
  #42292
8ight-e's Avatar
The Hobbywing v3, sick ESC smoother than any i've had in my SCTE.
8ight-e is offline
Old 12-23-2012, 02:02 PM
  #42293
iroczcec's Avatar
Trader Rating: 128 (100%+)
i ordered some turnigy nano 6.0 hardcase packs hopefully they will work good
iroczcec is offline
Old 12-23-2012, 02:46 PM
  #42294
Nick@Jet's Avatar
Trader Rating: 17 (100%+)
6200 Nano tech A-Spec with Pro4 4600 13T medium bite and did an 8 minute main plus 4 laps.
Nick@Jet is offline
Old 12-23-2012, 03:05 PM
  #42295
Gene158's Avatar
They will man don't worry.
Gene158 is offline
Old 12-23-2012, 03:19 PM
  #42296
iroczcec's Avatar
thanks guys!
iroczcec is offline
Old 12-23-2012, 03:25 PM
  #42297
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
they'll work good for about 30-40 cycles, then not so much.
i know it's too late for you, but for others looking for high capacity, high discharge batteries for this truck, check out SMC's packs. only a few bucks more than the nano's and they're much higher quality batteries.
RC*PHREAK is offline
Old 12-23-2012, 07:31 PM
  #42298
8ight-e's Avatar
IP Intellect 70c 6800mah packs are the best I've had yet in my SCTE, including the 90c carbons, and many others.. week after week strong as the last way way better than nanotech packs, not as cheap but a nice price tag too. SMC recent packs I have not tried but I had a lot of bad luck with them a year or so ago.. several poofed.
8ight-e is offline
Old 12-23-2012, 07:38 PM
  #42299
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Not had a problem with my nanos running a Castle 1410 motor , though I did kill 2 trying to run that Tenshock SC411 4600 motor ......
BashemSmashem is offline
Old 12-23-2012, 07:49 PM
  #42300
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
I ran the 6600 nano's all season no probs with my tenshock sc401 4600. I guarantee you they've had more than 40 cycles on them and they're still going strong.
Rockthecatbox21 is offline
