Like Tree9Likes
Old 08-16-2012, 12:13 PM
  #38401
Grandturk's Avatar
Originally Posted by bobf24
I would add HA shock bodies and gold shafts up near the top of your list, I think they were the best money I've spent on the truck
Yeah the shock bodies are great and hold up really well. The original blue shock bodies on mine were torn up withing 3-4 months of hard running.
Grandturk is offline
Old 08-16-2012, 12:23 PM
  #38402
Trying to find the ha shock bodies with no luck on amain. Anybody got a link or part number?
Found them.
Jeffem62 is offline
Old 08-16-2012, 12:32 PM
  #38403
.AJ.'s Avatar
TiNi shock shafts are meh, 2 of mine worn down to silver in less than 20 packs
.AJ. is offline
Old 08-16-2012, 12:37 PM
  #38404
Grandturk's Avatar
Yeah I never bothered with them either for the scte. Losi's TI nitride coating hasn't lasted on my XXX shock shafts or my 22T shafts so why bother.
Old 08-16-2012, 12:46 PM
  #38405
BradS's Avatar
Originally Posted by Ralph289
Not crazy about the protection the stock front bumper gives the body, What is the bumper of choice for most of you guys , the RPM, T-Bone or something else ?
THANKS
Stock still best for racing, all others have a skid that will mess up ride height. just keep a spare handy, you won't get a DNF with a broken bumper.
BradS is offline
Old 08-16-2012, 01:24 PM
  #38406
Trader Rating: 28 (100%+)
they are sized differently than the stock ones though so you get freeer shock movement with them even when coating wears off, at least in my experience anyway,
bobf24 is offline
Old 08-16-2012, 01:28 PM
  #38407
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
No ti-ni for me, but the ha bodies with m2c pistons and 22 oring mod made my shocks nite n day. Buttery smoooooove ?:@)
BDRMBULLY is offline
Old 08-16-2012, 01:47 PM
  #38408
n10cities's Avatar
Found them.
For everyone else's reference, they are LOSB2833 & LOSB2834 (front & rear)
n10cities is offline
Old 08-16-2012, 01:51 PM
  #38409
Trader Rating: 52 (100%+)
just picked up a used scte Need help with a body that Fits. I picked up toyota tundra body from proline- Doesnt wanna fit at all. What do u guys recommend besides the stock body? does the Ford F-150 Svt body Fit good?
thedopeshow is offline
Old 08-16-2012, 01:56 PM
  #38410
Grandturk's Avatar
There's no reason it shouldn't fit. You're doing something wrong.
Cut out the wheel wells and all around the body first. Then lay the body on top of the posts, line it up front to back, left to right. Mark the posts. Cut it out. Paint. Done.
Old 08-16-2012, 01:57 PM
  #38411
It fits if you slightly mod the body posts. You just drill new holes for the swivel pads or what ever you call them about 5/16" lower or so. This gives you a little more post sticking up through the body. My front body posts on that body actually go through the make believe hood louvers.
oldschoolnewb is offline
Old 08-16-2012, 02:15 PM
  #38412
only fits if i bring the body forward over the front bumper. all my other bodies have fit before this one doesnt line up.
Old 08-16-2012, 02:25 PM
  #38413
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Hey guys, just got done making a "custom" rpm creation. It used to be an rpm scte rear skidplate, but now its........a flat piece of plastic!!!!!!! Took a ton of dremeling to do this but had to be done since a ton of mud was caking back there.
Rockthecatbox21 is offline
Old 08-16-2012, 03:43 PM
  #38414
You probably only really needed to taper the leading edge to keep it from hanging up.
I'm of the opinion that when racing, that's the worse thing you could do to the bottom of your chassis as all that skid plate is - is a friction brake every time it taps the track.
tonyxcom is offline
Old 08-16-2012, 03:44 PM
  #38415
n10cities's Avatar
I am running the Proline Flo-tek Raptor body and it was a tight fit getting it behind the front bumper. Had to trim the ends off of the rear bumper to get it to set down properly.
Also had to drill new holes in the front body posts and lower the pivot pad mount down so I could get the body clip thru the post as mine came thru the louvered section too, which 'thickened' the body at that point.
