So what are all your opinions on drag-break ?
Use it, or don't ? And if you use it, what settings ?
I'm curious to see how people drive
Hopefully Losi will come out with the new truck as soon as they get the new 8 done. Them will can start a new tread call it Losi scte 2.0
I heard by end of december or sometime in January from a good source... But not holding my breath. :-)
I would have liked a stock tooth count, I don't really want to change my current setup, a little quieter would be nice though.
I always ran 14/40 wherever I went but when I switched to the 41 on indoor tracks and to the 39 on outdoor tracks it was night and day! Believe me the spur choices will inhance whatever setup you currently have
Seems like more work than just changing the pinion... What's the point?
I run my battery back with a custom mount to get some of the weight off the nose.
It uses the end plates from the Attebury mount. I run the snr graphite chassis and mount the battery flat on it for lower cog. I scaled the truck to get 50/50 weight distribution before I drilled the mount holes.
I run medium/high bite dirt or clay. Never tried carpet but it sounds fun.
so i'm new to the SCTE. I bought the ARR and before i put all the electronics in it i was going to correct all of the bad things i heard about the truck i.e. diff, weight problem, chassis. So i started with the rear diff, taking out the old grease and replacing it with oil(3k weight). I tore it down cleaned it out throughly. I put it back together tighten the screws, and the outdrives wouldn't spin. I took it back apart and removed the shim, CA the inserts and put it back together. Now it spins freely. Is it ok to run without the shims? or did i do something wrong putting it together the first time?
You really want to use the shims. My front diff did the same thing after i ca'd it. I found out you really have to put exactly the right amount of ca around the insert, or the diff will bind. What i did to the diff i over ca'd, was i put 2 paper seals to make it feel like it should. My other 2 diffs worked fine after i put just the right amount of ca on them.
