Like Tree9Likes
Old 03-17-2011, 07:13 AM
  #3841
Default Setup
What is working out to be the hot setup? How does it vary from the setup provided by Losi?
Dr. J is offline
Old 03-17-2011, 07:25 AM
  #3842
Owl
I've been running box stock and nobody can touch me, I've TQed by over a lap on the field all 4 times I ran this truck.
Some of the other guys at the track run 5-5-3 and like it and some run rear spring in the front and like it. Until I get beat I see no need to change anything.
Owl is offline
  #3843
maxx90's Avatar
Trader Rating: 104 (100%+)
Default 2650
Originally Posted by skyler hays View Post
did that 2650 bolt right to the motor mount? no mods needed?
Yes the 2650 bolts right up to the mount.But you have to do some dremel work to the plastics under where the motor sits and shorten or remove 2 screws.
maxx90 is offline
Old 03-17-2011, 07:37 AM
  #3844
Trader Rating: 90 (100%+)
Rear springs in front?
b121774 is offline
Old 03-17-2011, 08:04 AM
  #3845
Hmmm, I can see front springs in the rear, but have a hard time with rear springs in the front as well.
hacker07 is offline
  #3846
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Are there any nuts on the SCTE (other than the wheel nuts of course) that are not 1/4"? Almost seems like you can just get a 1/4" nut driver and that covers everything, the rest is hex.
heavyjeffd is offline
Old 03-17-2011, 08:12 AM
  #3847
jhautz's Avatar
Trader Rating: 86 (100%+)
Funny thing is Ive seen the same things. Guys running the grease in the difs are beating the guys trying to "tune" it. Now we just need to find out where to get the magic losi grease so I can put it back in my truck........
jhautz is offline
Old 03-17-2011, 08:13 AM
  #3848
S/X Runner's Avatar
Trader Rating: 37 (100%+)
You are correct, just 1/4 nuts (then the 7mm wheel nuts).
S/X Runner is offline
Old 03-17-2011, 08:29 AM
  #3849
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Feint Motion View Post
how much stronger is the Machined Aluminum Rear Shock Tower compared to stock? I bent my rear slightly and want to see if its worth purchasing.
I would go with the carbon towers. The machined alum towers will be much stronger but also weigh more. The 4mm carbon towers will be a better choice for this truck IMO.
Those of you with a full set of SAE nut drivers that work well for this car, what are the sizes needed (I know some, like the wheel nuts, are metric)?
I need to grab a few nut drivers (all my tools are metric), getting tired of using small crescent wrenches for what I can reach with them.
7mm for wheels and 1/4 inch for all the rest of the nuts on the truck.
Casper is offline
Old 03-17-2011, 08:33 AM
  #3850
Owl
Just what I was told, personally mine is stock, which is what I'd recommend
Owl is offline
Old 03-17-2011, 08:36 AM
  #3851
heavyjeffd's Avatar
Sweet, thanks guys.
Old 03-17-2011, 08:38 AM
  #3852
badassrevo's Avatar
When installing the optional hinge pin mounts what position do you install the inserts?
badassrevo is offline
Old 03-17-2011, 08:51 AM
  #3853
Casper's Avatar
If you put 0's in all locations you have the stock settings. Some of us are playing with rear antisquat though. Casey went to 1's up which is 3 deg of antisquat and some of us are at 1's down which is 1 deg of antisquat.
Casper is offline
Old 03-17-2011, 08:53 AM
  #3854
wcrase101's Avatar
how does the 2650 mmm/ compare to the mmpsc 1415?
just curious, I have some Ideals pinging around in my head, involves a three cell, and how I'm gonna run it in the outdoor, I have the 1415 with mmpsc in it now and that is plenty for the indoor on two cell, but I'm gonna get a lil crazy on the outdoor tip, maybe.
wcrase101 is offline
Old 03-17-2011, 08:58 AM
  #3855
Trader Rating: 24 (100%+)
I like the feel of the truck with grease as well, what oil wt would I use to have the same feel as the grease??? Hacker do you know.
kerby is offline
