Like Tree9Likes
Old 09-06-2012, 06:59 PM
  #39106
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Diffs are packed with grease, should still change it , helps get to know the truck a lil better too
BDRMBULLY is offline
Old 09-06-2012, 07:06 PM
  #39107
Anyone else have leaky diffs? I notice my center diff especially seems to leak. It's not a whole lot but it leaves a line right under it.
Jim Bob is offline
Old 09-06-2012, 08:11 PM
  #39108
pballer2777's Avatar
Trader Rating: 28 (100%+)
where is everybody ordering these tenshock motors from? seems like alot of guys like them. anybody running one with the lrp ix8 esc?
pballer2777 is offline
Old 09-06-2012, 08:16 PM
  #39109
TimMo846's Avatar
http://builtrc.com/brushless_motors.aspx
^^^^Just ordered mine from buildrc.com ^^^^
Or on ebay
http://www.ebay.com/itm/Tenshock-Sho...item19d45a381b
TimMo846 is offline
Old 09-06-2012, 09:58 PM
  #39110
Originally Posted by LOSI123 View Post
Was wondering if anyone knew if the standard black chassis is 7075 or is it just a weak easy to bend alloy?
Stock chassis is not 7075. It's probably stamped 6061 or something similar. 5052 is far too soft to be chassis material. Aftermarket chassis are 7075, hence why they hold up a lot better.
thegame7 is offline
Old 09-06-2012, 10:25 PM
  #39111
BuiltRC.com!
EJ is the man! Best customer service in the RC industry and a very nice guy.
Jim Bob is offline
Old 09-06-2012, 11:21 PM
  #39112
.AJ.'s Avatar
Originally Posted by Throwindirt View Post
does anybody know what size screws are used that hold the motor mount slider onto the motor ? Only a couple of threads seem to be screwing into the motor with the screws I have. I run the new Kingheadz motor mount it didn't seem to be an issue with the stock motor mount or maybe I just didn't notice
I use m3 x 12mm with the KHZ motor mount
.AJ. is offline
Old 09-06-2012, 11:30 PM
  #39113
eddomak's Avatar
funshobby.com - ordered from them a couple of times and it arrived in a week to Australia. Good service!
eddomak is offline
Old 09-06-2012, 11:38 PM
  #39114
LOSI123's Avatar
Trader Rating: 63 (100%+)
Thanks for the info
ALso I was wondering what teeth pinions to order in this truck on 2 cell with a 4000kv sensored 4 pole motor, will be on a medium to large-ish track
LOSI123 is offline
Old 09-06-2012, 11:46 PM
  #39115
TimMo846's Avatar
Thanks for the info
Before you order the 4000, everyone has suggested to me to get the 4600. I'll be running on a track about the same size, so I'd suggest it to you as well.
TimMo846 is offline
Old 09-06-2012, 11:48 PM
  #39116
nanoverse's Avatar
Yes all the diffs leak thats a design problem that should have been fixed before launch. Well we have tested a lot of different things but for now the best solution seems to be to get loctite gasket silicon, zap a gap pink (with needle), some kicker, brake cleaner.
First let the paper gaskets soak in break cleaner for a while. Then put some gasket sealer in your hand ( use gloves ) and rub it all over the wet paper gasket. Put some cleaner on your finger as it helps to smear the stuff around. Let it sit for 30-60min or let it dry overnight. Both work as the little wet silicon is getting in all the nooks little better we prefer that method.
Next step is to glue the metal inserts into the housing. Clean all parts wirth break cleaner. Now push the inserts in real good and i mean real good. The insert shoud come out about finger nail width outside if not then push harder or get other housing.
Now apply the super glue with a needle from the inside. Use so much that the orifices are shut. Use kicker and scrape off if there is glue on the top of the insert.
Glue the outside too just to be sure as the diff spins/wobbles. Repeat for the top housing. The insert doesnt portrude here as much its just a little top of flush.
Put the thing together dry and take care not to push a lot on the outdrives. If it feels notchy try different gears. Sometime the housing just doesnt work and has to be disgarded. But usually built this way its quite smooth even dry.
Now put oil in the diff. Not too much. And screw in a cross pattern at first, not all the way in. One screw a little bit tighter then the opposite. Try if the gear action is smooth before tightening all the way. Built correctly you can tighten the screws quite tight.
Now the most important part. If its notchy at all or the gears dont move at all it's built wrong. It should be butter smooth this way.
Building scte diffs is an art form.
There is also something wrong with the diff shims getting almost totally worn out by driving one race day. Doesnt matter if they are stock or the superduper hardened ones. Maybe the kingheadz quadra bearings in center will help.
nanoverse is offline
Old 09-06-2012, 11:49 PM
  #39117
.AJ.'s Avatar
I order all my Tenshock kit also from Funshobby, but im in the UK xD
.AJ. is offline
Old 09-07-2012, 01:45 AM
  #39118
nanoverse's Avatar
Search also for "Mamyllyn" he has some pics up of the procedure.
Old 09-07-2012, 04:15 AM
  #39119
Trader Rating: 46 (100%+)
gonna try something different with my truck...will post my findings next week
NitroLuver is offline
Old 09-07-2012, 06:05 AM
  #39120
Here's another vote for Builtrc.com, it's where I bought my Tenshock from.
J.Pietsch is offline
