Like Tree9Likes
Old 11-14-2012, 09:15 PM
  #41116
dogger 218's Avatar
So far all bearing are good just got done with all 3 diffs motor is normal cvd fill good
dogger 218 is offline
Old 11-15-2012, 02:47 AM
  #41117
dtr
dtr's Avatar
Where can I get the conical washers that are under the bolts holding the bottom plastic plate? I have seen LOSB5033 mentioned before but is there something more specific to the SCTE, without the nitro parts?
dtr is offline
Old 11-15-2012, 04:10 AM
  #41118
rcgod's Avatar
Trader Rating: 32 (100%+)
http://www.amainhobbies.com/product_...sink-Washers-8
rcgod is offline
Old 11-15-2012, 04:44 AM
  #41119
dtr
dtr's Avatar
Thanks, I have those but they are too big and do not fit the recesses in the chassis.
dtr is offline
Old 11-15-2012, 08:55 AM
  #41120
chucko's Avatar
Try this
http://www.ebay.com/itm/HobbyPro-H17...61127259377%26
I have two one on my scte and one on my 8 E 2.0 I cant help but sometimes spin the tires
chucko is offline
Old 11-15-2012, 10:26 AM
  #41121
TCCustoms's Avatar
Originally Posted by Rockthecatbox21 View Post
I think you're mistaken, Nitrohouse.com sells a roller with the BUMP chassis already installed. You can only get the bce on their website and only the chassis has to be bought separately.
Originally Posted by TCCustoms View Post
but DO KNOW that nitrohouse.com sells the TLR chassis and TLR kit for $189 i beleive but hopefully someone will chime in to point you in the right direction
no, your reading too much into what i said...I said Nitro house sells the TLR chassis and TLR tuning kit for $189 but there is a company somewhere out there that sells an aftermarket chassis like the bump, bce, or KH as a combo with the TLR tuning kit as a combo but didnt kno which. Thats what why i said hopefully someone will chime in and point you in the right direction but now that you made me look again, nitrohouse sells the BUMP chassis with the TLR kit also for $189 and thats pry the one i was thinking of...but do apologize as i didnt word it better to clearly state that i didnt know which chassis it was that was paired with the tuning kit, i just meant that if he didnt have the tuning kit that he could get the chassis and tuning kit as a combo ALOT cheaper this way if it was a chassis he liked
BUMP Chassis with TLR tuning kit
TCCustoms is offline
Old 11-15-2012, 01:21 PM
  #41122
chucko's Avatar
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-chris-atts-install.jpg
bce chassis. I think its really the ticket. they have em on e bay.. a chris battery holder. helps with lowering center of gravity and transfers weight where you need it. a fan to keep it cool on those 120 degree days when racing in the heat or indoor heated track that fan cost 6 bucks and has been working for a yr.
chucko is offline
Old 11-15-2012, 06:29 PM
  #41123
Allen720's Avatar
Trader Rating: 33 (100%+)
Originally Posted by chucko View Post
Attachment 992607
nevermind
Allen720 is offline
Old 11-15-2012, 06:33 PM
  #41124
Allen720's Avatar
Try this
how long did it take to get it. it says on ebay dec6 to dec 24 delivery date
Allen720 is offline
Old 11-15-2012, 06:40 PM
  #41125
Default setup tools
could someone please tell me what setup tools i need for the scte. just got into the rc car scene this past weekend with a scte rolling chassis, and novak electonics. Anyway, i dont see any hudy stuff that will work with this truck ?
i think i need a setup board, guages for ride height, camber and toe in ? Anything else ??? what tools are you guys using, what works ? i have searched and spent hours on rctech since i joined yesterday but i couldnt find anything specific for the scte.. i did read that the hudy off road setup station does not work with this truck.
aquaanox is offline
Old 11-15-2012, 06:58 PM
  #41126
Casper's Avatar
Trader Rating: 34 (100%+)
IMO a setup station for an offroad car is a bit unnecessary. A ride height gauge and a camber gauge and a smooth flat surface can get you dialed in 95% of the time. I have some large calipers to dial in toe in when I first build but after that I just adjust by eye if I need to.
Casper is offline
Old 11-15-2012, 06:59 PM
  #41127
sbrewer's Avatar
Trader Rating: 20 (100%+)
I would say all you really need is ride height guage and a camber guage. That truck I really good stock, a lot of ppl make alot of changes, but I would say get some good tires, and drive it till you need to change out that diff grease
sbrewer is offline
Old 11-16-2012, 03:49 AM
  #41128
MRANTITRAXXAS's Avatar
You need the number 6's instead of 8's
MRANTITRAXXAS is offline
Old 11-16-2012, 06:01 AM
  #41129
dtr
dtr's Avatar
Thanks, could you please give a bit more detail? I am not familiar with SAE hardware sizes.
dtr is offline
Old 11-16-2012, 07:00 AM
  #41130
Suspended
Trader Rating: 440 (99%+)
Attachment 992607
That looks like a good setup. Did you run the truck with the stock chassis before the BCE? If so how much of an actual difference did it make on the track?
MattP is offline
