Like Tree9Likes
Old 08-26-2012, 08:25 AM
  #38716
Tlr released aluminum gearbox inserts for our rear diffs. Is this what weve all been waiting for? I was hoping for better diff cups.
http://www.thebigsc.com/?cat=3
Jspfeiss is offline
Old 08-26-2012, 08:29 AM
  #38717
chucko's Avatar
Originally Posted by .AJ.
Has anyone tried this rear brace yet??
http://www.ebay.co.uk/itm/Fioroni-As...c2f9fb6&_uhb=1
Thats a nice looking brace. I have not run that exact one but have tested three different braces on the bce chassis and can say on a tight track a long brace is good.. and on a large 1/8 scale size track I use the plastic short for more flex and traction... hope this helps.
chucko is offline
Old 08-26-2012, 09:31 AM
  #38718
goehm's Avatar
Trader Rating: 45 (100%+)
I hope not, that was over a month ago.
goehm is offline
Old 08-26-2012, 09:38 AM
  #38719
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Yep, I talked to Bill on Friday and I have a few things to try. My chassis is one of the very first batch and it has held up really well. I am not a great driver and my truck has been through some hellacious crashes. The chassis is still in great shape. My son ruined his stock chassis last weekend so I put my BCE on his truck for yesterday's race. That way I don't have to worry about straightening his chassis after every heat.
Originally Posted by NITROALM
I spoke to Chris Attebery Yesterday and we went over a few things for him
to try. He did have alot of good info as far as his On track experience
He runs with some Very fast Nor Cal guys
I did also remind him that he has had his chassis for close to a year
and that we have made three changes since we first came out with His Generation. We will award him the Duriability Awarde..
ChrisAttebery is offline
Old 08-26-2012, 10:01 AM
  #38720
Good, I can stop writing my manifesto against horizon hobby......for now
Jspfeiss is offline
Old 08-26-2012, 10:16 AM
  #38721
KingdomRacer's Avatar
+1
HD diff cups!
KingdomRacer is offline
Old 08-26-2012, 11:24 AM
  #38722
Trader Rating: 22 (100%+)
looks great shiny.
how hard was it to flip the APE battery tray around like that? how does it handle?
Originally Posted by chucko
I am so sorry I thought I was posting a picture of my totally dialed in scte when I did the 8. 2 0 e showing off my polish job. by mistake .yes I have to much time on my hands and polish my chassis to a mirror finish. then build every time I race and do a complete rebuild. I know your saying every time ? I hate breakdowns and DNF's because of a bearing or shaft or something little that make you go nuts. so I build it and make it like its new ever time. I have fun .. Thanks Bill for a great chassis. thanks casper for all you do to help the peps here at rctech with great set up ideas
Attachment 962633.
jonasm48 is offline
Old 08-26-2012, 02:05 PM
  #38723
rcgod's Avatar
Trader Rating: 33 (100%+)
Great. Something else that's not needed for this truck. Maybe for the few running an 1/8 scale system. Never had a problem with stock plastic pieces and I'm on my third truck. How about some new diff cases with bearings to support the wobbly outdrives? King headz already took care of the center diff for us.
rcgod is offline
Old 08-26-2012, 02:14 PM
  #38724
i have a brand new losi ten scte and ran it for the first time today. and i had a very good local racer set up my gear mesh ect. when i run it and go full throttle from a dead start it makes a really nasty grinding noise for like a second and only a second then goes away. if im coasting, even if its the very slightest, if i give it full throttle it will not make any grinding noises at all. has anybody had anything like this before. im running the tekin pro 4 4600kv motor with a rx8 esc if any of that would matter. thanks guys!
i honestly have no clue where to start on taking part stuff to look for it. any help would be appreciated.
benicetofatkids is offline
Old 08-26-2012, 03:41 PM
  #38725
chucko's Avatar
i think it could be motor cog. unplug the censer cable and see if it still has that problem. then try a different censer cable. it could be also....a bearing in the diff cases about to go. or motor bearing. clean check replace as needed after 2 or 3 races.
chucko is offline
Old 08-26-2012, 04:52 PM
  #38726
pfraser2488's Avatar
Trader Rating: 14 (100%+)
Questions?? heat in a losi scte
i know this is a subject that has been talked about but i have done everything
that everybody has said do about the heat
while running in the yard for about 7/8 min i got up to 203 degrees with a castle fan on the motor.
temps outside are 91 degrees w/46% humidity
what i am using
rx8,pro4 4600 kv
5900 mah w/60c battery
all new avid bearing kit in truck replaced all bearings
just installed the king headz motor mount and front diff holder
i have the tlr kit w tlr chassie
i have not added any weight or taken any out not sure what my trucks weighs rtr.
pfraser2488 is offline
Old 08-26-2012, 05:11 PM
  #38727
rcgod's Avatar
what i am using
rx8,pro4 4600 kv
What's your gearing and what profile in the esc? Should be no timing and 13 pinion.
rcgod is offline
  #38728
I hit 165 and I thought that was hot.
Jeffem62 is offline
Old 08-26-2012, 05:26 PM
  #38729
running a 13tooth pinion
rx8 settings are
drag break=0
brake strength=50
push=0
min brake=5
netural width=58
current limit=75
reverse=off
throttle min=0
timing=min
timming profile=c1
curve=3
Old 08-26-2012, 05:43 PM
  #38730
Integra's Avatar
Originally Posted by KingdomRacer
+1
HD diff cups!
+2
Integra is offline
