you can use one end of ur shock tools that came with the kit... it snaps in on the one end and if u need more holding power you can use pliers and it will not damage the shock because ur holding on the plastic piece.
I got advice from one guy but would like more opinions.
I am fixing to try a turnigy 4.5 550 can 4560 kv motor. What size pinion should I start with? He suggested a 17t for a starting point.
i would say 13-14 and go from there, if it was me i would start with a 13, i run a 13 myself and go from there.
I'd go with 14 as a nice average, then you can move up/down to 17 or 12 as you see fit.
Gear calc:
http://www.rcuniverse.com/community/gearwizard.cfm
SCTE gear ratio is 3:89.
To get a rollout about 1:1 as a starting point use a 13-14t. Check temps, after that use timing and boost to get more speed if needed. If temps allow and the track needs it, might go up in pinion size.
Gear calc:
Gear calc:
Really? Damn, I'm running the same motor and gearing and I think the hottest my motor got was like 155 or so. That's without a fan too.
Anyway, thanks for the hints - got all the Associated shock boots on with no dramas at all. They are certainly a thicker rubber and look like they will do the job!
