Like Tree9Likes
Old 11-04-2012, 05:40 AM
  #40741
dtr
dtr's Avatar
Originally Posted by Zachfeen View Post
Quick question guys, I raced my SCTE for the first time yesterday and did pretty well. I solved the turning issue I was having with some new tires and changing diff fluids. Now I have another issue, the track i race on is a tight, indoor clay track and at the end o the straight there is a sweeper, and my truck traction rolls on it everytime unless I slow down a ton, other tracks can get through it quite a bit faster. WIll tightening the swap bars help out here so it will slide rather than body roll over and then traction roll?
Tightening the sway bars is effectively disabling them while acting as having stiffer springs. You should rather install a heavier set. You can also lower ride height, change inner camber link position or use different tires (or cut the outside of your current tires)
dtr is offline
Old 11-04-2012, 08:42 AM
  #40742
rcgod's Avatar
Trader Rating: 32 (100%+)
Try limiting droop and lowering ride height.
rcgod is offline
Old 11-04-2012, 08:50 AM
  #40743
hkrob's Avatar
Trader Rating: 18 (100%+)
I had the same problem when I first started driving my scte turns out it was my driving not the truck. Try letting off the throttle 15'-20' before the sweeper then use about 25% throttle through the corner this will pull the truck through the corner and not traction roll.
hkrob is offline
Old 11-04-2012, 08:54 AM
  #40744
chucko's Avatar
Maybe a little bit more camber to keep your tires from rolling in and then biting. also a what kind of inserts are you running ? Try a stiffer insert
chucko is offline
Old 11-04-2012, 10:34 AM
  #40745
Ralph289's Avatar
Default Castle Link Torque Limit Question
I run my SCTE for fun on a 3s and have the Torque Limit turned down some for better throttle control. If I decide to pop a 2s in it at times will that effect my ESC since it was setup and rev tested when i had a 3s in it with the Castle Link.
Hope I have explained myself...... I think .
Ralph289 is offline
Old 11-04-2012, 01:17 PM
  #40746
jmackani's Avatar
Trader Rating: 14 (100%+)
+1
jmackani is offline
Old 11-04-2012, 01:36 PM
  #40747
greener380's Avatar
Default Sidewinder SCT combo
Hey guys, just got finished with a fresh scte build. Bump chassis/brace, tuning kit, HA shocks, KH front diff mount, Tekno center CV's. Anyway I've installed a Castle sidewinder sct esc and 3800 motor I already had. Has the fan built into the case and I have a castle fan on the motor. Haven't hit the track yet but in the street this combo seems decent. I've heard these esc's won't last long in the losi. Anyone run this setup?
greener380 is offline
Old 11-04-2012, 02:16 PM
  #40748
Trader Rating: 20 (100%+)
did they change the gears in the gear sets ? I noticed the gears are more at a point. I can not get then to turn once I put it together. Everything is down and tight. Is their a new case for these gears or did I get something packaged wrong ?
xxxtruck is offline
Old 11-04-2012, 02:49 PM
  #40749
NEWBIE HERE....
I am currently running a MMM with 2200kv motor on 2s. It was stolen out of my traxxas revo. It seems that the teking rx8 and 4600kv motor is the best set up for the scte.
what advantages will i get if i upgrade to this motor?
compared to my current set up, is the upgrade worth $350?
Hackleman is offline
Old 11-04-2012, 03:04 PM
  #40750
Slotmachine's Avatar
I`ve had 2 or 3 of these blow on me in that truck, even 2 MMP speedo`s have gone on me. I am switching now. Sell the one you have and get something a little more beefy. I just missed out on a race this weekend because of esc problems.
Slotmachine is offline
Old 11-04-2012, 03:40 PM
  #40751
rcgod's Avatar
Originally Posted by Hackleman View Post
NEWBIE HERE....
4600 is a lot lighter and faster on 2s.
rcgod is offline
Old 11-04-2012, 03:41 PM
  #40752
goehm's Avatar
Trader Rating: 45 (100%+)
http://www.falconsekido.com/products...c-for-1-10-car
goehm is offline
Old 11-04-2012, 03:58 PM
  #40753
Double check that the squares on the sides of the pins are correctly seated. That has happened to meant times and I have to open the case a few times till I get it correctly
TXSlasher is offline
Old 11-04-2012, 04:09 PM
  #40754
Do yourself a favor and sell the sidewinder esc and put the money towards a Hobbywing SCT Pro or a Tekin RX8.Its only going to overheat on you,the losi scte is way to heavy for that esc.
Losi57 is offline
Old 11-04-2012, 04:38 PM
  #40755
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
I run a mmp without any issues in this truck. Some people have bad luck with castle and some have great luck, i'm the latter. I've heard just as many issues with tekin stuff as well.
Rockthecatbox21 is offline
