Like Tree9Likes
Old 03-20-2011, 06:33 AM
  #4201
Trader Rating: 19 (100%+)
Originally Posted by wcrase101 View Post
will this work with the stock chassis? my motor mount stripped out already.
if it does is this the ten-X they have listed on there site?
me likes
Yes. It is the Ten T mount. Works great with the stock chassis.
Edumakated is offline
Old 03-20-2011, 07:24 AM
  #4202
FangsCPO's Avatar
Originally Posted by skyler hays View Post
ok guys...i am fed up. i am running a novak hv 4.5 and novak pro sc esc. geared at 12/40 and 15/40. temps really dont change that much. after 10 minutes i am at 180 degrees. lipo was 115-120. motor will not make it this summer when ambient temps are 100. it was 80 here today.
that combo worked fine for 10 minutes with my jammin...but i guess the extra beefiness of the losi pushes the system to its limits. (not complaining about weight of truck. i punted quite a few slashes today)
basically looking for opinions. thought about getting a different esc and going to 3s. will that make it run cooler? my esc will not take 3s. my buddy found a hv pro 4.5 system at the lhs that has to be old stock because it is discontinued on tower. his manual says 2-4s lipo. but if you look on novak's site they say the 4.5hv is for 2s operation only. so i am thinking the 4.5 can handle the 3s.
but anyway. i tqed today and finished 2nd. the truck overheated glitched what ever and i had to baby it the last 3 minutes to finish. i was far enough ahead that i only fell to 2nd. gonna race again tomorrow at a small track so heat shouldnt matter tomorrow. looking forward to suggestions.
Does your ESC have a "current limiter" in it's setup??
On the Tekin RX8 you can adjust the "current limiter" to 90% from the default "off". This way your ESC isn't pushing all the juice to your motor. I was overheating like crazy with my Tekin SC4x 4.5T until I did that. I ran a (2) 5 minute heats and (1) 7 min main and temps coming off the track were at 140 degrees. I was geared at 14/40.
FangsCPO is offline
Old 03-20-2011, 07:32 AM
  #4203
FangsCPO's Avatar
Originally Posted by BDRMBULLY View Post
so my novak and mmp have to many issues , sensor wire , over heating, heating up my battery's. etc i was running a castle 1512 1.5 y in my slash but the can was a lil to big to fit in the ten properly. so i shimmed the four bolts of the center diff apprx 1/8 and my motor slid right in. very close to the outdrive but not touching. do you guys think shimming the center diff up 1/8 will affect it much or not? i didnt wanna dremel off the lil motor kick stand as i also ordered the castle 1410 new 4 pole motor yesterday. but my slash never over heated with the mmp 1512 1.5 combo so i wanted to install it and try it out.
Does your ESC have a "current limiter" in it's program setup??
On the Tekin RX8 you can adjust the "current limiter" to 90% from the default "off". This way your ESC isn't pushing all the juice to your motor. I was overheating like crazy with my Tekin SC4x 4.5T until I did that. I ran a (2) 5 minute heats and (1) 7 min main and temps coming off the track were at 140 degrees. I was geared at 14/40. Good luck!
FangsCPO is offline
Old 03-20-2011, 08:07 AM
  #4204
shortcut's Avatar
Trader Rating: 55 (100%+)
Originally Posted by jhautz View Post
How is that different from any other 1/10 scale?
It just looks like there is no side impact deflection at all.
shortcut is offline
Old 03-20-2011, 08:25 AM
  #4205
Ripped's Avatar
Trader Rating: 17 (100%+)
I sure need some diff pins...
Ripped is offline
Old 03-20-2011, 09:05 AM
  #4206
hgrove99's Avatar
me too
hgrove99 is offline
Old 03-20-2011, 09:24 AM
  #4207
hgrove99's Avatar
im running an mmp w/2400kv motor and 19t pinion..my car never got over 105 degrees...i run in a very tight clay indoor track fyi...just thought id put that out there
hgrove99 is offline
Old 03-20-2011, 09:27 AM
  #4208
what battery pack you running? 2s or 3s
fireflysti is offline
Old 03-20-2011, 09:29 AM
  #4209
You don't have any nurf bars.
Super Coupe is offline
Old 03-20-2011, 09:54 AM
  #4210
+1 I decided to screw around and take my son's tires off his stampede xl5. I went hard on speed runs and drifted a for a while infront of my house and when I came in the temp was 104 on the motor. I couldn't believe it? I love the 2400 on 3s
LRPO is offline
Old 03-20-2011, 09:58 AM
  #4211
I think I saw earlier in the thread that someone had rear arms split on the mold line. Add me to that list. Didnt break , just seperated on the end near the wheel and let the pin come out. Since no spare parts exist, I just place the pin back through the hole and ran it that way for the main. It held together and I won the main. We have a Series race in 2 weeks. It would be nice if some parts made it by then. I havent received my gear pins yet either.
The truck drives awesome. But the early amount of slop in the drive line alarms me. I hope it all gets sorted out .
Lon_L is offline
Old 03-20-2011, 10:01 AM
  #4212
Cult Racing's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Cult Racing View Post
Rage, I just got done racing today with my rx8 in, and it was awesome, the only problem i had was towards the end of the race (7min main) my car would start to stop running, and then go and stop and would do that over and over. I checked the temps and the hottest it got was 132, and i didnt even have a fan on it
can someone help me with this? or could it possibly be my battery dieing on me?
Cult Racing is offline
Old 03-20-2011, 10:05 AM
  #4213
Did you check your battery's voltage? it sounds like your battery voltage dropped down to the voltage cut off of the ESC.
Old 03-20-2011, 10:14 AM
  #4214
Trader Rating: 33 (100%+)
Cool
If you have about 30 min, some patience and a couple of parts you can fix it.
Same thing happened here, I took a small metal picture hanger, a 1.5mm screw & nut, my drill w/ a 1/16" drill bit, some 30 min epoxy and a bit of heat shrink tubing and made it better than new.... It works Great..... check the pic.
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-131-3142_img.jpg
silversam is offline
  #4215
BashemSmashem's Avatar
You still have steering when it stops ? Is it re arming after it stops , or just starts up with no arming tones ?
BashemSmashem is offline
