Like Tree9Likes
Old 08-16-2012, 03:52 PM
  #38416
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by tonyxcom
You probably only really needed to taper the leading edge to keep it from hanging up.
I'm of the opinion that when racing, that's the worse thing you could do to the bottom of your chassis as all that skid plate is - is a friction brake every time it taps the track.
I'd take it off if my gearbox wasn't stripped. I had to use longer 5/8 in screws instead of the stock 3/8 in to keep them from backing out. I don't think it should cause me any problems though as before when i raced with it i couldn't notice it at all. Now at least mud won't cake to it.
Rockthecatbox21 is offline
Old 08-16-2012, 04:45 PM
  #38417
chucko's Avatar
Default Front bumper
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-7-10-2012-001.jpg
I tie wrapped a 1/2 inch heater hose with fiber running through the hose in the area where it flexes, I put the hose in and its lasted a yr. it takes the flex out and stops it from breaking.
chucko is offline
Old 08-16-2012, 04:49 PM
  #38418
I could probably use the stock bumper but cut out the part that connects to the top of the diff box. The place where it always breaks is at the part where the bumper connects to the top of the diff. Right now i run the rpm and am happy with it.
Old 08-16-2012, 05:22 PM
  #38419
Grandturk's Avatar
+1
I wouldn't want anything on the bottom only my chassis. I'll pay $90 every year for a new chassis instead. Thats why I deep 6'd the RPM garbage bumper.
Grandturk is offline
Old 08-16-2012, 05:27 PM
  #38420
Originally Posted by Grandturk
+1
I agree, should probably get new gear boxes and go back stock. Just gotta make sure i eon't strip the screws!
Old 08-16-2012, 05:30 PM
  #38421
Grandturk's Avatar
The geArboxes are garbage plastic and strip out like crazy. Try longer screws first. Luckily replacement is only $10 money but effort is like 1+ hours
Old 08-16-2012, 05:35 PM
  #38422
Those phillips screws i have on the rpm skid plate are 5/8 in and they have a nice snug fit on the skidplate. Just wondering if they'll go too far without the skidplate going directly into the gearbox. You think 2/8 of an inch will be too much when getting rid of the skid plate?
Old 08-16-2012, 06:10 PM
  #38423
Suspended
Trader Rating: 89 (100%+)
Holy Cow ---
2.3 million views, and 38k posts? I knew this truck was popular, but damn! I plan on getting one soon and was going to ask the "Must have" list of upgrades, but I have a feeling out of 38k posts, I should find my answer (unless of course someone wants to volunteer all the info up front )
Sarinexia is offline
Old 08-16-2012, 06:20 PM
  #38424
Originally Posted by Sarinexia
Holy Cow ---
I'll do them in order of importance:
1. Carbon fiber shock towers (stockers bend easy)
2. Lightened oudrives at all 3 diff ( tekno makes a complete kit with front and rear driveshafts as well, better investment)
3. New tires depending on your track
(4.) sorry had to edit, HA pivot balls and rod ends.
4. New chassis (i like the bce, but all are good choices)
5. Tekno center diff driveshafts
6. Tlr racing spring sets front and rear
7. Kingheadz center diff mount and motor mount (stock motor mount works fine, just needs better screw)
That's about it for me.
Old 08-16-2012, 06:52 PM
  #38425
Suspended
Haha, awesome . Looks like an expensive list.
Old 08-16-2012, 07:03 PM
  #38426
Get the tekno m6 driveshaft kits for front and rear, losi hd lightened outdrives at the center diff, tekno center diff driveshafts and carbon towers and that is all you absolutely need.
Old 08-16-2012, 07:09 PM
  #38427
Dano628's Avatar
Sorry but the carpenter in me makes me do it . 2/8" is a 1/4" . I would try it you could always take an 1/8" off with a dremel and a cutoff wheel .
Dano628 is offline
Old 08-16-2012, 07:15 PM
  #38428
DanielHolloway's Avatar
Holy Cow ---
If you go back a few pages, there is a list on here. Somewhere around 4 or 5 back.
The list that ol' Catbox made is pretty good start. For sure you will want some serrated wheel nuts. I use the ones for a Blitz, and have never had a problem. Aluminum shock caps are good too.
DanielHolloway is offline
  #38429
Simplify those fractions!!!!! Can't believe i didn't see that. But i'm just wondering if it will be too much as too the point of it going throught the gearbox. Not too good at machining my own screws but i'm wondering if instead of cutting the existing ones, i should go buy some 1/2 in screws. Would like to still use the 5/8 in screws if i can.
Old 08-16-2012, 08:19 PM
  #38430
Casper's Avatar
Trader Rating: 34 (100%+)
I would say the only right away upgrade is the carbon towers.
Another option is the TLR tuned kit but it is bit of money but you get a lot of great hopups for a much reduced price if you were to get all the parts seperate.
Outdrives I would upgrade when you wear out the stock ones.
Drive shafts are fine out of the box.
Upgrade chassis if you feel you want to take some weight out but run the truck and get used to it first.
I agree with the tires for your track and the racing spring sets!
Casper is offline
