Like Tree9Likes
Old 08-21-2012, 06:09 AM
  #38581
Gene158's Avatar
What is a good steering servo for this truck? I looked on the first page but I don't seem to see any servo info there, or I'm just missing it.
Gene158 is offline
Old 08-21-2012, 06:20 AM
  #38582
Using ALIGN DS620 with no problems. Enough speed and torque.
asalk is offline
Old 08-21-2012, 06:33 AM
  #38583
Chris K's Avatar
Trader Rating: 46 (100%+)
In my opinion FAST & HIGH TORQUE!!
I use a JR 9100S but I've seen Associated 1015 and Spektrum 6040 used successfully.
A servo with some 'yank' in it gives much more crisp and 'assertive' response to the somewhat porky SCTE.... Porky in a VERY good sense, BTW!
Chris K is offline
Old 08-21-2012, 07:25 AM
  #38584
Grandturk's Avatar
I've used the Savox 1257TG and 1258TG - both have worked well. The 1258 has a little more grunt.
Most importantly - make sure your servo saver is TIGHT!
Grandturk is offline
Old 08-21-2012, 08:18 AM
  #38585
eddomak's Avatar
Default Rebound Settings in TLR Setups?
Hi,
I have just spent around an hour reading the posts on setting rebound (how to's as well as some personal preferences), and was wondering whether the TLR team mind sharing any useful tips on rebound amounts? I don't seem to see that item in the setup sheets.
I am running standard (ie non-emulsion) for the moment and when I took the shocks off from the factory they seemed to be set with no rebound.
I know it may be dependent on track conditions, driving style, temperatures, (also the phase of the moon in Venus and the election cycle), but if people don't mind sharing a little then I would really appreciate learning a little more.
Thanks!
eddomak is offline
Old 08-21-2012, 08:49 AM
  #38586
Grandturk's Avatar
So - I watched tr Adam Drake video on building 8ight shocks and setting rebound and tried to apply the same concepts to the SCTE shocks. However, what I found was without the foam compensator and space above the bladder, there is less room for the bladder to move into when the shaft is pushed in. So what happens when you try to set up for 3/4 or full rebound you end up not being able to push the shaft in at all. The most I could manage with full compression was about 1/2 rebound.
What I found, however is that setting up with more than 1/4 rebound dramatically negative effects on my trucks handling. It felt twitchy and less planted.
Old 08-21-2012, 09:40 AM
  #38587
mysupratoy94's Avatar
Trader Rating: 24 (100%+)
Originally Posted by rcgod
4600 gear 13-15 depending on track size. Make sure no timing in esc and temps usually run 150-180 depending on ambient temps, track and truck weight. Also a lot of push brake or drag brake will increase motor temps.
Thanks for the info. What is the recommended spur gear...40? I like to have some good power but im worried about getting my electronics too hot.
mysupratoy94 is offline
Old 08-21-2012, 10:29 AM
  #38588
rcgod's Avatar
Trader Rating: 33 (100%+)
Yes 40t spur. Put a 13t pinion on it, no timing and check temps. That will tell you if you can gear up. And use a temp gun.
rcgod is offline
Old 08-21-2012, 10:35 AM
  #38589
Jake C6R's Avatar
I've done the foam compensators (cut down and chamfered edges) on both my 8-T 2.0 and 8-E 2.0 and they are a huge pain anyway. Getting the rebound the same seems like luck sometimes, even when you are super careful to set both sides the same. With the SCTE obviously there are no foams and I set them at 1/4 rebound because you are right if you try to get a lot of rebound you won't be able to get full compression.
Jake C6R is offline
Old 08-21-2012, 10:46 AM
  #38590
Sounds good, thanks.
Old 08-21-2012, 11:05 AM
  #38591
offroad dude's Avatar
Trader Rating: 31 (100%+)
Can someone please tell me whats the best body for this truck.
offroad dude is offline
Old 08-21-2012, 11:13 AM
  #38592
chucko's Avatar
I have had good luck with the flow line pro tech.
chucko is offline
Old 08-21-2012, 11:16 AM
  #38593
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
the pro-line flotek is nice i also like the new losi body runs nice good strength where needed.... i did leave some of the flow channels closed i say open a few run it then decide if you need every flow channel opened...
BlackStarRacing is offline
Old 08-21-2012, 11:18 AM
  #38594
Trader Rating: 23 (100%+)
I like the jc high flow but just got the new losi one all painted and ready to try
nitro0619 is offline
Old 08-21-2012, 11:54 AM
  #38595
Thanks guys...
