Like Tree9Likes
Old 09-05-2012, 03:55 PM
  #39046
TCCustoms's Avatar
Originally Posted by Pygmy View Post
That's good to hear since I ordered it yesterday (Will probably take a month to get here from Hong Kong though...)
I was wondering why I found so much posts and youtube videos about the Tenshock 411, and hardly anything about the HW 3656SD.
I'd love to see a race with a Scte with that motor in it just to see how it performs.
Hmm, i have a vid on there but its not of it racing, just running across the yard as the track we have wasnt groomed enough to run on it safely...Just click the pic and it should open up
TCCustoms is offline
Old 09-05-2012, 03:56 PM
  #39047
MIP MATT's Avatar
Originally Posted by jonasm48 View Post
I took apart my scte and inspected my axles, and the ends look a bit wallowed out.
Are axles just a part that needs replaced from time to time?
Are tekno more durable? Are there direct replacement teknos?
Yes there are direct replacement Tekno shafts for the centers and front/rear. I'm currently running them on my SCTE for quite a while and haven't had a failure. I have bent of one the rear shafts but I also splintered a losi shaft in the past and the drive pin slid out and tore apart my rear case. I have heard of people having them bind up but it seems different from SCTE to SCTE because I personally didn't have a problem.
Just my 2 cents.
MIP MATT is offline
Old 09-05-2012, 04:56 PM
  #39048
goehm's Avatar
Trader Rating: 45 (100%+)
1 month? Yikes. Next time give Falcon Sekido a shot, they've been quick and Jennifer in support has been tremendously helping in getting anything I need (including extra cases and switches). Also had good experience with HobbyPartz. CRC should treat you right too, though I don't have first hand experience.
goehm is offline
Old 09-05-2012, 05:00 PM
  #39049
goehm's Avatar
Just my 2 cents.
Did you bend and splinter the shafts when running the MIP chassis and aluminum brace?
Seems that would occur more with chassis flex, and I assumed the MIP setup would be a bit more stiff with it's brace. I know I bent one with the stock chassis and stock plastic brace.
goehm is offline
Old 09-05-2012, 06:04 PM
  #39050
eddomak's Avatar
Originally Posted by GNS Racing 86 View Post
ya im running the 4000kv on a small tight track and its just enough, outdoor or bigger track it would not be enough. also using the gens ace 5000, 50c, seems to be a good motor, only 3 races on it... but i will get the 4600 for bigger tracks....
Agree - I am on the 4000KV on a medium sized outdoor 1:10 track and compared to the 4600KV I think it's not quite enough. All this talk has me itching to buy the 4600KV now and sell the 4000KV.
eddomak is offline
Old 09-05-2012, 06:47 PM
  #39051
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Do it man , do it ?:@)
BDRMBULLY is offline
Old 09-05-2012, 06:59 PM
  #39052
eddomak's Avatar
OK - only if you buy my 4000KV.
It's people like you that make me spend money.
eddomak is offline
Old 09-05-2012, 07:18 PM
  #39053
Trader Rating: 41 (100%+)
What is the safe max temp under racing conditions for a Tekin pro 4600?
rifraf is offline
Old 09-05-2012, 07:26 PM
  #39054
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Some new paint !
And one next to my new buggy ....
BashemSmashem is offline
Old 09-05-2012, 07:34 PM
  #39055
kman16jr's Avatar
Trader Rating: 56 (100%+)
I believe tekin told me 200 but mine runs around 170-180.
kman16jr is offline
Old 09-05-2012, 07:35 PM
  #39056
TCCustoms's Avatar
uh oh, someones got some new sabertooth rims, hehe!!!
Hey, where do you get those little stickers you have on the side doors...we've been looking for some of those???
But looks good...do you paint your own?
  #39057
rcjunky10's Avatar
Trader Rating: 227 (100%+)
180 and below and your good to go!
rcjunky10 is offline
Old 09-05-2012, 07:38 PM
  #39058
Thanks , yes I do all my own painting , the stickers on the doors came with the body .
  #39059
rcracenut's Avatar
Trader Rating: 52 (96%+)
I always believed that you NEVER run a brushless motor over 160. I heard differently about the Pro 4 4600. So I called Tekin and they confirmed that 190 to 200 is OK under race conditions with that motor. Boy, does it ever fly when geared to run those temps. It definately likes it.
rcracenut is offline
Old 09-05-2012, 07:43 PM
  #39060
eddomak's Avatar
Default Newbie Questions - 2S vs 3S
Hi - these are newbies question, but please bear with me...
I understand that with a 3S system it is more efficient than a 2S system and seems to power the truck more easily, just needing to get the right KV motor to put it in the 30K -> 40K rpm range, and then the right pinion gear...
Question 1:
However do you also need the same type of C rating to be able to match the load regardless of # volts?
Eg I am currently using the 2S NanoTech 6600's rated at 65C-130C. If I had a 3S with 6600, would I still be looking for something with the same C rating, or would it not require as high a C rating?
Question 2:
When using a friend's SCTE on 3S 5000mAh, I noticed the batteries were heaps heavier than my 2S 6600mAh's and my 2S 5000mAh's. Although the power was great this significantly affected handling. Are all 3S's that heavy? or is is just the ones he got?
Thanks in advance for your wisdom.
eddomak is offline
