Like Tree9Likes
Old 10-17-2012, 11:18 AM
  #40231
Originally Posted by Resqnu
which 4 pole 4000kv or 4600kv? I currently run the Tekin sc4x 4.5 with a RX8 and feel it's plenty of power for me. Alot of you run the 4600 tuned down, so is the 4000 not enough? Info is appreciated.
If I rember right the 4000 tends to run hotter then the 4600.
lsbass is offline
Old 10-17-2012, 11:41 AM
  #40232
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by RC*PHREAK
You use those front and rear? What weight oils?
Yes front and rear. 32.5/27.5
rcgod is offline
Old 10-17-2012, 11:49 AM
  #40233
Originally Posted by rcgod
Tlr5090. #54 with two holes glued shut.
Personally, I prefer the 55 with 2 holes closed.
hacker07 is offline
Old 10-17-2012, 12:23 PM
  #40234
rcgod's Avatar
Hacker is right. My bad. I used #55.
rcgod is offline
Old 10-17-2012, 12:58 PM
  #40235
Casper's Avatar
Trader Rating: 34 (100%+)
55 holes are 1.32mm so a 1.3mm would be a very close.
Casper is offline
Old 10-17-2012, 01:07 PM
  #40236
Razorbelly's Avatar
____________________________________
I've raced the SCTE with a CC 3800kv and had great results and low running temps. 14T/ 6600 65c battery=20mins @ 140deg. And has out ran the 4600kv setups.I've just got the HW 4700 kv / 14t /same battery=11 mins @ 165deg.
Fast motor, but if u run in dusty conditions, u better check after every race day.
Because the HW motor will get loaded up with dirt inside front and back really bad.My next motor will be the Tekin 4000kv, temps will be about the same if u gear it right. IMO, the 4000kv should be the best choice for the SCTE. And that's running on big outdoor and big (Flowood) indoor tracks. U can run that punch level higher and add some timing on the 4000.
Razorbelly is offline
Old 10-17-2012, 01:39 PM
  #40237
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
4000 indoor , 4600 outdoor bigger tracks. had both , prefer the 4600!!
BDRMBULLY is offline
Old 10-17-2012, 02:41 PM
  #40238
.AJ.'s Avatar
I loved the art work for the 22sct so much i got my painter to copy it for me for my SCTE shell
.AJ. is offline
Old 10-17-2012, 03:10 PM
  #40239
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Definitely flaming.
ryanpatrickgore is offline
Old 10-17-2012, 03:57 PM
  #40240
Hay Casper, bought tekin 4600 pro4 what pinion should i use? race on mediem track clay blue gruve. losi 4x4 truck thanks for the help
mfcoupe32 is offline
Old 10-17-2012, 03:59 PM
  #40241
Casper's Avatar
13/14. I run 14 most places but for the med to small or tight and technical 13 is better.
Casper is offline
Old 10-17-2012, 04:16 PM
  #40242
thanks for the help.
Old 10-17-2012, 05:36 PM
  #40243
copey70's Avatar
it's a combination of things:
1) the savox servo draws more power than the stock servo
2) the internal BEC of the esc is weak and can't handle the additional amp draw
3) the spektrum receiver is very sensitive to power sag and will brown out much easier than other brands.
so the solution is to try a glitch buster capacitor like this one:
http://www.amainhobbies.com/product_...iver-Capacitor
that may eliminate the issue, or get an external BEC like this one:
http://www.amainhobbies.com/product_...Adjustable-BEC
that should definitely eliminate the problem.
I had the same problem and the glitch buster solved the problem, it's small enough to hide in the reciever box. Works like a charm.
copey70 is offline
Old 10-17-2012, 05:43 PM
  #40244
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
I am having a problem when building my shocks emulsion style. When i try to set the rebound to zero, only one shock has no rebound. The other shock, no matter what i do, always has full rebound. Only problem with 1 front shock the rears are fine and so is the front right one. No matter how much oil i take out to get less rebound, i always have that one shock getting full rebound. Even replaced the
o-rings in the problem shock.
Rockthecatbox21 is offline
Old 10-17-2012, 05:50 PM
  #40245
nitro_mt_racer's Avatar
Trader Rating: 240 (100%+)
Are you pushing the shock shaft all the way up prior to tightening the cap?
nitro_mt_racer is offline
