I tried out a set of 2 hole 1.3mm pistons with 32.5/30 oil this weekend. They felt pretty good. I was running 3/4 with 32.5/27.5 before and felt like the truck was bottoming too often. The 2 hole pistons handled very similar but didn't bottom out nearly as much. Thanks to Casper, Ryan and rcgod for letting me know about this setup.
found that there are separate option black spring for the 22SCT, can they be used in SCTE also ???
Sheesh, I keep finding SCTE part manufacturers that are new to me.
Anybody have any experience with the parts from Hot Racing ?
http://www.hot-racing.com/index.cgi?c=629
They seem to have a dual bearing motor mount like King Heads (only this one is a lot cheaper AND includes the top and front as well),
and other funky stuff.. (aluminum Diff case, "Rear Knuckle with graphite Mount" etc.)
What are you using to hold the motor heat sink in place? I have one similar to that but have been chicken to use it b/c I think it's going to slide back and short out the motor.
All freshened up for the Sc Showdown this weekend...
I want to add the 22SCT, any one have a discount code for amain?
Anyone know the tooth count on the servo horn on a Spektrum S6040?
Same as futaba - 25
