Like Tree9Likes
Old 09-01-2012, 07:45 AM
  #38911
chucko's Avatar
Originally Posted by 1M
What needs to be done to have the SCTE rotate fast on a hair pin corner? If I drive it in deep, hit the breaks the truck just stops it doesn't slide the rear around.
Move your steering link in on the arm of the servo.. put the shorter control arm on. shocks oils and diff oils will make it do what you want. you just have to change oils take notes test.. its hard to say without watching you drive. go fast to turn break turn throttle and if you barrel role your getting close to becoming a great driver. set camber have fun
chucko is offline
Old 09-01-2012, 07:49 AM
  #38912
1M
1M's Avatar
Trader Rating: 44 (100%+)
The truck is great every where except for hair pin corners. I have gone to lighter diff oil in the center. I will be running it again tonight.
1M is offline
Old 09-01-2012, 08:08 AM
  #38913
rcgod's Avatar
Trader Rating: 33 (100%+)
What setup are you running? What track conditions? In general more front toe out, less rear toe in, more front camber, less rear, move rear shocks in on arms. I also find a small amount of drag brake to be helpful to get the truck to rotate on tight turns.
rcgod is offline
Old 09-01-2012, 08:11 AM
  #38914
rcgod's Avatar
Originally Posted by Rcdudes3475
Hey,
I recently just completely redid my Scte and And ever since Ive had a glitching issue. I am running a MMP with Novak 4.5 And S6040 servo. I went up to mikes and I was told to run a capacitor, lower my gearing from a 15t pinion to a 13t and I cut my motor wires shorter. That helped alot but the glitching is there and last week it brought me from 1st into 5th Plz help.
Most guys need an external bec when running the mmp. Capacitor doesn't always take care of it.
rcgod is offline
Old 09-01-2012, 08:15 AM
  #38915
1M
1M's Avatar
30 oil and black springs all shocks, 7 2 2 for diffs, Just changed the center and rear diff fluid. battery is to the rear with ESC behind the motor, Seems very balanced.
Tekin RX* and Pro4 4000 Futaba 9351 servo
1M is offline
Old 09-01-2012, 08:37 AM
  #38916
rcgod's Avatar
I would go to 3,3,2 on diff fluids if you want a lot of rotation going into a corner. 7k in front is hurting you. Never heard of anyone running 2k center. 3k is the lowest I've tried. Option springs and sway bars would help too. Might try disconnecting front swaybar. Some guys swear by it.
If you get the springs and sway bars run black/orange springs, smallest bar in rear and biggest or middle in front. If you want to save some $$ you can bend your own from piano wire.
rcgod is offline
Old 09-01-2012, 08:54 AM
  #38917
1M
1M's Avatar
maybe the heavy front diff fluid, I have front sway bar unhooked with heavy working in the rear.
1M is offline
Old 09-01-2012, 09:05 AM
  #38918
Hello,
I have a small question and hope to find some answer for this:
The steering link that is between servo arm and steering crank (B4210) has two smaller pivot balls in both end of the rod.
Have somebody found this balls form the market? My balls are almost gone, and of course I could buy the whole set but itīs just stupid waste of material...
mamyllyn is offline
Old 09-01-2012, 09:10 AM
  #38919
timannnn6's Avatar
Trader Rating: 140 (100%+)
Originally Posted by mamyllyn
Hello,
I would go this route. You'll get the parts you need and some spares to boot.
http://www.ebay.com/itm/LOSB0128-Los...item564bf3e8d9
timannnn6 is offline
Old 09-01-2012, 09:15 AM
  #38920
rcgod's Avatar
Heavy rear bar gives less entry steering and more exit. Try the smallest bar.
rcgod is offline
Old 09-01-2012, 09:20 AM
  #38921
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
When you say disconnect the front sway bar, exactly which part of the setup are you undoing?
BlackStarRacing is offline
Old 09-01-2012, 09:24 AM
  #38922
Hi,
Thanks for the answer. I infact have those spareparts, and that why searching for only the balls :-)
mamyllyn is offline
Old 09-01-2012, 09:25 AM
  #38923
rcgod's Avatar
Either remove swaybar completely or one of the links that attach it to the arm.
rcgod is offline
Old 09-01-2012, 09:59 AM
  #38924
BmainStar's Avatar
Fri ,nite race report....Thurs nite on the work bench when the old RX8 I was using decided to start doing stupid stuff I smacked it with my pliers on the bottom of the case and it stated to give off the evil white smoke
I posted the pix the other day of my Pro-4 that spun a can and at this point didn't know if I would make the final series race on friMy LHS had no rx8 in stock so had to run about an hour up to the high desert to grab one from Coyote hobbies(thanx Dave!)Got home soldered it up ,rebuilt that pro-4 using screws from the old tekin 5.5 laying around.Didn't know if the pro-4 would still work. Got to the track just in time to shake her down in the parking lot and jam it into the 1st qual round.Now here is the funny part before spinning the can on the motor it would temp at 160-165,last nite she temped at 141 -145!!!WTF????All went well and got my 2nd place plaque for the series with a worked motor that now runs cooler..P.S. got the win in the Main cuz the 14 yr old Phenom Rudy Rico Lost a wheelWhat a day!!!
BmainStar is offline
Old 09-01-2012, 10:22 AM
  #38925
.AJ.'s Avatar
Hi,
When mine wore out i changed the to Traxxas rod ends and pivot balls
http://www.ebay.co.uk/itm/Traxxas-Sl...1#ht_477wt_928
.AJ. is offline
