Like Tree9Likes
Old 09-16-2012, 01:00 AM
  #39331
eddomak's Avatar
Originally Posted by snaketaco
Bought scte used. How do I know what type of spring are on it? I don' see any thing to identify them.
For the original (ARR & RTR) style it comes with all black coloured springs. This means "medium". If you have gold or silver springs the previous person used the older style losi springs.
If you have black springs but they have dots of colour on the ends then it has the newer style racing springs.
Here are some notes from a previous thread:
http://www.rctech.net/forum/10541655-post31964.html
Spring rates for LOSB 2959 Front set
Green - 3.6
Blue - 3.9
Black - 4.2
Purple - 4.5
Spring rates for LOSB 2963 Rear set
Red - 2.7
Orange - 3.0
Silver - 3.3
Green - 3.6
"Old" spring rates.. Stock spring rates Front
Silver - 3.6
Black - 3.9
Gold -4.3
Stock rears are
Silver - 3.0
Black - 3.3
Gold -3.6
eddomak is offline
Old 09-16-2012, 04:10 PM
  #39332
jsamarin's Avatar
does the 2012 dunford setup call for emulsion or bladder shocks? I dont think it says on the setup sheet what he is using.
jsamarin is offline
Old 09-16-2012, 04:58 PM
  #39333
aquito's Avatar
Hey guys I have a scte with a castle 1410 3800kv with a hobbyking 120a esc and I'm running gens ace 40c 5,000mah 2s and a 50c 5,000mah 2s..
My question is. I will be upgrating to the tenshock sc401 4600kv.. Will I have to get new batteries with higher C rating? Or the ones I have are ok?
aquito is offline
Old 09-16-2012, 06:25 PM
  #39334
TCCustoms's Avatar
my 40c puffed on my HW SCT Pro and HW 4700kv geared at 13T and dont wanna drop any more as punch is on 1 and it still spins alot but my Nanotechs direct wired from esc to bullets that plug right into battery have yet to even get the packs warm even running in 90* heat in MI.
I say run it and try it with 13-14t gearing and see how temps are and see what your batteries do? If your that worried order new and sell or sell the GA and order a higher C rating while waiting for delivery of the motor if you can. I tried mine and mine didnt like it but they are $37 batt so i wasnt really out anything if something happened as i had them for 6-8 months and got my money out of them i thought, but any extra connection will cause resistance and even i was a skeptic until removing my TRX battery connection and goin to a direct wire set-up
TCCustoms is offline
Old 09-16-2012, 06:27 PM
  #39335
Would like some viewpoints, rebuild truck with all new stuf or get a new roller kit ?
sgtlt is offline
Old 09-16-2012, 06:56 PM
  #39336
TimMo846's Avatar
I would go with a new roller IMHO. I bought my roller brand new in box and really haven't changed to much on the set up, other than a little more cambering. Buying a used truck with all new parts sounds very tempting especially if its a GREAT price. But the Bad thing about buying something that is used is that you're buying someone else's set up and possibly problems and it's hard to get everything directly back to the stock setup so you can start fresh. If you have the money, I'd go new roller.
TimMo846 is offline
Old 09-16-2012, 07:40 PM
  #39337
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
I actually HAVE the sc401 4600 and i can tell you will need new batteries. I'm geared at 13t and my nanotec 6600's get puffed at the end of a long run. Even a short 6 min heat makes them heat up a little.
Rockthecatbox21 is offline
Old 09-16-2012, 07:48 PM
  #39338
cpt_RedBeard's Avatar
Trader Rating: 22 (100%+)
It all depends on where you wanna go with the build. I was going mip and top of the line so I went used. But I also went ceramic bearings, tekno drives and shafts, Ha balls and ti links. There wasn't much losi left when I was done.
cpt_RedBeard is offline
Old 09-16-2012, 08:37 PM
  #39339
TCCustoms's Avatar
+1
couldnt have said it better...I would have been better off doin a roller rather than converting my 810 into a SCTE but i was able to sell the motor/driveline to help gain some money back but i spent more trying to get it up and goin but still happy even tho i wish the MIP kit would have been out sooner cuz i would have just done that and swap all over that was needed.
But just depends like RedBeard said if you goin with alot of aftermarket, i'd shoot for a decent used but pay attention to what your buying and how they have treated it maintenance wise
Old 09-16-2012, 09:02 PM
  #39340
Gene158's Avatar
Damn man you got me worried now. I just bought a ten scte and ordered the sc401 4600kv and HW sct pro. For batteries, I ordered some 2s 6000mah 65-130c nanotechs. I was planning on using a 14t or 15t pinion. You think I'll have any issues with that setup?
Gene158 is offline
Old 09-16-2012, 09:18 PM
  #39341
Usually around 8 min mark is when they noticeably puff. At regular 6 min heats battery is at about 95 f and my motor is at 170 WITH the castle fan on it. My friend tried a 14t WITHOUT a fan and at the end of a 8 min run his motor temp was at 210 f
Old 09-16-2012, 11:51 PM
  #39342
Trader Rating: 90 (100%+)
Regarding batteries puffing.
I've tried all the nano-techs and gens ace on my 4600 and they ALL puff the 1st generation nanotech 6.0's were the ones that lasted the longest in my SCTE.
Turnigy now has the A-SPEC nanotech 6.2 which are the REAL deal. These batteries are actually lighter, feel stronger (carbon wrap), and have A LOT more punch. On the straight, a couple other racers were amazed on the speed of my truck.... tried my old nano's and it wasn't the same.
Just saying.....
Kuya_Kimo is offline
Old 09-17-2012, 12:02 AM
  #39343
ferrarieeeee's Avatar
Did u mean the SC411?
ferrarieeeee is offline
Old 09-17-2012, 12:03 AM
  #39344
aquito's Avatar
Wow so looks like I'm gonna need new batteries then. Or should I just keep my castle 1410? Is it really a big difference? I'm running 15t pinion
aquito is offline
Old 09-17-2012, 12:11 AM
  #39345
RC*PHREAK's Avatar
Trader Rating: 145 (100%+)
you should be fine with those batteries as long as you aren't running more than about 8 minute races. after that, you're risking it. i haven't puffed any of my 6.0's with my SC411 4600. i slightly puffed a 6.6 running it almost to cutoff during practice. i did puff a 6.0 running the hobbywing 4700 4 pole motor. that thing is just too much IMO. yeah, it's ballistic fast, but people say tenshocks eat motors? that thing eats them for lunch and asks for seconds.
RC*PHREAK is offline
