Like Tree9Likes
Old 09-19-2012, 10:34 PM
  #39436
[QUOTE=Gene158;112
I got it all set up!!! I soldered some castle 4mm bullets onto the esc so it plugs right into the battery and I soldered the motor directly to the esc. I spent a while doing all the wiring because not only do I want it to look clean but I want to have as little resistance as possible. Anyway, this truck is awesome! I put a 15T pinion on it and only had time to run it in the street for a few minutes but wow this thing is fast! I think I might try a 13T on it.[/QUOTE]
Looks good! Can I ask why you opted for the 401 rather than the sensored 411? I'm looking into getting a tenshock too.
00Pocho is offline
Old 09-20-2012, 01:05 AM
  #39437
.AJ.'s Avatar
It does seem a bit pointless having a SC401 with a SCT Pro, why not go for a SC8 esc instead and save a few dollars????
.AJ. is offline
Old 09-20-2012, 03:31 AM
  #39438
Gene158's Avatar
I got the 401 because mostly everything I read said it wasn't worth getting the 411 and that the brakes are better on the 401. The reason I got the sct pro over the sc8 was so that I have the option of running a sensored motor in the future without having to buy an new esc.
Gene158 is offline
Old 09-20-2012, 04:26 AM
  #39439
.AJ.'s Avatar
Ive had both of the Tenshock's and the low down smoothness of the 411 is a winner for me, but a good call on the ESC tho and cant say ive had any issues with the brakes either
.AJ. is offline
Old 09-20-2012, 06:29 AM
  #39440
rcus3r's Avatar
Between the SC401 and SC411, does one run cooler than the other?
rcus3r is offline
Old 09-20-2012, 07:02 AM
  #39441
ferrarieeeee's Avatar
Sc411 cooler in my experience
ferrarieeeee is offline
Old 09-20-2012, 09:32 AM
  #39442
P6
i bought the sc401 instead of the sc411 because the price i paid $100 from funshobby and it came with a ex4 esc (toro or sc8) i can use a toro or tenshock program card for sure havent looked into hobbywings yet, i wish i would have spent a couple extra bucks and went sensored but for now im fine when i replace it ill move to a 4.5 novak system i personally just prefer having a sensor for the low speed control and if i ever need to replace parts on the motor it seems like novak is ther best about their parts being easier to find and around the same price as other places
P6 is offline
Old 09-20-2012, 11:50 AM
  #39443
Nick@Jet's Avatar
Trader Rating: 17 (100%+)
TEKNO dirveshafts and outdrives - anybody running them ? I have a question
I love the center shafts - but just installing the driveshafts and they require the larger outdrives which they come with. Putting them together is a pain though - the bearings, bearing holders and ring gear do not fit over them, so you must assemble in a certain order , not real excited about having to take this apart at the races only to change a bearing. Has anyone done something different with this setup? I'm sure I will be happy once all together.
The peice of paper that comes with it says you may have to modify the stock gear boxes - but says nothing about where, why and how much?
Nick@Jet is offline
Old 09-20-2012, 11:53 AM
  #39444
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
I have them and I did not modify the gear boxes. How often have you had to replace one of those bearings? I've had my truck for 18 months and I finally replaced them because I thought it was time, but they were still serviceable.
ChrisAttebery is offline
Old 09-20-2012, 12:00 PM
  #39445
Casper's Avatar
Trader Rating: 34 (100%+)
Reedy Truck race coming up in a couple weeks (Oct 6-7)at Hot Rod Hobbies. Anyone on here running there SCTE's at this race!
Casper is offline
Old 09-20-2012, 12:08 PM
  #39446
Grandturk's Avatar
More importantly - any big TLR announcements to be made at the event???
Grandturk is offline
Old 09-20-2012, 12:24 PM
  #39447
Casper's Avatar
It is a truck only race. What you expect to be announced? They already released the 22-SCT.
Casper is offline
Old 09-20-2012, 12:37 PM
  #39448
Nick@Jet's Avatar
Good point - I have replaced only once as a precaution
Nick@Jet is offline
Old 09-20-2012, 01:04 PM
  #39449
Grandturk's Avatar
That was months ago and I already have one. I want something new! TLR SCTE 2.0 maybe???
Old 09-20-2012, 01:10 PM
  #39450
KingdomRacer's Avatar
LOL
KingdomRacer is offline
