Like Tree9Likes
Old 09-14-2012, 12:55 AM
  #39301
Suteki's Avatar
Originally Posted by TimMo846 View Post
It's not the wheel off set or tires at all that are unusual. The reason behind having to have a certain wheel is that the front arms are wide will hit a normal wheel around the pin area. What a lot of people do, is dremel out the webbing on the inside of the front wheels to allow clearance. Here's a video from Proline that shows how to grind the wheel down some.
+ YouTube Video
AKA Enduro's will fit the stock wheels(rims) if you remove the Eclipse tires.
The problem I have it that my very first race is this Sunday and there are no hobby stores near me and the online ones I do use, would have to order them in so there is no way I would have them in time.
The only place I can get tires before the weekend was from some one that sells tires and spares at the track itself. He has tires, but no rims that are specific for the SCTE, the only rims he had were the AKA Cyclone rims but they weren't the SCTE specific and I wasn't sure what the offset is (I take it SCTE needs 0 offset?).
So basically I was boned.
I ended up getting some AKA City Blocks in SS (track has loose marbles on the surface in areas, but on the infield it's very hard dirt with a little bit of dust). So I currently have the stock SCTE wheels taking an acetone bath as I type this and I'll fit the AKA City Blocks on them.
There is next to no short course class at the track, it's mainly a few younger drivers that go in it and they run 4WD and 2WD, stock and modified, so I could basically end up in a field with only 1 guy in my actual class. So I'm not hugely concerned about great performance as it's not an competitive class. Next meet should be a lot more short course as it's an interclub round but I will soon get a 1/8 buggy as that is the major class everyone runs.
So yeh, I just wanted something to get me by as my standard tires that came with the truck are now all but bald.
Suteki is offline
Old 09-14-2012, 01:10 AM
  #39302
nanoverse's Avatar
Originally Posted by Casper View Post
Only thing with bullets on a battery is you HAVE to make sure they never touch. The battery will not be happy if you short the plugs. There are ways to do this but this is typcially why you would see another type of plug on these. I would go with a deans ultra plug on any battery with leads, personally.
The 4-poles and other systems we have now draw max amperages beyond what deans is made for. A friend who is in designing electronics looked at them and said that it's safer to use the connectors that are round and where the whole surface leads electricity better like EC5, XT90 or equivalent.
Pre tinning the wires and connectors of course helps with avoiding cold solder joints.
nanoverse is offline
Old 09-14-2012, 01:20 AM
  #39303
nanoverse's Avatar
Originally Posted by RC_Tactical View Post
In Adam's vid (yes it's for 1/8 scale but eerily similar to SCTE) he mentions that because the tolerances are so tight on the gears and housing vary that in his experience he finds eliminating the tiny shims (keeping the blocks) gives freer diff action. After struggling to get a clean mesh after three tries with all new parts, I removed the tiny shims and voila... Perfect. Just something to keep in mind if you keep getting a bind or overly tight diff after reassembly.
Sometimes the case is crooked but usually if it binds or isnt butter smooth is because of the metal inserts not properly seated/glued. If you dont glue them the force you use to push down screwing the head on might dislocate the inserts and result in a bad mesh. Rarely the gears just dont mesh especially if you have the older ones which are a bit lower.
The shims get chewed up pretty fast and maybe leaving them out works and the inserts dont get sanded down without the shims.
Old 09-14-2012, 03:36 AM
  #39304
Nick@Jet's Avatar
Trader Rating: 17 (100%+)
WE are experiencing very warm wires with Deans and originally I liked them - we have 12 cars and 30 batteries and unfortunately will have to change all of the connectors - also the deans we have to continually bend the pins for better connection - we are in search of the best connector.
Nick@Jet is offline
Old 09-14-2012, 04:21 AM
  #39305
Gene158's Avatar
I don't have any experience with deans but I do use ec5's and I really like them.
Gene158 is offline
Old 09-14-2012, 08:47 AM
  #39306
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
For the conditions you're describing the stock tires would actually work pretty well.
ChrisAttebery is offline
Old 09-14-2012, 08:51 AM
  #39307
TimMo846's Avatar
I've actually noticed the stock tires hook up just about on any surface pretty good.
TimMo846 is offline
Old 09-14-2012, 09:10 AM
  #39308
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
The only problem with the stock tires and a fast motor is that you get the balloon effect...
kjohnsiii is offline
Old 09-14-2012, 09:46 AM
  #39309
rcgod's Avatar
Trader Rating: 33 (100%+)
Boil the stock tires off the rims and put some good molded inserts in them. They are great practice or loose track tires and last a long time. The glue losi uses is pretty crappy and comes off a lot easier than most so it's easy to do.
rcgod is offline
Old 09-14-2012, 09:50 AM
  #39310
TimMo846's Avatar
heads up on this method, be very careful when you pull them out of the water not to warp the wheels. I've made this mistake a few times before. The plastic tends to be a little soft. Other than that, a good method.
TimMo846 is offline
Old 09-14-2012, 10:15 AM
  #39311
pballer2777's Avatar
Trader Rating: 28 (100%+)
where can i find a good setup for and out door 1/8th track with med bit
pballer2777 is offline
Old 09-14-2012, 10:37 AM
  #39312
This is great to start with:
http://losi.com/ProdInfo/Files/LOSB0...ford-02_12.pdf
Old 09-14-2012, 10:46 AM
  #39313
it will b a good base setup even tho it was for a indoor track?
Old 09-14-2012, 10:56 AM
  #39314
Yes. Just find out which tires work at your track.
Old 09-14-2012, 11:13 AM
  #39315
awsome thank u
