Like Tree9Likes
Old 08-27-2012, 01:40 AM
  #38746
Trader Rating: 22 (100%+)
Originally Posted by benicetofatkids
what is motor cog?
so i took the rear drive shaft off and it still made the noise. so i took the front one off as well and it still did that, i think meaning its the center diff? how can i tell if the bearings are bad or the diff is. i spin the diff and bearings by it self and it and it seems to spin fine with no drag or noises. im so confused with this problem. the car was brand new and i have never ran it before and it was doing it since i started it up for the first time. but it only makes that noise when i go full throttle from a dead stop. thx again!
Sound like the magnets might be spinning on the shaft.
Honu is offline
Old 08-27-2012, 03:10 AM
  #38747
Originally Posted by rcgod
Sounds like your sensor wire is either not connected properly or is bad. Double check it.
The sensor wire and motor are brand new. Took the motor off the spur gear and went full throttle with it not connected to anything and it seemed fine with no weird noises.
benicetofatkids is offline
Old 08-27-2012, 04:24 AM
  #38748
Originally Posted by RC_Woody
I haven't done it yet, but based on one of Caspers or maybe Chris A. posts a while back, I picked up the losi 22 low friction o-rings. However based on the thread you needed a 3.5x7x1mm or 1.5mm spacer to put in it as well. I have the parts at home, and I would double check in this thread, but I think there were
TLR5074 Team Losi Racing Low Friction Shock Shaft O-Rings (8)
TLR5096 Team Losi Racing 3.5mm Shock Shaft Limiter Set (TLR 22)
(the shim set has multiple sizes, Not sure if there is 4 of the same or just 2 in, haven't checked yet)
could you link to that thread? or to provide a detailed scheme of assembly?
krits is offline
Old 08-27-2012, 04:47 AM
  #38749
.AJ.'s Avatar
Low friction 22 orings with a 1mm spacer from the 22 limiting kit
.AJ. is offline
Old 08-27-2012, 08:11 AM
  #38750
lewis4x4's Avatar
Looking for a little help here... I built a "King Headz" edition SCTE with every King Headz part available (Chassis, outdrives, dog bones, braces and such). This is my thrid SCTE with all the others using the Losi aftermarket chassis. For some reason, I can not get the truck to stop nose diving on EVERY jump and EVERY track I atttend. I have tried everyting I know. I have used different springs, oil weight, ride height and such. Has anyone else had this problem? I have ZERO drag brake and even if I accelorate through the jump, it will still nose dive.
lewis4x4 is offline
Old 08-27-2012, 08:21 AM
  #38751
chucko's Avatar
I had that same problem. took me three days of practice to figure it out.
depending on motor and speed control this is a vague answer. gearing.
if your running a 13 tooth go to a 14 and remember if your at full throttle going up the jump and pinned speed you need a little more motor or speed control to use that to lift the nose. break nose down throttle on nose up. if you running out of power that would cause your problem. also try moving battery all the way to the back. then make sure body is as far back so the front bumper is not touching the body if your body is mounted to far forward that could cause the problem also.. but I would try gearing first then the rest after
chucko is offline
Old 08-27-2012, 08:29 AM
  #38752
BmainStar's Avatar
I think I had my first DNF ever with this truck Friday night,Running 2nd in our local club race great outdoors series and threw her down for the mains and some horrendous noise started to come out of My Baby!Thought oh well she will make it thru the Main noise or not ,always has.Truck was sick dialed all night took off from the grid number two position and got 3 turns in and Bam complete lock upHere is what I found when back in the pits.The small screws that hold the front end bell came loose and spun My motor
Bought this motor used with very little run time on her!
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-bad-can-001.jpg
BmainStar is offline
Old 08-27-2012, 08:33 AM
  #38753
chucko's Avatar
what is motor cog?
COG is motor skipping, when under load, kind of like going off and on at a really fast rate. like your car on bad gas starting off. that noise also could be center diff bearings or internals going bad or built wrong. out of oil. all kinds of different things. take it apart. rebuild , take the bearings, clean, oil, then roll them in your fingers and if you feel any thing that's gritty..... toss them, get new. rebuild diff with what ever oil and then take motor apart do same for bearings. brush out with tooth brush, inspect censer board, if it looks burnt that could be your problem.
chucko is offline
Old 08-27-2012, 08:41 AM
  #38754
chucko's Avatar
That sucks. looks like its time for some new lock tite, maybe a new end bell and can. that happened to me with a truggy motor from tekin. I have replaced screws with longer on motor mount, end bells and top of motor mount. seams they like to save money on using the correct longer screws,,.. I FEEL YOUR PAIN
chucko is offline
Old 08-27-2012, 09:03 AM
  #38755
HighLife420's Avatar
Trader Rating: 49 (100%+)
You can spin the end bell part around to use new holes...also make sure you let the lock tite set before you use it, like 10-15mins should be ok.
This has happened to me before. Just make sure before a big race you check the screws, reapply lock tite if needed.
HighLife420 is offline
Old 08-27-2012, 09:55 AM
  #38756
Team Tekin
Randy_Pike's Avatar
Not good. Looks like someone had it apart before and didn't snug up the screws.
Randy_Pike is offline
Old 08-27-2012, 10:09 AM
  #38757
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
It isn't hard at all. Just flip it over and screw the end plates to the other side. The holes are symmetric.
I hadn't even thought about it since I made my prototype. That was Chucko's idea. I didn't think people would want to run their wires over the center diff.
Originally Posted by jonasm48
looks great shiny.
how hard was it to flip the APE battery tray around like that? how does it handle?
ChrisAttebery is offline
Old 08-27-2012, 10:12 AM
  #38758
AJ,
I see you're running 2 o-rings. I assume that you are not screwing the cap all the way down.
I've been thinking about making a spacer ring that you could put under the shock cap to get consistent compression of the o-rings. I'll have to make a set to try out this week.
Chris
Old 08-27-2012, 10:14 AM
  #38759
Originally Posted by Dan
Has anyone compared the sensored Tenshock SC411 4000kv motor to the sensored Hobbywing 3656SD 4000kv motor?
Both are going for the same price but I'm not really sure which one to get.
i'd also be interested if anybody has tried both and has an opinion. i'd like to pair one up with a hwing 120 pro.
gernaat is offline
Old 08-27-2012, 11:14 AM
  #38760
.AJ.'s Avatar
Originally Posted by ChrisAttebery
AJ,
Chris
Thats correct, i spaced the cartridge cap with another o-ring so the cap doesnt fully wind on, its still a bit hit and miss to get the spacing right tho
.AJ. is offline
