Like Tree9Likes
Old 09-18-2012, 08:14 PM
  #39406
I was also having heat issues running the sc411 4600/ rx8 and 6600 nano's. Leads would get very warm and I had one lead come off the deans a few times. I had also switched out the birdcage style plugs for the protec 4mm plugs. Since then I have ran 10ga wire directly from the esc to the battery and use TQ bullets that plug into the battery. Now all the wiring stays cool to the touch and I have had no more problems.
j_kinz is offline
Old 09-18-2012, 10:53 PM
  #39407
BmainStar's Avatar
Originally Posted by pballer2777 View Post
took my center diff out becase it was wobbling when i give it throttle. i wound up changing the out drives, bearings and the case, it still wobbles. the only thing i can think of that maybe the problem is the plastic part of the diff mount. has anybody else had this prob? also is there and upgraded piece i should get?
Don't worry bout wobbly center diff out drives it affects nothing,Every truck has them ,if it drives you nuts cuz You hate to look at it, then don't look at it LOL.Just like the front end slop it will not hurt any thing... Run It!!!! P.s. Battery Talk. Buy Good batteries!!It is the fuel of Your 800 dollar race rig ,why Skimp now??
BmainStar is offline
Old 09-18-2012, 11:06 PM
  #39408
ferrarieeeee's Avatar
Originally Posted by Suteki View Post
I haven't fully charged it back up but it was over 7.2v when I plugged it back into the battery charger.
In this round of battery purchase I'm giving Revtech, SMC, and Zombie batteries a try... My ESC is changed to sctpro as well, so far so good
ferrarieeeee is offline
Old 09-19-2012, 12:38 AM
  #39409
Suteki's Avatar
I have heard good things about Revtech and SMC; could you PM me with how they go?
I have a Revolectrix I am incredibly happy with, it just doesn't have enough capacity, 6000mah which if I have to run 10min mains, could be a worry.
Got my intellect today, unfortunately I had to run with a deans connector as they didn't have any with bullets so I had to solder on female bullets to the wires (made sure I have enough heatshrink on that none of the contacts are exposed). Took it for a marginal run out in the back yard for about 7min, a bit of full throttle here and there and mostly otherwise light running to see if some sort of 'break' in does anything. Seemed to go ok, no puffing anyway. I'm sure in the hotter mid day sun will be it's real test.
So long as it holds up for a 2 day race meet I'll be happy. After that I start a new job so money and importing a high quality battery shouldn't be as big an issue.
Suteki is offline
Old 09-19-2012, 12:53 AM
  #39410
Revtech 6900 100c goes pretty well... Lots of punch and high voltage... Ive just got it tried a couple of times so need some time to see if it stays so well
SMC i just got the 6000 60c non-roar for the price as backup battey, not bad though;-) Next would wanna try the zombies 7200 75c
For the connector i use ec5 for 4s and bullet for 2s now, i think i ll stay this way
Old 09-19-2012, 03:32 AM
  #39411
the perfect way is to use KH dual bearing motor mount
Marco926 is offline
Old 09-19-2012, 03:39 AM
  #39412
Suteki's Avatar
Awesome, please keep me updated on that.
Suteki is offline
Old 09-19-2012, 08:29 AM
  #39413
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
What's the deal with petit RC not having the setups for this truck posted?
Gas Rat Racin is offline
Old 09-19-2012, 11:41 AM
  #39414
dtr
dtr's Avatar
Does anyone have a setup for smooth, very high traction tracks? We will run on an onroad track with some wooden jumps, surface is concrete covered with some rough epoxy layer, so traction is very high but not very consistent as there is a lot of nitro smoke and al kinds of tire residue.
dtr is offline
Old 09-19-2012, 01:55 PM
  #39415
P6
can anyone do me a favor and measure the end of the battery tray the esc spot
P6 is offline
Old 09-19-2012, 02:40 PM
  #39416
dtr
dtr's Avatar
About 56mm long, 58mm wide.
dtr is offline
Old 09-19-2012, 02:52 PM
  #39417
Gene158's Avatar
I got all my stuff today! I have a question though. Both the motor and esc have the 3 wires already soldered in. I wanted to solder the motor batteries straight onto the esc without using any connectors. Should I just heat up the solder that's already on the esc and remove the wires or is that not a good idea? Also, how should I mount the esc to the truck. The tray on the truck has no holes but the esc has a some attachable tray of its own. It also has tape; do I just tape it on the truck's tray?
Gene158 is offline
Old 09-19-2012, 03:00 PM
  #39418
rcgod's Avatar
Trader Rating: 32 (100%+)
Use the tape to mount the esc. Unsolder the wires from the esc and solder the motor wires to it.
rcgod is offline
Old 09-19-2012, 03:05 PM
  #39419
Gene158's Avatar
Thanks!
Gene158 is offline
Old 09-19-2012, 03:07 PM
  #39420
P6
i would shorten the wires to while ur at it my tenshock 401 had more than extra
and for the battery i soldered 4mm bullets on to for my nanotechs the birdcage bullets that come with nanotechs arent recommended ether and yes like he said tape esc to the battery tray i acually own a jammin scrt10 not a scte so im gonna be using this battery tray on my truck same way
P6 is offline
