Like Tree9Likes
Old 09-21-2012, 10:14 PM
  #39496
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
Originally Posted by Gene158 View Post
Looks good!
Originally Posted by BmainStar View Post
That looks sick Phreak!!
Thanks buddy!
RC*PHREAK is offline
Old 09-21-2012, 11:00 PM
  #39497
Trader Rating: 90 (100%+)
I've ran my SCTE with a Tekin RX8 for a year now. I was forced to use my backup hobbywing xerun 120a today and loved that ESC so much. It's not as punchy but I don't lose anything from my pro4 4600.
Now, since the fan is a problem....
What's the difference between the xerun 120amp and the sct pro?
Kuya_Kimo is offline
Old 09-22-2012, 12:31 AM
  #39498
Suteki's Avatar
Have a small problem. The screws holding the shocks to the a-arms has come out a little during the past two races I've had. On the rear one has done so only a little bit but on the front it was definitely making it's way out.
Any tips on preventing this from happening? I was thinking blue loctite just to give it a little more hold but have since heard it's not good for plastics.
Was thinking maybe thread tape as a possible solution?
Maybe even CA glue, but I'm a little concerned it won't come out after ward?
Suteki is offline
Old 09-22-2012, 12:49 AM
  #39499
Bigwave's Avatar
It happens because of the rotation of the shock end. It will ever so slowly back out on the left rear and right front .
I personally use longer screws that go all the way through and add a locknut on the back to hold them on, but you can also buy left hand thread screws from Losi that will fix the issues on those 2 shocks.
http://losi.com/Products/Features.aspx?ProdId=LOSA6285
Bigwave is offline
Old 09-22-2012, 01:30 AM
  #39500
Suteki's Avatar
Huh.....that's exactly right, the left rear and right front. Interesting, why don't the other two?
Anyway whats a good temp fix? Don't believe I have long enough spares and being in Aus, getting anything local will be near impossible as most things need to be ordered in....
Suteki is offline
Old 09-22-2012, 04:50 AM
  #39501
TimMo846's Avatar
What are you actually trying to get the Temps down on? Motor or ESC?
Gearing and depending on what motor it is, less boost if you're using it and lower the current as well. I lowered mine on my RX8 and dropped 10-15 degrees.
TimMo846 is offline
Old 09-22-2012, 05:08 AM
  #39502
Chris K's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Rockthecatbox21 View Post
Yeah not too good of an idea on a semi-scale class on de's part. Would be cool for club racing though.
Mmmmm, probably NOT. Using them under any circumstances infers that they are OK - and they're NOT. Plus, there are always a bunch of newcomers around tracks and they tend to do what the 'fast guys' do; so in a sense you'd be leading by example the wrong direction. Just about any thread on this site has several posts by folks saying to the effect: THAT SUCKS, it's ok for me to do that at my home track.... and now we see how that line of thought and disagreement begins.... I (along with lotsa' others) believfe that this class should be maintained in 'semi scale' fashion - using stuff that looks like the 'big trucks' run....
They rotate in the 'tightening' direction - remember: righty tighty, lefty loosey!
As a temporary a small dab of shoe goo or a similar product should probably keep them from backing out - use a toothpick and put a small dab on the inside hole of the slot where the shock goes in the arm.
Chris K is offline
Old 09-22-2012, 05:23 AM
  #39503
Suteki's Avatar
Nope, don't have shoe goo either, I'm in Australia. If we have it I certainly haven't seen it. That's why I was thinking loctite.....hmmm.
However, with regard to the left hand screws, won't they ruin the threads considering they have already been made for regular screws?
Suteki is offline
Old 09-22-2012, 07:04 AM
  #39504
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
No issues at all!!
KIK is offline
Old 09-22-2012, 08:57 AM
  #39505
BmainStar's Avatar
Hey Kuya,the SCT Pro is more heavy duty,mo insulation, it is said!!
If it happened a lot then the arms may crack at that point or the holes may heave oversized.If yer lucky and none of that happened than you will be fine wit left hand ones.As a quick fix use tire clue and screw em back in works well!!Cheers!
BmainStar is offline
Old 09-22-2012, 09:03 AM
  #39506
Jake C6R's Avatar
No the left hand screws work great. I have used them on mu buggys and truggy and no more backing out. If you need a temporary fix put a little CA on the threads and screw them in. You can still break them loose when you are ready to do a permanent fix.
Jake C6R is offline
Old 09-22-2012, 09:04 AM
  #39507
Jake C6R's Avatar
Ha ha great minds think alike but you were too fast for me!
Jake C6R is offline
Old 09-22-2012, 09:09 AM
  #39508
Moderator
Deja Vu's Avatar
My daughter has been running a SC10 4X4 for awhile now. She has the Havo Pro SC and 4.5 Ballistic motor. It's always ran great and motor temps never got over 150. I bought a 2nd SCTE from a friend recently that was basically brand new. It came with the MMP SCT 550 2400 combo. Last week, the SCTE had a little bit of throttle glitching but I haven't had time to check it out. Last night, she broke her SC10 so I moved her Novak system to the SCTE. She ran her first qualifier like she was on fire! Man, the truck was fast and had tons of torque, but, she died on the last lap. I had to race so a couple of guys helped her with the truck and the motor temp'd at 203 and two wires had come loose. There is a possibility that I didn't do a good solder job and something happened to cause the motor to heat up after 5 minutes.
I had a 12 tooth pinion on the Novak 4.5. I seriously thought that this ratio would be just fine in the truck and wasn't concerned when we didn't have time to test it. Anyone else running the Ballistic 4.5 550 motor in this truck? If so, what ratio are you running?
Also, since the Castle SCT 2400 system seems to be working fine now, what ratio are you running with it? I know right now, it has the largest pinion you can run with the stock spur, but its pretty slow down the straight.
Sorry for the newbie-like questions. I usually do my own research. But when I am down to my last spare motor, I want to get some experienced advice
Deja Vu is offline
Old 09-22-2012, 09:14 AM
  #39509
BmainStar's Avatar
Ha,Ha Great minds think alike or Fools seldom differ You will have to make atrip out the 210 fwy E where it ends and come race at the new indoor track we have IERC to find out if i am actually faster LOL
Old 09-22-2012, 09:28 AM
  #39510
Trader Rating: 22 (100%+)
Try running a 13 or 14t pinion. These brushless motors have a sweet spot that they like to run. If overgeared, the motor may be revving too much. Also take apart the motor and check the bearings and clean out any dirt with a brush and compressed air.
Honu is offline
