Like Tree9Likes
Old 09-30-2012, 04:45 AM
  #39676
sbrewer's Avatar
Trader Rating: 20 (100%+)
Not Sure how many others have do this. But I sawped over to te 8ight 2.0 buggy shocks and it drives very good!
sbrewer is offline
Old 09-30-2012, 06:50 AM
  #39677
TCCustoms's Avatar
i did it with the SNR +9mm graphite towers and like it...have red front springs with silver in rear. Nice that these towers also have the holes for stock or lower mounting holes if i decide to go back to stock shocks but doubt i will since they are just as much as the 8ights but a smidget cheaper. Cut off the bolth the standoff mounts to and drilled and tapped in a new smaller bolt so i didnt have to drill out the tower mounting holes since they are so close together
TCCustoms is offline
Old 09-30-2012, 12:40 PM
  #39678
Pygmy's Avatar
Travis, since you have the same Esc / Motor combo I have, what kind of batteries are you using and what runtime do you usually get ?
Pygmy is offline
Old 09-30-2012, 12:44 PM
  #39679
cmace23's Avatar
Trader Rating: 26 (100%+)
Hey guys I'm in need of some parts if anyone has any extras.
Needed Losi Scte parts:
Body
Front and rear body Mount's
Rear Bumper
Front Bumper
Side guards
Mud Flaps
Rear center drive shaft
Wheel hexes
cmace23 is offline
Old 09-30-2012, 01:13 PM
  #39680
TCCustoms's Avatar
Nanotech 6600's with 13t pinion and i havent really had "track time" to get a estimate as usually if i am running, its around the yard testing and checking things or just not paid attention when running with the bro in law and nephew BUT our local indoor track just opened back up so i dont know if on Wed they are open for practice and thats when i go run as i just dont have the extra money to race on Fridays but i'll try to do some checking within the week and run the truck if i get some time
Body
Rear Bumper
Front Bumper
Side guards
Mud Flaps
Wheel hexes
If your converting your TEN-Te you will also need the chassis to get the extra 1" and also why you need the longer rear shaft...im sure you kno but just in case you didnt
Old 09-30-2012, 01:29 PM
  #39681
Pygmy's Avatar
Cool. I'm running the 13t as well. I was bashing today on my 7000mAh Gens Ace (they're shiny new, 2nd run) and imho I had less run time than I'd expect. I don't know if the batteries might improve a bit over time; I've read about preservatives added to lipo's in the factory (for transportation) that disintegrate over time resulting in better performance, don't know if that's true or hogwash. I'd like to hear about your runtimes, then I can compare when the indoor track here opens again somewhere in the next few weeks.
Pygmy is offline
Old 09-30-2012, 01:45 PM
  #39682
TCCustoms's Avatar
Dunno, i use to run the Gens Ace 40c 5000mah batts and these nanos blow them outta the water BUT i was using direct wired batts with TRX connectors and now i have about 4-5" of wire out of the esc running straight to the batt with duratrax 4mm bullets and that reduced alot of heat and VERY PLEASED with the truck right now and flies through the air nicely and able to control it mid air very well. If i had some stuff around here or alittle more of an open area to run i would try to run it now but usually here im more speed runs or high speed running and not track style dinking around so it wont be worth comparing but our local indoor track is small also so this system will pry be way to much for the track but it will be fun to find out...
Old 09-30-2012, 03:24 PM
  #39683
spider882009's Avatar
Trader Rating: 7 (89%+)
Does anyone have a center diff for sale with 10000wt built??? I need to purchase one asap. I have had some problems in building the last couple days!
spider882009 is offline
Old 09-30-2012, 06:32 PM
  #39684
sbrewer's Avatar
Where did you get the shock towers from?
sbrewer is offline
Old 09-30-2012, 06:34 PM
  #39685
scracer68's Avatar
He got them from SNR more than likely.
http://www.snrgraphite.com/index.php...products_id=17
http://www.snrgraphite.com/index.php...products_id=18
scracer68 is offline
Old 09-30-2012, 06:38 PM
  #39686
scracer68's Avatar
Fixed the links.
Old 09-30-2012, 06:48 PM
  #39687
TCCustoms's Avatar
u are correct...happy with them so far also! Just CA Glue the edges and install em
Old 10-01-2012, 06:21 AM
  #39688
sbrewer's Avatar
cool thank you
sbrewer is offline
Old 10-01-2012, 09:08 AM
  #39689
weavty1's Avatar
Running a Novak Ballistic 4.5 motor, Tekin RX8 esc, and 5600-6000mah lipos... No matter what gearing I use, I can't seem to find myself making 10-minute mains. I'm lucky to get 9-minutes.
Also, not running any advanced timing, drag brake, or even a HV steering servo... Everything else seems legit, otherwise. Oh and no overheating of either the motor or ESC. Just poor run-times.
Help?
weavty1 is offline
Old 10-01-2012, 09:26 AM
  #39690
Grandturk's Avatar
Help?
I run 6500 Revtechs and the Activ8 from Novak with my Ballistic geared 15T and running timing advance on the speedo. No trouble making 10+ minutes.
Have you retarded the current limiter? I know that 100% will cook through batteries on the rx8. Try 60%
Grandturk is offline
