#406
Question?
Do you think a castle creations sidwinder 3800kv would work will with this truck or the Dynamite FUZE 5800kv would work better I know the 5800kv will be faster I have a 2s 5000mah 20c battery i know I will have to gear up on the pinion to keep the heat down a little but do you think that will be a good start.
Here is mine, it flies pretty good.
+ YouTube Video | |
#407
In my best 15 year old voice... I learned it from you (posting vids)lol
oh you fixed it. oh well I'm leaving it up. It deserves two posts.
+ YouTube Video | |
#408
+ YouTube Video | |
I fixed your video with the durability test.
#409
What would be the cheapest motor and ESC I could get a way with on this truck.
#410
#412
motor
Casper will a 1/8 brushless motor fit?
#413
I have a converted tent scte to hold me over till the losi scte that I have already pre-order. ran it for the first time finished second tonight more stable than my jammin but pushes more. I race on a tight track. my conversion is box stock right now diffs are grease 7k center and grease in the rear. shocks feel real thick. I need this thing to steer more off power. can anyone help with setup for diffs and shocks? what will the new truck come with? I was gonna try 5-7-2 diffs but I am lost for shocks. first time out was good tho I was only 25 seconds off my pace with a non-setup truck so with a lil work this thing is gonna rock and it is so much more durable...
casper or hacker can you guys post a setup?
should I change springs, swaybars, shock pistons, etc? whats different on the new roller than the ten scte?
#414
If you have the original 2 hole pistons from a TEN-T, then you need to drill them out to make them 4 hole. That single change will help dramitically. I would do all four about a 57 or 58 and start with 35 in front and 25 in the rear. Ours certainly do not push, these things steer excellent.
#415
#416
[QUOTE=SaladFork;8564736]I think the 3800 would work but not ideal for this truck. And the 5800 you shouldn't even consider, the motor will over heat no matter how you gear it. And you want to go less teeth on the pinion to keep the temps lower. [quote=SaladFork;8564736]
Saladfork
Why do you think the Castle Creations 3800kv is not ideal for this truck?
Saladfork
#417
[QUOTE=CarlCrocco;8567677][QUOTE=SaladFork;8564736]I think the 3800 would work but not ideal for this truck. And the 5800 you shouldn't even consider, the motor will over heat no matter how you gear it. And you want to go less teeth on the pinion to keep the temps lower.
Curious myself because the RPMs will be low and have tons of torque on tap with the 3800kv 1410 ???
Top Speed Calc looks excellent ??
Differential Ratio: 3.888888888888889
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 17
Total Voltage: 7.40
Motor KV: 3800
Tire Diameter (inches): 4.25
Tire Ballooning (inches): .10
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.35 : 1
Total Ratio: 9.15033 : 1
Tire Circumference (inches): 13.98 inches (355.09 mm)
Rollout: 1.53:1
Total Motor Speed: 28120 RPM
Vehicle Speed: 40.68 mph (65.35 km/h)
Effective KV Value: 3800
KT constant: 0.36 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Other Ratio: 1
Total Voltage: 7.40
Motor KV: 3800
Rollout: 1.53:1
#418
I dont think you could gear that motor anywere near that without it getting hot.
#419
Other Ratio: 1
Total Voltage: 7.40
Motor KV: 3800
Rollout: 1.53:1
Other Ratio: 1
Total Voltage: 7.40
Motor KV: 3800
Rollout: 1.53:1
And hooksjk asked me about the cheapest combo, not the best IMO or what I would run. While I would never run a Havoc 3S in any 4wd, I do know it will work and it's cheap so that is what I said use.
#420
This is the main reason why I dont care much for this forum, most of the guys are so closed minded ?
But I have to agree that other motors such as a 550 BL mill "might" be better due to the weight of the SCTE.
I have one coming via mail as I write this and look forward to testing it.
No calc is perfect but I assure you this one is as close as one can get to it.
All the guys on RC-Monster swear by it and thats plenty good for me. IMO it's one of the highest levels of BL information and knowledge availible on any forums I've visited ?
The gentleman whom made this webpage is one of the mods at RCM.
http://scriptasylum.com/rc_speed/top_speed.html
